#51 |
Just a car guy
Re: Increased MPG for carbs?
How much driving would you have to do to save enough gas money to pay for the swap?
I'm all about saving gas, but spending $5000 or so to swap will take a long time to pay off. Thats like the hybrids, I didn't understand why people were going out and spending $20-30k on a car to save gas money???
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
#52 | |
#53 | ||
Don't know about you guys, but I hate $500 a month car payments, plus full coverage insurance, expensive tags every year that are based on car values (in AZ) etc... That $30,000+ sure would put alot of gas in the tank of the car I already have. That's not to say I'm against the LS swap. I did a 6.0/4L60 swap in my blazer, but an ailing transmission let me to consider an overdrive which led to just swapping the whole thing. In order to make that cost effective though, you have to plan to keep the vehicle for several years. I drive mine daily and have no plans to sell so it works out for me. An LS swap is still alot cheaper than a new car, and I'm not driving a cookie cutter car around ![]() The cost of the swap never really waivered me in any one direction however, I just knew I would enjoy the 6.0 power and the drivability the overdrive provides. I was in the same boat with my 79 454 pickup. I don't drive it daily, it's just used for towing and hauling stuff. Would have loved a brand new duramax, but I couldn't justify spending $50-$60k on a new truck for something I rarely drive, and only gain about 3-4 mpg. The rising cost of diesel fuel finally put a lid on that idea. Now 40-50 cents more per gallon,,,,no thanks. I'd have dug a deep hole with those truck payments and then the cost to put fuel in it......OUCH! If diesel were cheaper than gas like it used to be (and should be still) I probably would have a new duramax sitting here. Last edited by Firebirdjones; 09-25-2012 at 10:59 AM. |
#54 | |
Just a car guy
![]() I have done a lot of little things to make my truck more effecient, but I really need to learn more about tuning the Quadrajet to really squeeze the miles out of it.
#55 | |
Hopefully you aren't the sensitive type and are open to ideas and/or suggestions. If not, I'd highly recommend investing in a wideband air fuel meter. I've used the LM-1 for many years and it's the only way to tune a car properly. You can shoot for a lean idle 14.7-15.0 and a lean cruise of about the same AFR and that alone will probably get you another 2-3 mpg. It might require that you dive into the carb for a couple of jet changes, maybe metering rods and power piston spring changes. If you run a lighter power piston spring that opens at a vacuum of say,,,,4-8 inches, it will gain you some mileage during throttle transition and light loads (climbing mild grades) when your vacuum is lower, the power piston isn't going to open as often unless you dive below those vacuum readings. So long as the leaner fuel isn't causing any pinging issues it won't hurt a thing. If you do any heavy hauling or towing, this may need to be tweaked more to stay on the safe side of things. That wideband will be your friend, and can be used on any car, just weld a bung in the exhaust and plug it in to the cig lighter, (also runs off a 9 volt battery) you're set to go. |
#56 | |
I look at it this way....Have more power, Better drivability, OBD II dianostics & I havnt done anything to it other than maintenance (oil changes, trans service) in 8 years....Its an overall improvement, Fuel milage was just a bonus. My 350 was getting worn out, With dual smog pumps it was a nightmare to work on & I still had to smog test at the time. The old Burb doesnt owe me anything, I dont see how in the world me doing an engine swap is in the same league as buying an expensive hybrid $hit box?? |
#57 | |
Just a car guy
What I was getting at, was when someone has a good running combo and asks for better mpg advice, and people say "Swap an LSX". That seems silly to me. I understand if you are starting from scratch the LS is a killer engine and a great swap. But to tell someone to spend thousands to swap one to improve their milage is silly.
