03-27-2013, 09:11 AM | #1 |
tire help
ok guys i need some input because tire fitting is like japanese to me. I have some 16.5 rims that i think are either 9 or 9.5 wide. my question is can i put i think 12 or 12.5 wide tires on it or is that to much of a difference and will not work. thanks for your input
03-27-2013, 10:54 AM | #2 |
Re: tire help
Should be fine as long as they are 33" tall or greater.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
03-27-2013, 12:29 PM | #3 |
Re: tire help
If 16.5 they're probably either 8.25 or 9.75 wide, but yes either will be fine with 12.5 tire.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
03-27-2013, 12:38 PM | #4 |
20' Daredevil (Ret)
Re: tire help
Measure your rims inside bead-to-bead to determine their width. A couple common widths for 16.5s are 8.25" and 9.75".
For typical highway use, a tire's tread width should roughly match the width of the wheel. Looking at a 33/12.50-16.5 tire, 12.50 is the nominal section width, and the tread width is 9" - 10". The correct rim width is 9.75". 8.25" can be used but is better suited for off-road where low pressures are used. http://www.tirerack.com/index.jsp is a good resource. You can look up tires by size and they will show you the recommended rim width range.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-27-2013, 02:23 PM | #5 |
Re: tire help
Should be fine,Just swapped my 35s to 37s on the 82 & it seems ok. 16.5 x 9. Will try to post some picts
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
03-27-2013, 07:14 PM | #6 |
Re: tire help
im running 15" wides on just under 9" wheel. itll be fine.
03-28-2013, 01:47 AM | #7 |
Re: tire help
I'm running 35 12.50s on 8" wide 16s
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift 2000 silverado extended cab stepside 5.3l. Stock for now |
03-29-2013, 10:07 PM | #8 |
Re: tire help
thanks for all the input and great comments guys
