Old 01-23-2013, 08:29 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
Lifting my 90 model k5
I recently bought a 1990 k5 blazer. 86k original miles efi 350. I want to lift it enough so that I can run 35's what is the most cost effective way to get there? Also how much lift do I need? I also want to keep my gear ratios as close to stock as possible for gas mileage purposes so what do I need to re gear to? Thanks in Advance for the help
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 01-23-2013, 08:58 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Lifting my 90 model k5
4" spring front, block rear. 4.11 gears will put cruise rpm at 70 mph at 1,933 rpm. Might be a touch low for a brick up in the breeze at speed. 4.56 gears will raise engine rpm at 70 mph to 2,145. That should be enough to keep it from downshifting constantly if the engine is healthy, but I haven't done it myself to know for sure.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-23-2013, 09:05 PM   #3
jbristo67
jbristo67's Avatar
I think in that case ill run 456. Yeah motor is beyond healthy. What should I expect to spend on gears
2011 Nissan Armada
Old 01-23-2013, 09:09 PM   #4
68Timber
68Timber's Avatar
$400 to $500 in parts for a front and rear gear swap full kit, another $400 to $500 in labor to change the ring and pinion front and rear.
John
74 Honda Z50 build
Old 01-23-2013, 09:28 PM   #5
jbristo67
jbristo67's Avatar
I don't believe in paying for labor
2011 Nissan Armada
Old 01-23-2013, 09:30 PM   #6
jbristo67
jbristo67's Avatar
2011 Nissan Armada
Old 01-23-2013, 09:34 PM   #7
68Timber
68Timber's Avatar
I don't either. My latest gear/posi is being done on favor for favor trade - best way.
John
74 Honda Z50 build
Old 01-24-2013, 01:14 PM   #8
Ski-me
Ski-me's Avatar
2.5" BDS front leaf springs, 2.5" blocks in back.
35" tires on 15" wheels.
At 70 MPH with 3.73 gears, I am at about 1,800 RPM's and it does downshift if I go up any grade....
I do rub on my front fender if I turn sharp while hitting a bump. 4" lift would probably solve that but I prefer it lower.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 01-24-2013, 01:21 PM   #9
riz
I have 4" of suspension and 2" of body lift to fit my 35s..... I curerently have 3:42 gears but plan on swapping to 4:56s for the proper driving rpms... My engine is a very healthy balanced and blueprinted 350.
RIZ
riz is offline   Reply With Quote
Old 01-24-2013, 03:25 PM   #10
jbristo67
jbristo67's Avatar
dude your blazer is exactly what I'm going for. I will prob run black 20's instead of 15's but your blazer is sweet.
2011 Nissan Armada
Old 01-24-2013, 03:29 PM   #11
bohmankid
bohmankid's Avatar
Mine has a 4 inch lift by Procomp. Springs in the front, blocks in the rear. 35x12.5 R16 tires don't rub.
Also, an alternative do the blocks would be a shackle flip. I wish I would have done that instead of the blocks.
bohmankid is offline   Reply With Quote
Old 01-24-2013, 06:06 PM   #12
Ski-me
Ski-me's Avatar
Attachment 1047282
I've heard that a lot on the blocks but never really understood the real reason. Why would you prefer the spring lift or shackle flip vs. a lift block? What are the measurable differences you've experience?
U-joint life? Axle wrap (and how can you tell)? Etc.
A lot of people "say" the leaf lift is preferable but why?
Thanks!
- Jeff
Old 01-24-2013, 06:08 PM   #13
Ski-me
Ski-me's Avatar
While we are on the subject...how many leafs do you currently have in the rear (including the Overload on the bottom)? 5 or 6? Just curious.
I assume just two leafs up front....correct?
- Jeff
Old 01-24-2013, 07:43 PM   #14
dman1982
dman1982's Avatar
if you have the cash i would go with something other than rough country, the price is right on them but takes them forever to smooth out, they live up to their name when it comes to rough....my k10 has a 6 inch lift (i ordered a 4) and its a rough ride...but my 35's fit under there nice and sweet...thing is tho i got those 35's with some 3.08 gears with the th350 tranny, not cool going down the highway and its super slow outta the hole
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 01-24-2013, 07:57 PM   #15
Prerunner1982
Prerunner1982's Avatar
Thanks!
