10-02-2012, 06:28 PM | #1 |
Putting Buddy Buckets back together. Can someone shoot me pix from underneath?
The buddy buckets sat for a long time in peices. I had inteneded on restoring long long ago. If someone has a set out of the truck can you shoot me some pix. I need them from underneath (driverside, passanger side, console box) to see where all this hardware goes.
Thanks |
10-03-2012, 12:05 AM | #2 |
Always on the hunt...
Re: Putting Buddy Buckets back together. Can someone shoot me pix from underneath?
Here you go, the below hardware (pic. 4, 5 & 6) is everything needed to bolt a 67/68 buddy bucket setup back together plus a cab to center jumpseat brace. If you end up finding out that you are missing any pieces when going back together I should be able to help with any of the hardware besides the four pass. side seat riser to frame mounting brackets, currently only have enough of them for the complete seat setups onhand. Have a few original OE cab braces along with the reproed copies of the cab brace available, also had the drivers side adjustment track wires reproed and currently have a few extra 67/68 LH/drivers seat adjuster track sets with handles available along with two extra buddy seat frames which are all real deal OE GM & not halfbreeds. Mel
10-03-2012, 12:06 AM | #3 |
Last two pics...
10-03-2012, 11:44 AM | #4 |
I definitely need the drivers side adjustment track wires and can you shoot me pix of the original OE cab braces and the repro cab braces and prices on all that. My e-mail is bruce@kohensports.com
In the picture below what is the angle iron piece circled in Yellow. Also the thick washers, do they go on the front or rear of the passanger seat Can you shoot a little better picture of them installed? |
01-17-2013, 07:22 PM | #5 |
425hp409
Classic, do yo have any cab braces left, also do the thick washers go between the drivers side outside track and the seat?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
01-17-2013, 07:44 PM | #6 |
I PM'd Classic several times about the connector wire (adjustment track wires). No response. Don't understand if someone offers assistance and won't provide it. But, I can easily make my own.
01-17-2013, 07:47 PM | #7 |
425hp409
I can give you the dimensions if you need them.
01-17-2013, 07:52 PM | #8 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-17-2013, 07:58 PM | #9 |
Thanks Leddzepp Cool to know. I did pm him several times during the summer so it must have been during the season or something. I do need the dimensions or an adjuster either way...Thanks in advance
01-18-2013, 09:45 AM | #10 |
subcribed
08-17-2015, 11:42 AM | #11 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
