Wanting increased fuel carrying capacity and not wanting to mess with the old two tank system that someone had previously rigged, I went scavaging in the wrecking yard. Found a 40 gallon tank from a 85-86 suburban that measured just about right for my needs. It was nescessary to remove one of the frame braces just behind the rear axle but added cross braces of 2"x2"x3/8" angle to mount the tank between. These new braces along with the receiver hitch in the rear should be ample for the removed brace. Used original tank straps but ran them with the frame instead of across it and cushioned all mating surfaces with rubber inner tube. Nice thing was the tank cost me $45 and I got $20 worth of gasoline out of her!
'72 4x4 Blazer (in the works) |
Additional photos
More shots
What are the aprox. dimensions of that tank, I want to remove the tanks from the cabs of both of my trucks and that looks like a pretty good option.
Ron
72 Chevy C10 (rust repaired, starting body work) 72 GMC 3/4ton 4x4 72 Chevy C20 Suburban 38 Ford Tudor Humpback Sedan (from the darkside ![]() 67 Pontiac Parisienne 55 Studebaker Commander 2dr Hardtop (Starliner) My Youtube channel with Video Updates! |
Tank is approximately 12"H x 26"W x 33"L. If you are going fuel injection you may want to consider a tank from '87 suburban up. The '87 I measured in the wrecking yard was the same size as above but had the electric fuel pump in the tank. Check on these years for yourself, I'm just going by what the guy said. I would try and get the mounting straps and any other things you might need to make mounting easier. The '85 tank I used had the fuel filler on the passenger side of the burb, I turned the tank 180 degrees so that the filler would fit my '72 driver side location.
Wow, I calculated that a 3'x3'x1' tank was 20 gallons, boy was I far off.
Looks like a good option. Ron
From what I found in my references, 1 gallon= 231 cubic inches This would mean a 44.57 gal tank but the measurements were approximate, corners aren't square, etc. I bet it is at least a 40 gal tank which is about twice what I had. Now I need to figure how do I afford to fill this thing up?!
MOVE OVER
That does sound like a good option,, I wonder if I can do that with my 72 C-10, its just currently a work truck, so I dont need a custom tank or fuel cell, but a large one would be great
No matter where you are..... There you are... Buckaroo Banzi |
Can't kick the addiction!
I was always wondering about useing a 73-86 burb tank in the rear of my truck, now I know how to do it so it will fit. Thanks a lot, TexSparks, the pics are great.
Just couple questions on this....Notice your truck is 4WD w/ leaf springs. Do you feel there will be enough clearance with coil spring set up? (I.E. swaybar, crossmember and coil interference) How about overall ground clearance since alot of guys are looking at this adaption for C10 picups? thanks.
motoretro 1972 Chevrolet Custom 10 Lwb www.esivart.com/ebay/truck.gif |
Any fuel flow problems with this install....or does the electric fuel pump help...........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Looking at a coil spring frame I have, the coil suspension should not be a problem. Tank should fit between the panhard bar and rear of frame with room to spare. My tank is 8" below bottom of frame rail so this may be a problem with lower vehicles. Blazer tank or other smaller tank may be a better choice.
My electric fuel pump is mounted on the frame rail and should feed as my old smaller tank. Just put the body back on this weekend so don't know how it is all going to work yet.
Insert witty comment here
I wonder if that would work on my 74 short step? I have to get fuel with my one 15 gal tank twice a week if I don't go anywhere..
![]() Join Date: Jan 2015
Re: Installed larger gas tank
in for the pics
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
#15 |
Any updates on this, Did the Test drive go OK?
#16 |
The Older Generation
The OP hasn't visited the site for about a year. It would be nice if he would pop in but it may not happen...... LockDoc