Axle Wrap- the rear end will bounce and/or thunk when accelerating or getting on the gas hard. The block put more leverage on the leaf twisting it into a lazy S (S on it's side) shape. Then the spring tries to pop back into it's original position, back and forth they fight until the torque is released.
A lift leaf pack will be arched more than the stock spring with a block and have less leverage, therefore will better counter act the torque load.
This may also help the rear u-joint life since the pinion of the axle will not be snapping up and down violently.
A shackle flip provides the lift, keeps the stock spring for a better ride and flex (less arch = better flex) and since the leverage between the axle and the leaf pack has not change (other than due to tire size) it is not as likely to cause axle wrap as a block would.
They make traction bars and add on leaves that are meant to counter act axle wrap as well.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 01-24-2013, 09:54 PM   #16
cdm10700
cdm10700's Avatar
i had 35s on a 4 in lift no problems with turning or anything
what transmissions you guys running to get the lower rpms at 70mph
i have sm465, 205, 3:73 and i think it runs about 2100 2200 at 55
cdm10700 is offline   Reply With Quote
Old 01-24-2013, 10:20 PM   #17
dman1982
dman1982's Avatar
i believe they have the 700's...overdrive
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-25-2013, 11:27 AM   #18
Ski-me
Ski-me's Avatar
Yea, 700r4.
Be careful with 3.73 gears. Just because they are higher doesn't necessarily mean better gas mileage with larger tires. Mine has to work pretty hard to get the thing rolling down the road. My MPG is about 11.
I met another guy who has 33 inch tires and went from 3.73 to 4.56. His mileage went from 11 to 14. So keep that in mind as you analyze gearing.
- Jeff
Old 01-25-2013, 09:13 PM   #19
79Betty
79Betty's Avatar
Also depends on the motor, th350 4.11's 35's i get about 13 highway. Hopen my 465 swap and 3.08's will counter it and help...
79Betty is offline   Reply With Quote
Old 01-25-2013, 10:26 PM   #20
cdm10700
cdm10700's Avatar
you will get better mileage with 465 and 3:08s?
Old 01-25-2013, 10:33 PM   #21
79Betty
79Betty's Avatar
With my 350 n 4.10's im crusin at 3,000 rpm. Both final drive's are 1:1 so i'll be crusin at about 1900 with 3.08's. more in my power range. At 3k my motor is about topped out. With the 4 speed i'll have my town gas milage, as the gears one lower in the tranny, but one higher in the axles make up for it... Hard to explain on here lol. Woth my 350 n 3.08's it's too high in town so it'll make up for it. This's my cruiser not my toy.
Old 01-25-2013, 11:01 PM   #22
LONGHAIR
Unless you know someone willing to trade you labor for something else, make an exception on this one. This is not a job to tackle yourself, it is best left to a pro.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-26-2013, 09:37 AM   #23
dman1982
dman1982's Avatar
^^^^^i so agree!!!!^^
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 01-26-2013, 05:22 PM   #24
DetroitDan
DetroitDan's Avatar
I had a 91 Blazer last year with a 4 inch all-spring lift and BFG 35s. Could get them to rub hitting a bump while turning (into my driveway, every day) so I clearanced it with a sawzall just a little. Had 3.08s and a 700r4 behind a tbi 350, too much tire height for those gears, but I would definitely not recommend 4.56s. Way too much imo. 3.73s would be enough to satisfy most, 4.10s are pretty much ideal. Keep in mind, your carriers won't support a drastic swap. May want to consider swapping in 3/4 axles, easy swap. Radial tires rarely measure anywhere near their stated size, so you're probably only getting a 33 anyway.
Hey Ski-me, are you sure that's only 2.5 inches of lift?! Mine had the same exact tires and yours is as tall, probably taller. I would have bet that was a six inch lift. Doesnt look like theres any bodylift there either.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-20-2014, 12:47 AM   #25
jbristo67
jbristo67's Avatar
I just did a google search because I'm ready to do my life and I happened on my own thread. I still can't get a good answer on what lift to run. I was decided on procomp but I've read places that it rides like crap. Any truth to this. Anyone run the 4 wheel parts lifts?
2011 Nissan Armada
