Old 06-23-2012, 06:49 PM   #76
Effeckt
Effeckt's Avatar
Re: Headers to 2.5" Ramhorns
So I am finally getting around to looking into getting these. I don't love the alternator mount but don't really have the means/tools to remove it. Is there a set that will fit without the alternator mount? Like the 674-501? I'm guessing not or there would be more talk about them. Would there be any figment issues if I just left the alternator mount on them?
My 1972 K5 Blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=399719
Effeckt is offline   Reply With Quote
Old 06-23-2012, 09:28 PM   #77
jaros44sr
jaros44sr's Avatar
Depends on which ones you buy, when i bought mine, i had to buy the same manifold for the right and left side. So, with that being said, the alt. mount will be located at the back of the engine on one side. And it does hit the firewall, so in my case i had to cut it off.
It was really easy to cut with a angle grinder, and a cutoff wheel
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-23-2012, 10:56 PM   #78
Heavy Evy
born to lose
Heavy Evy's Avatar
Not to brag but I picked up a used original set locally for 30 bucks! They're going on my truck ASAP since they didn't clear on my Nova. How do you guys like the dormans?
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 06-25-2012, 08:54 PM   #79
SeventyOne
Got a buddy with a grinder? It literally takes 20 minutes per manifold to remove the bracket and "sculpt" the metal to look right. Then hit it with some manifold paint.
SeventyOne is offline   Reply With Quote
Old 06-26-2012, 01:04 PM   #80
jaros44sr
jaros44sr's Avatar
Might be a good time to start a tool collection, really not much money if you go to harbor freight. Just a thought, but an angle grinder with a cut off wheel went thru it like a hot knife through butter...
BTW, nice looking truck!
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2012, 11:24 PM   #81
Effeckt
Effeckt's Avatar
Thanks Jaros! Time to really start investing in this thing. It's not running properly right now, so I'm working on that now and these manifolds are part of the process. The plan is to use my tax return next year to get some color on it as well. I have some tools but not a ton of power tools. I have a buddy that likely will have one. If it's that easy then time to make a trip to his place!
My 1972 K5 Blazer
Old 03-04-2013, 12:13 PM   #82
Effeckt
Effeckt's Avatar
Another quick question on these, when they came in, there was a slip in there recommending not using a gasket to mount these to the block. I'm hesitant to go that route and wanted to see what others did/used for theirs.
My 1972 K5 Blazer
Old 03-05-2013, 07:52 AM   #83
rsavage
rsavage's Avatar
I have never mounted exhaust manifolds without gaskets nor have I seen it done. Why go through the work only to find out that there are leaks. Stock exhaust manifolds had gaskets. Why would aftermarket manifolds, most likely cast overseas, not need them? If it were me, I'd use gaskets.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-05-2013, 06:02 PM   #84
Effeckt
Effeckt's Avatar
That's what I thought too but I wanted to make sure I wasn't crazy. Thanks for the feedback.
My 1972 K5 Blazer
Old 03-07-2013, 12:34 PM   #85
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I am not running gaskets based off info from this board and I have no leaks. I ran gaskets on my 69 and had leaks.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 03-07-2013, 03:22 PM   #86
jaros44sr
jaros44sr's Avatar
JMHO, not saying anyone is right or wrong, but this topic has been debated a long time.....probably since the internal combustion engine was invented
I think if your surfaces are true and flat, plus using oem locking plates, you could get away with a copper shield sealant. Anyway, thats what i plan to do, and you guys will the first to know if that system fails
I think the gaskets fail because the bolts arent retoqued after several heat cool cycles, wrong bolts, and failure to use the mechanical locking plates
SAFETY FIRST
AS usual, off topic
Jim
Old 03-08-2013, 09:13 PM   #87
NuBomb
NuBomb's Avatar
Has anyone bought the Wysco ones from Jegs? I'm thinking about ordering them this weekend.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 03-08-2013, 09:43 PM   #88
jaros44sr
jaros44sr's Avatar
Na, mine were Dormanns
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2013, 01:48 PM   #89
Ole Beater
They look like the dormans with all the grinding work already done.
