Old 12-09-2012, 03:00 PM   #1
NEWFISHER
NEWFISHER's Avatar
Unhappy 250 w/stovebolt cast headers, help-who has one?
I'm looking for someone who has a 250 in an AD with Tom's Stoveboltengines.com cast ceramic headers installed. Mine hits thhe steer boxno matter what I do. I have pulled all the head studs etc and still no room to squeaze it. Let me know if you have a better idea than the torch and building different motor mounts...GRRRRR!
NEWFISHER is offline   Reply With Quote
Old 12-09-2012, 06:38 PM   #2
paintman
Re: 250 w/stovebolt cast headers, help-who has one?
Here's what i'm going to do. Have these mad in stainless. Just so I can have it the way I want it. http://www.stainlessheaders.com/index.aspx
paintman is offline   Reply With Quote
Old 12-10-2012, 09:34 AM   #3
focusedontheprize
focusedontheprize's Avatar
How'd you do with this?
focusedontheprize is offline   Reply With Quote
Old 12-10-2012, 10:03 AM   #4
mknittle
mknittle's Avatar
Talking Re: 250 w/stovebolt cast headers, help-who has one?
He didn't make them, thepicture is a set of a set he missed on e-bay. he is going to have a se made.{colose to $1000.}
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 12-10-2012, 10:05 AM   #5
mknittle
mknittle's Avatar
Originally Posted by NEWFISHER View Post
I'm looking for someone who has a 250 in an AD with Tom's Stoveboltengines.com cast ceramic headers installed. Mine hits thhe steer boxno matter what I do. I have pulled all the head studs etc and still no room to squeaze it. 541 515 ooo5 if you have a better idea than the torch and building different motor mounts...GRRRRR!
That's no fun!
Mark
My GMC build.
Old 12-10-2012, 11:45 AM   #6
NEWFISHER
NEWFISHER's Avatar
I posted this last night, still nothing
Old 12-10-2012, 01:26 PM   #7
NEWFISHER
NEWFISHER's Avatar
Spoke to Tom @ Langdon's ( supplier of the headers) He said when they know that they are being installed in a A.D. truck, they shorten the forward header 3 inches for the customer. Took the truck and headers to the exhaust shop, they will cut it and fit the collector , then I will take the 2 pieces to the machine shop and they will heat them in an oven, weld them with nickle/Copper rod and cool them down in the oven. Small speed bump, but I get to keep the headers!
Old 12-10-2012, 02:59 PM   #8
paintman
Hey Jon, I'm confused (as Usual), these headers you have from Tom ,are they not cast material? How do they shorten them? Do they have 2 different castings or do they just wack off 3" and and re- weld the collector back on? Seems kind of odd to me. Wouldn't a set of Clifford shorty headers work in your situation? Like these
Old 12-10-2012, 03:14 PM   #9
NEWFISHER
NEWFISHER's Avatar
Yes, "new" castings can be welded successfully says Tom and our local machine shop. Used ones, not so much. Carefull heating and pre-cooling, using Nickle -Copper rod are the trick. As I type this they are warming up in the oven.
Thanks for the side shot on the Clifford shorties, they would have worked perfectly!
Old 12-10-2012, 09:09 PM   #10
mknittle
mknittle's Avatar
verrry good!
Mark
My GMC build.
Old 12-10-2012, 09:12 PM   #11
mknittle
mknittle's Avatar
I have welded cast iron with high nickle rod it works well
Mark
My GMC build.
Old 12-11-2012, 12:07 AM   #12
NEWFISHER
NEWFISHER's Avatar
Chopped the header and got it turned to fit. Took both pieces to the machine shop and they pre. Heatedto 700 degreesand welded them up. Put them back in the oven and let them cool down slowly. For over an hour. Bolted it up and towed the Burb to the exhaust shop. They called at 4..all done. Picked it up and worked a couple hours fumbling a coolant leak, ran a choke wire, finished the Lokar pedal swap and hit the key....set the timing and runs like a scalded dog!