#58 | |
I actually was happy with the carbed 350 in my 72 4x4 blazer. A mild 355 with a small Crane cam, RPM edelbrock intake and a 750 holley. Long tube headers, 33" tires and 3.07 gears, and the original 350 turbo. I would get 13 mpg around town and 16 mpg highway. Drove it like this for years and was very pleased considering what it was. It never let me down and started every day, very reliable driver. I only swapped in the 6.0 because the original 350 turbo was dying, and figured now is the time for an overdrive, and that led to the LS swap. I already have the software for tuning since we own a couple other LS cars so that expense was out of the way. I'm still a carb guy at heart as several other cars I have are all carbed. You can't beat the simplicity and cheap parts/easy repair. When tuned properly they run and drive just as well as anything else out there. As a matter of fact the LS retro swaps that are converted to carbs are still very popular. Edelbrock makes the intakes, and MSD makes the ignition controller so you still get the benefit of coil-on-plug ignition, cam and crank sensors still used etc.... The only real big advantage the LS engine has over the gen 1 sbc is it's 15 degree heads vs the gen 1 23 degree head, that's why they run so well. Fuel injection is nice, but it's spendy, then you need software to tune and diagnose it which is another added expense. Technically speaking, you could put a nice FAST/Edelbrock fuel injection setup on a Gen1 sbc cheaper than swapping an entire LS engine, and have your multi port fuel injection and easy drivability that way. The 14 mpg you are getting with your current combo is decent. I'm sure you'll find more without spending a ton of cash. |
#59 | |
#60 |
Just a car guy
I'm going to start looking for an s10 T-5 to swap in for milage.
It will drop my cruise rpm by about 1000rpms. That should make a difference!
#61 | |
25-30% gain in fuel economy is what most will experience. That's an easy 3-4 mpg in your case and would put you right at what most brand new SUV's are getting nowadays,,,,not too shabby ![]() |
#62 |
It's really fun reading through all these suggestions guys. Especially since I have no idea what I'm doing. And the only reason why I was considering the $8k 383 was that it would be brand new out of the box, dolled up how I wanted it to be, had about the performance I wanted, and got 20 mpg. However, I've decided to just save up for a motor swap (still debating on which) and keep this thing brute. If I get better mileage, so be it, but I want this thing to be a terror, instead of a Prius (which, looking back at the op, was how it sounded to me lol).
Does anyone know how much mpg the Hennessey builds get? I'm not saying I'm considering them since they're WAYYY out of budget, but I'm curious as to what high powered cars get mpg-wise. And the sole reason why I'm somewhat bailing on the idea of getting in the 20's for mpg is that I plan on buying another car and have that be the mpg-getter while also being a track car with all the amenities inside. But I'd still like to hear what I could do for performance that'll also increase mpgs for my truck, i.e. what cams, lifters, headers, rear ends, etc.
1981 C10 Silverado Package, a.k.a Project Bahamut ![]() |
#63 |
BAD BOW-Silverado XST
Tonneau cover!!
#64 |
I have been renting cars for trips to phoenix from Tucson for the past year. I find that the Japanese and Korean small cars consistently get 43 mpg with about 50 miles of city driving. Actual mpg on hybrids is not much better, so why would anyone spend the extra money for one? BTW, the best mpg I got on GM small cars on these trips was 34 mpg. Honda Civic is the best all around vehicle for economy and comfort, but the Hyundai models are a close second.
#65 |
Not sure how much good a tonneau cover does , I've seen studies where the volume of air in the box revolves and helps the aerodynamic efficiency of the truck. The mass of air rotates and allows the air travelling over the top of the truck to move over the box with a lot less disruption than you would think.
I think panel gaps and design of the undercarriage are big factors. Looking at my 1991 suburban , it is a un molested truck and panel gaps are all over the place and the amount that they stand off the body is not consistent. Lots of places for the air to grab and create drag. |
#66 |
Not a full toneau cover. Look at these NASCAR trucks.
http://73-87.com/7387info/Circle_Track_7387.htm |
#67 |
I'm sure this could help
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
#68 |
hey its the blurple lol
i get 20mpg hiway and to get that i put the fast ez efi and put a nv4500 in my truck. i may be able to get more if i swoped the gears carbs arnt 100% best i can tell you is keep your air filter clean. a little restriction will add more fuel droping your mpgs. a carb will never be best of both worlds if you wont mpgs with a carb your gana have to put the smallest cfm carb on it but there goes your power your gana come to a point where you wont more and it will take money to save money weather it be o/d trans, fues injection, low pro tires, lighter driveline parts
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
#69 | |
Born a Chevy Man
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#70 |
It's getting a little late night for me to get into it whole-hog. But here is what i DON'T believe in:
The whole notion about cold air intakes increases mpg. Why? Because warmer air=less dense air= less fuel. Leave the stock air cleaner assembly completely hooked up the way it came from the factory for best mpg results. Also, what many people may not realize is at full throttle---when vacuum is low, the stock air cleaner lets nothing BUT cold air to the carb. Discuss. |
Tags |
fuel economy, gas mileage, increase, mpg, question |
