Old 03-04-2013, 10:45 PM   #1
gofast68c20
Porterbuilt sway bar HELP!!
I've got Porterbuilt's mild front and rear dropmembers on my truck with 1" narrowed control arms. I'm not sure which way the sway bar goes, over the tie rod or under. With it mounted on the frame where the instuctions say and under the tie rod, the spindle hits the sway bar with the wheels turned. With it over the tie rods the sway bar links hit the tie rods when aired out which keeps the frame from going all the way down. I mocked up the sway bar approx 1" further back with it over the tie rods and now all is good except when set at low ride height the spindle hits the sway bar when the wheels are turned. Any suggestion/ pictures would be great. I will post pics soon.
gofast68c20 is offline   Reply With Quote
Old 03-04-2013, 11:02 PM   #2
gofast68c20
Re: Porterbuilt sway bar HELP!!
This is with the suspension aired out wheels straight and sway bar about 1" back.
Old 03-04-2013, 11:05 PM   #3
gofast68c20
Top view, just realized looking at these pictures that maybe I need a narrowed sway bar.
Old 03-05-2013, 01:53 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
There is different linkage for the 1"narrowed arms. I will give you a buzz tomorrow to get you taken care of!
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-05-2013, 09:43 AM   #5
Bennett68C10
Bennett68C10's Avatar
Nate will I need this linkage as well with my Touring Dropmeber, 1" narrowed arms and my sway bar.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-05-2013, 09:45 AM   #6
gofast68c20
Thanks Nate, looking forward to hearing from you.
Old 03-05-2013, 11:16 PM   #7
gofast68c20
Well I think I figured it out! There is no way it will work with the sway bar over the tierod. I put it under the tierod with 1 bushing between it and the control arms. Cycled the suspension up and down with the wheels turned and everything clears!!
Old 07-19-2014, 05:20 PM   #8
Gipper01
Gipper01's Avatar
Nate, I received the sway bar with the extended linkage when I ordered my mild front dropmember with 1" narrow control arms. Should I have the shorter sway bar linkage setup in order to avoid wheel and modular drop spindle interference.
Gipper01 is offline   Reply With Quote
Old 07-19-2014, 09:13 PM   #9
calvin78612
calvin78612's Avatar
I too have the 1" narrowed upper & lowers, still waiting on my sway bar ( 2 months) i hope i receive the correct one. I ordered my sway bar and arms from Travis.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 07-21-2014, 03:04 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Sorry for the delayed response... I just don't have the same amount of time to spend over here that I used to. In the future, for a more timely response, please use our direct email: sales@pbfab.com or tech@pbfab.com
I do have one of our team members monitoring PMs, but we don't always make it into the forums.
We have been having some "issues" with ADDCO for several months now. It has reached the point to where we are looking into a "plan B" to resolve the issue. This is taking a little time, so we are keeping the current orders with them until "Plan B" is solidified and tangible. They are telling us they will be caught up "shortly" but are not willing to give us an exact date as of yet. We are doing all we can to get our customers the sway bars that are on backorder. This issue will be resolved soon.
Feel free to send any tech questions to tech@pbfab.com I answer them personally.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 08-23-2014, 06:26 PM   #11
Gipper01
Gipper01's Avatar
Thumbs up Re: Porterbuilt sway bar HELP!!
Thanks To the PB Team, I received the correct sway bar to LCA linkage Once I mount the tires, set the ride height, and install the sway bar w/linkage, I'll snap a few pics and post them to the forum.
Old 12-21-2017, 10:17 PM   #12
59GMCApache
59GMCApache's Avatar
Do you have the pics of the sway bar and tie rod route?
59GMCApache is offline   Reply With Quote
Old 12-22-2017, 12:40 AM   #13
Gipper01
Gipper01's Avatar
I'll get around to snapping a few shots and post them within a day or two.