Ole Beater is offline   Reply With Quote
Old 03-11-2013, 07:24 PM   #90
NuBomb
NuBomb's Avatar
It looks like they are just a little more money, but you don't have to grind on them. I'm just checking here to make sure they aren't junk.
Jeremy (NUBOMB)
1951 Chevy 1/2 ton
North Georgia Group
Old 03-15-2013, 02:04 PM   #91
CrewCab59
CrewCab59's Avatar
Are you guy just using the 2 1/2 header collector for these?
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 03-15-2013, 02:15 PM   #92
jaros44sr
jaros44sr's Avatar
I bought my 3 bolt ring from a corvette parts supplier, then the muffler shop just put a flare on the downpipe
Two styles available, one is bent sheetmetal, and the other is a piece of solid steel
Also, ive heard of the donuts failing, so get the one with a metal sleeve
SAFETY FIRST
AS usual, off topic
Jim
Old 03-16-2013, 06:22 AM   #93
CrewCab59
CrewCab59's Avatar
Thanks !
1971 Chevy C/10
Old 08-21-2014, 03:01 PM   #94
1966
I got my manifolds & cut off the brackets. Got my downpipe. Trying to figure out how to mate the downpipe to the manifold. I bought the manifolds w/o the heat tube and they came w/ the donut gaskets...
Do I use a Ball Joint style fitting and slip the 3-bolt flange behind it (donut inside the ball joint)?
Or do I need something like this:
1966 is offline   Reply With Quote
Old 08-21-2014, 08:45 PM   #95
jaros44sr
jaros44sr's Avatar
I would say its more like the second, i took my downpipe to my muffler shop and had them flare my pipe....i use long brass nuts (about 3/4") and high temp. anti-seize, i think its the one with copper in it, don t forget to retighten after a few heat cycles.
Kinda concerned about the inside of that part, as it looks like it is reduced on one section. Try looking the part up on a corvette site.
Let me know if you have any further questions
Hope this helps...
SAFETY FIRST
AS usual, off topic
Jim
Old 12-22-2014, 05:24 PM   #96
SierraMtns
SierraMtns's Avatar
This is a great thread.
I have a question. I'm running old school heads with no mounting holes to run the alternator.
Would the Dorman 674-504 work? Or will I need to run the alternator on the upper passenger side?
Amazon.com: Dorman 674-504 Exhaust Manifold Kit:... Amazon.com: Dorman 674-504 Exhaust Manifold Kit:...
SierraMtns is offline   Reply With Quote
Old 12-22-2014, 08:18 PM   #97
jaros44sr
jaros44sr's Avatar
I m guessing that there is a enongated squared off bracket ( the pivot bracket) on the bottom of the alt. If this is the case, then there is a threaded boss that is on the exhaust manifold
Take your alt. off and post up a pic. of the bottom mount.....
SAFETY FIRST
AS usual, off topic
Jim
Old 12-22-2014, 10:21 PM   #98
SierraMtns
SierraMtns's Avatar
Here is a pic.
You think those manifolds will work?
Old 12-23-2014, 07:53 AM   #99
jaros44sr
jaros44sr's Avatar
I m guessing that you would not use the adapter bracket that mounts around you header, and bolt your pivot bracket directly to the manifold, so, yeah it should work....
Don t forget to buy one for the passenger side, and you will have to cut that bracket off, since it will now be facing the firewall. Unless, you buy the proper manifold
SAFETY FIRST
AS usual, off topic
Jim
Old 12-23-2014, 09:39 AM   #100
CrewCab59
CrewCab59's Avatar
If you don't want to use the heat riser spacer than you can use this .
CORVETTE EXHAUST PIPE FLANGE - 2 1/2" FLAT TYPE
Part#:322106
Price:6.95
Pkg:EACH
Year:1962-1974
1971 Chevy C/10
