Old 03-26-2013, 06:57 PM   #76
78camarob
Re: 69 Camaro Gas Tank Install
this is how i ended up doing mine not the best way but it works for now im going to shorten the bolts so they dont show from under the bumper
78camarob is offline   Reply With Quote
Old 04-14-2014, 10:59 PM   #77
lawest
60-65 Falcon and Mustang tank will fit between the rear spring hangers for those with SWB leaf spring trucks. The rest of the install is similar to the Camaro tank install. Mounting is easier since these tanks have a flange all the way around the top, so no need for straps. Thanks for the info on the flip down over-center license plate brackets.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 04-14-2014, 11:16 PM   #78
67Slider
67Slider's Avatar
Cool. What is the capacity? Will the sending unit work with our trucks stock gauges?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 04-16-2014, 02:34 PM   #79
lawest
Capacity is 16 gal. and TriStarr radiator in upstate NY can covert the sender to the GM 0-90 ohm to work with our trucks.
Old 04-29-2014, 11:40 PM   #80
utee05
So I am looking to do this mod as well. Is this all that is needed besides the mod on the license plate for the filler neck:
http://www.ebay.com/itm/1969-Camaro-...item5ae26aa4d7
'72 GMC Super Custom 1500 350 V8 w/AC
utee05 is offline   Reply With Quote
Old 04-30-2014, 11:59 AM   #81
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You might want to rethink that. These trucks have "C" channel chassis and are designed to flex and move with the contours of the terrain. This is why the gas tanks are mounted with straps. With straps the flexibility is maintained. When you bolt the gas tank to the frame, as the frame flexes so will the gas tank, only the gas tank is welded together and is not flexible. Sooner or later the tank will start to split at the seams. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-30-2014, 01:37 PM   #82
utee05
Interesting point. Never thought of that being an issue in the long run. I will be using straps when mounting my gas tank when I finally decide between either the burb tank or the camaro tank.
Old 05-13-2014, 10:30 AM   #83
ekgguy
ekgguy's Avatar
67slider, thanks for the write-up. It made things a lot easier when I did mine this weekend. I followed your parts list almost exactly, except I found my tank at a swap meet.
The only thing I am going to do different is I will be putting the fill nozzle in the bed with a trap door.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 05-18-2014, 12:03 AM   #84
utee05
I ended up getting the tank but when I installed it on my truck it looked to be sitting too low for me. It just looked odd and didn't feel comfy with it sitting that low. I needed to put some square metal tube (2") since my truck has leaf springs so it would not hit the joint where the leaf springs connected to the frame. I think I am going to just sell the tank and get the boyd tanks that fit in the spare tank area. This would sit about 4 inches higher than the camaro tank would.
From looking at ekgguy's pics mine seems to sit a bit lower.
Old 05-18-2014, 12:13 AM   #85
ekgguy
ekgguy's Avatar
My tank sits right against the frame rails and is actually about 2 inches outside the rails on either side. I could see that if you had leaf springs, that it would probably hit the rear mounts or the springs themselves.
Matt
Old 05-18-2014, 12:51 AM   #86
utee05
Yup that's pretty much exactly what is happening. It is a couple of inches outside the rails and it hits the rear mounts. The spacer was needed to clear them. To me it seemed to sit too low but I guess this is to be expected with any tank that is underneath the bed.
You couldn't see the tank from the bumper but it is clearly visible from the side. I assume there won't be any issues with it sitting that low? Also probably other gas tanks would fit in a similar fashion unless I go a custom route which would end up being expensive.
Old 05-19-2014, 10:34 AM   #87
lawest
Regardless of how the tank is mounted it has to come up solid against something so it doesn't move around and chaff a hole in the tank. The answer in either case is to isolate the mounts using a flexible material of some sort like rubber or polyurethane. Not that different from how the engine, T-case, axles, exhaust etc. are mounted to the frame. I had assumed that this was understood, but I guess not.
Old 08-20-2014, 07:11 PM   #88
clemsonteg
Was there a reason for using the 2"x3" tubing instead of 2"x2"? I am guessing that the tank needed the 3" for clearance.
clemsonteg is offline   Reply With Quote
Old 08-20-2014, 07:16 PM   #89
67Slider
67Slider's Avatar
Yeah. I mocked it all up with 1x1 pine boards to find out what height I needed. For my application the 2x3 worked best.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 08-21-2014, 08:09 AM   #90
scott-wisc
scott-wisc's Avatar
I used 1x3 to properly locate the filler behind the license plate.
scott-wisc is offline   Reply With Quote
Old 08-23-2014, 11:15 AM   #91
utee05
If anyone is interested in doing this I have some of these gas tanks I will be parting with.
Old 08-26-2014, 09:48 PM   #92
clemsonteg
Can I ask how you connect the 2 sections of fuel lines? That uses a union right? What about the connection to the tank and fuel pump, did you use fittings or rubber lines and clamps?
Old 08-26-2014, 09:54 PM   #93
67Slider
67Slider's Avatar
I used a union to join the two lines. I used a short piece of rubber tubing from the tank to the hard line under the frame and a short piece from the end of the hard line to the pump. It allows a little flex without stressing the metal.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 08-26-2014, 10:05 PM   #94
clemsonteg
Thanks for all the help and the great write up. I have ordered most of the parts I need and I am trying to put together a list of items to pick up at the auto parts store. I have never messed with fuel lines other than rubber ones so this will be a new experience for me.
Old 01-15-2015, 11:24 AM   #95
mach92bill
Has anyone used a Camaro tank on an AD? If so what sender did you use for the 0 - 30 ohm stock gauge?
mach92bill is offline   Reply With Quote
Old 07-29-2015, 09:54 AM   #96
dwcsr
Hollister Road Co.
dwcsr's Avatar
I realize this is old but here is a 67-68 Camaro tank in a AD truck. the difference in the tanks is 67-68 no neck 69 has a fill neck. this tank is for EFI
Either tank is a good under bed conversion for 67-72 trucks and AD trucks
Old 12-15-2016, 02:17 PM   #97
Island Medic
sorry if this is a silly question, but are there different senders? does a stock sender for a camaro work for this application?
thanks
Island Medic is offline   Reply With Quote
Old 12-15-2016, 02:26 PM   #98
72bowtiestepper
thanks
The 67-69 Camaros & the 67-72 GM trucks both use a 90ohm sending unit & Yes.....the camaro sender works on these trucks.
72bowtiestepper is offline   Reply With Quote
Old 12-30-2016, 12:03 PM   #99
STAP54
67Slider, great information. Thanks for sharing!
STAP54 is offline   Reply With Quote
