View Poll Results: which paint job looks best? | |||
1 |
0 | 0% |
2 |
0 | 0% |
3 |
1 | 5.88% |
4 |
0 | 0% |
5 |
0 | 0% |
6 |
0 | 0% |
7 |
6 | 35.29% |
8 |
2 | 11.76% |
9 |
4 | 23.53% |
10 |
1 | 5.88% |
11 |
1 | 5.88% |
12 |
4 | 23.53% |
Multiple Choice Poll. Voters: 17. You may not vote on this poll |
#51 | |
Re: 71' (gonna be) a one of a kind custom
..........___ ..____//_{)] ______ [_(O)_[___][__(O)_] Project: Under Pressure II http://www.67-72chevytrucks.com/vboa...d.php?t=559720 |
#52 | |
#53 |
Well, there is one lower control arm "on" Posted via Mobile Device
#54 |
been thinking a lot about the paint job on the truck, originally i was thinking just matte black with some blue accents. i also want to shave the handles and the marker lights. the problem i am having is accenting with the blue is hard to do when there is no trim down the side of the truck. i thought about pin striping and still kinda like the idea but with that i was also feeling like the truck will also need some contrast as well. so here is my idea: doing a "factory" style paint job with the matte black as the base and a gloss black as the secondary color with the blue molding or blue pin striping. what does everybody think?
#55 |
Posted via Mobile Device Posted via Mobile Device
#56 |
Spindles will be here in a couple of days
#57 |
Spindles installed........... Posted via Mobile Device Posted via Mobile Device
#58 |
STOP RIGHT THERE! Go right now and get one of your dust shields and try it on. If it doesn't fall right on and lay right down on your mount pads, you're gonna have to grind hell out of the bottom side of the upright to get them to fit/wheel to go on and seat and turn. Had the same problem with the CPP spindles on Yeller. Word to the wise. Our Pass one was fine, Driver's was AFU. At least it was oversize and only cost me 2.5 hrs of grind and fit. Good luck, progress looks great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#59 |
67cheby
![]() Join Date: Sep 2008
looking good man !
#60 | |
#61 |
![]() Join Date: Jan 2012
nice job! what year spindles did you have to order for the hotchkis set up?Im getting all my parts together and I can't remember the year for that ball joint set up ,Thanks and keep up the great work!
#62 |
The spindles I ordered were "technically" for the 71-72. I did a lot of research making sure these were the correct ones for the setup I am going with (the hotchkis suspension and the willwood 6-piston brake setup). And these are the ones I kept coming up with every time without fail. These are just for a 2" drop, didn't want to drop the truck too much. Part number on them is CP30106-3.
#63 |
found my upper control arm spacers i was looking for and got the other side put together. now just need to clean up the garage, lol
#64 |
here is the next step......
#65 |
Has anyone here installed the No Limit rack and pinion kit? I just found it on an ad at the top of the page. It is less expensive than the one I was looking at, but looks like it requires a lot more fab work. Just wanted to see if anyone had any run-ins with it?
#66 |
I haven't yet but I've read a lot about them. They are a little bit m
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#67 |
Sorry...
More fab work, but rob from. No limit has an account here and seems to not mind helping people with questions or issues. I'd rather buy theirs (which is what I'm doing) rather than the other brands. Posted via Mobile Device
#68 |
Yeah, I am leaning heavily toward the no limit kit, I just hate the thought of grinding and cutting on my powder coated frame. It was probably inevitable though.
#69 |
Inevitable yes. If you're good, you can touch it up with paint from your powdercoater. I'm a fabricator and all my stuff I do I get matching paint from my coater for touch up.
#70 |
VA72C10
![]() Join Date: Mar 2008
Nice looking project! I see you're using some quality parts on the suspension!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#71 |
Yeah, I am still in touch with the shop that did the work so I guess I can go see them for that, thanks!
#72 | |
#73 |
Been rethinking the wheels, what does everybody think of these?
Will still have to paint the brushed part blue, can't have that brushed aluminum ![]() Posted via Mobile Device
#74 |
motor exploder
Those would look great with blue accents. I like that idea better than the Ridler's with a blue rim.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#75 |
Yeah, those Ridler wheels are just too over done.
