Old 02-18-2013, 07:59 PM   #201
jocko
jocko's Avatar
Re: SPID Picture thread?
here's an oddball for ya... A Z84 Cheyenne Super?? Never saw that before! (A Z84 is a Cheyenne (or CST) and a Super is a YE9, normally). Maybe they do stuff different up in Oshawa. For what it's worth, the truck was indeed a Cheyenne - the only "super"-ism was in the name of the RPO, which was clearly incorrect. I do believe it was original - this was a truck I was looking at a while back.
Old 02-19-2013, 05:23 PM   #202
Chevyc10572
Chevyc10572's Avatar
Have any of you guys seen this on a 1970 c10 big block, air but no radio
Chevyc10572 is offline   Reply With Quote
Old 02-19-2013, 05:37 PM   #203
cheyenne shortstep
cheyenne shortstep's Avatar
Latest parts truck. Z-fremont, 1972
cheyenne shortstep is offline   Reply With Quote
Old 02-19-2013, 06:12 PM   #204
SS Tim
SS Tim's Avatar
Its not unknown and being Custom Deluxe makes it even more likely than say a Cheyenne or a Super.
SS Tim is offline   Reply With Quote
Old 02-19-2013, 10:04 PM   #205
Steeveedee
Who Changed This?
Steeveedee's Avatar
That's the second one I've seen with Turbo Hydra-Matic misspelled, mine being the other one- a "U" instead of an "I" in the last word.
~Steven
Simi Valley, CA
Old 02-27-2013, 08:04 PM   #206
Maple Leaf C1O
Typical Western Canadian farm truck. 250 six cylinder, gauges with a
Turbo 400 and the optional wood floor box. Not too sure about the J63
brake shield option with drum brakes. Sorry about the poor picture quality.
Maple Leaf C1O is offline   Reply With Quote
Old 02-27-2013, 10:42 PM   #207
SS Tim
SS Tim's Avatar
This is a great resource and I can understand not wanting to post a VIN. However if at all possible, those that do edit their pictures or cut off the top, it would be really appreciated if you would state the plant and model year. Chevy examples would be 2Z,1S or 9A. It helps me to track changes between years and plants.
Old 02-27-2013, 10:50 PM   #208
Justin36
Justin36's Avatar
Justin
Justin36 is offline   Reply With Quote
Old 02-27-2013, 11:04 PM   #209
1972K20
1972K20's Avatar
SS Tim, I posted one that's on page 6, it's post #148. I was wondering what the "Georgia Power Company" was? Did other utility companies have there own codes?
1972K20 is offline   Reply With Quote
Old 02-27-2013, 11:24 PM   #210
SS Tim
SS Tim's Avatar
Just as an example of my last post. Of the 1970 Freemont 0Z SPIDs I have data from several show it. Roughly between 125800 and 167800 are the only examples showing it though. Sounds like a code or printer problem. If yours (and anyone else's) is outside that range I'd be interested in adding data points.
Old 02-27-2013, 11:54 PM   #211
SS Tim
SS Tim's Avatar
To answer your question yes. It is not uncommon to see a fleet order option truck to have a user named build code. Being as they are fleet option they do no conform to the RPO standard uniform production codes or groups. Without a little documentation it is impossible to say what these three specific option codes represented. However they were different from each other as denoted by the last letter change of the exception code suffix.
Could very well be that the AA code is for special paint though.
Old 02-28-2013, 12:09 AM   #212
roadmaster301
roadmaster301's Avatar
Pretty normal truck, only thing that is weird thing is that the truck has a 14000lb gvw plate but has no options that say it should have it.
72 K5 Blazer
68 C30
95 Buick Roadmaster
90 Geo Tracker(dune beater)
89 Honda Civic (winter beater)
roadmaster301 is offline   Reply With Quote
Old 02-28-2013, 12:31 AM   #213
SS Tim
SS Tim's Avatar
Your truck was probably rated at 14k as it has the Z51 rating plate (build sheet code) and not the lighter 10K plate found on R05 chassis cabs. But like you say it does not show a supporting tire RPO or the H22 axle required for the bump. Does it have the HO110 axle with ten lug rear and five lug fronts?
Old 02-28-2013, 12:53 AM   #214
Graham57a
Graham57a's Avatar
Originally Posted by blownrsz View Post
SWB BB
Do you have any pictures of this truck??
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 02-28-2013, 01:01 AM   #215
roadmaster301
It has the HO72 rear and and eight lug all around. The truck also has 18 in wheels which aren't listed. But it has the 18in spare listed.
72 K5 Blazer
68 C30
95 Buick Roadmaster
Old 02-28-2013, 01:25 AM   #216
SS Tim
SS Tim's Avatar
Then it was a 10K truck. The spare and carrier were options on chassis cabs with R05. It has the R05 included maker lamps though? If you look up the load chart in the drivers handbook you will see it requires the H22 option for the 14K capacity. Looks like the load plate was a missbuild. Have seen a few pickups with the incorrect 10K plate vs the correct 9K too. As unlikely as it is does your truck have a build sheet or Protect-O-Plate?
Old 02-28-2013, 01:39 AM   #217
roadmaster301
Yea the misbuild makes sense, that gvw chart always is what got me. I wish I had the protecto plate or build sheet although I thought the never put them in the trucks, but I don't know every thing. I'm still confused as way they didn't list the 18in wheels as an option unless that was a misbuild to.
72 K5 Blazer
68 C30
95 Buick Roadmaster
Old 02-28-2013, 01:51 AM   #218
SS Tim
SS Tim's Avatar
Well strange things happen. The 18" tire were a dual only size and that spare wheel RPO is not on my list. "...that gvw chart always is what got me." is there something I can help with?
Old 02-28-2013, 01:59 AM   #219
roadmaster301
No I'm all good With the info you gave. The chart confused me because it said I need the 11000lb axle for the 14000lb gvw plate. But I didn't have that axle.
72 K5 Blazer
68 C30
95 Buick Roadmaster
Old 02-28-2013, 02:08 AM   #220
roadmaster301
Now that I look at it more Q31 is the code for 18x5 wheels I wounder if it meant that it came equipped with them and had a spare.
72 K5 Blazer
68 C30
95 Buick Roadmaster
Old 02-28-2013, 02:36 AM   #221
SS Tim
SS Tim's Avatar
Don't know what to say 7.00x18 8 ply tires were one of six dual only sizes in 67. They were RPO code R90. The Q31 code (found it...) was for a bare wheel only as was the custom.
Old 02-28-2013, 08:58 AM   #222
Justin36
Justin36's Avatar
A truck we recently sold
Justin
Old 02-28-2013, 09:25 AM   #223
roadmaster301
Here's one from c60 I was looking at. I thought it was pretty well optioned.
72 K5 Blazer
68 C30
95 Buick Roadmaster
Old 02-28-2013, 09:40 AM   #224
b.eddy's72
b.eddy's72's Avatar
Here is my 67, for some reason the VIN does not match a VIN Code Chart I found on the net.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline   Reply With Quote
Old 02-28-2013, 12:23 PM   #225
SS Tim
SS Tim's Avatar
So what is the problem?
C Conventional Cab 4x2
E V-8 Engine
2 3/4 ton
4 Pickup
7 1967
Z Fremont CA assembly plant
149875 serial number
