#101 |
Re: Parked Indefinite
Wow that blue is killer, Kept the updates coming !
#102 |
Picked away on the motor, just about ready to go in
#103 |
#104 |
man this thing is gonna be friggin awesome!!
#105 |
![]() Join Date: Mar 2011
You Sir are a God and my hero!! People like you are the ones who I love cause money is not the factor but skill is!! Keep at it my friend!
#106 |
A day should have 30 hours.
Sweet, Keep up the great work
#107 |
#108 |
looks awesome bro....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#109 | |
I hope so! Getting antsy to be driving this again...might be wearing primer this year
Right arm! ![]() Years ago I had a brief stint in a body shop, and actually became somewhat decent, but most has been forgotten. Driven with the confidence of how good I used to be, supplemented by trace memories I figured I'd have no problem picking up the gun again. Unfortunately, I was mired by reality. I was trying to get a somewhat satin finish so it took a little playing around. The first time I sprayed it I went a little heavy on the clear in the mix, so it almost went on like a candy paint. It didn't really cover the orange completely and was shinier than what i wanted. Sanding ensued. This time I just mixed the base with the clear 50/50, added hardener and reduced it till it was suitable to spray. Here's what I got: ![]() ![]() |
#110 |
SO can you give a guy advice on spraying then....Ive never used a gun before...bought one and plan to spray enamel...Its a 1.7 tip gun an im pretty much clueless...
![]() Thx BTW your paint looks good to me
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#111 |
I'd be hard pressed to give any useful advice, as I'm just flying by the seat of my pants when it comes to paint...
#112 |
Plugging away...
#113 |
Great work! Love it!
Volker
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ![]() ´81 GMC C 10, Spanish Red |
#114 |
Keep it up , I look foward to updates
#115 |
Started to make some lines to reunite the master with the proportioning block. While I had the bender and flaring tool out I made up some oil feed lines, not sure if I like them though...they almost remind of that tacky early 90's "the heartbeat of america" logo. Regardless, the next task will be trying to bleed the brakes...looking like its going to be ugly
#116 |
Brief update as usual...buttoned up the brake lines, just need to a hand to bleed the brakes... Started to wire up the 3 components that reside underneath the hood(alternator, starter, distributor) didn't get too far though since the shop was like a meat locker tonight. I decided to bring a few of the tasks at hand inside where heat is. First pic is the edelbrock carb...I've already added a marine accelerator pump and .110 needle+seats, but still need to replace the brass floats with thermoquad ones. Next pic is the gauge I think I'm going to use for boost, found it in a storage locker, just going to see how well it cleans up
#117 |
Hope you don't mind these near daily updates that chronicle next to no progress, but anyway here's another. Hollow brass floats are out and solid thermoquad floats are now in...an excessive amount of pics for less than an hours effort follows:
#118 |
LOLcat
#120 |
WOW not a big lowered fan but that twin turbo has my attention so proud to see awesome work happening just an hour or so away
1978 GMC C25 LWB ![]() |
#121 | |
Well, I put the carb back together and got the most of the engine wiring figured out. I found this scoop in a storage locker, wonder how much cutting and welding it would take to make it work with boost.. ![]() Anyways, the plan was to mount a fuel cell in the back, I just didn't know what to get. Then I remembered 8 or 9 years ago I did get one when a guy redid his car. Well after 20 minutes of searching I found it and sure enough it was just the size I needed. Would've been nice if it had a sump, but good enough for me since it was free. Here's the dirty ol' tank: ![]() Spent a few hours, made up some brackets, and now it's installed: ![]() ![]() Tried to get it as far back as possible so I had room to run the exhaust I want to run...should be enough I think: ![]() |
#122 |
Kudos for thinking outside of the box! I like it!
#123 |
what no update?
c'mon man, I need my morning coffee reading fix. :-) Keep up the awesome work. |
#124 | |
Managed to get the bungs and flanges welded onto the downpipes which meant I could start doing the exhaust. Still plan on wrapping them, but I'll do that later. Anyways, I wanted to try something a little different so I decided to use this 5" exhaust pipe I had: ![]() The plan is going to be dual 3" merged into single 5" which should flow well enough i think. Took a few random pics of where I'm at and will try to finish it up tomorrow. ![]() ![]() ![]() ![]() Last edited by Desperado454; 01-30-2013 at 03:39 AM. |
#125 |
Sin7 = Luis 1959 Apache |
