Old 04-04-2013, 08:14 AM   #126
Bennett68C10
Bennett68C10's Avatar
Re: Build: I've never done bodywork...but I can change if I have to! (bagged '67 SWB
Just caught up on your build. I admire the fact that you have decided to take on the paint and bodywork yourself. Everything looks awesome, great job.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-04-2013, 10:08 AM   #127
jae
Looking good so far. I'm definitely going to be following the rest of your build.
jae is offline   Reply With Quote
Old 04-04-2013, 10:44 AM   #128
BossHogg69
motor exploder
BossHogg69's Avatar
What part number was that parking brake cable kit?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-04-2013, 11:02 AM   #129
BLUIDVL
BLUIDVL's Avatar
Originally Posted by smoknbarrels View Post
Thanks!
Never heard of evercoat s s, what is it?
My biggest problem is welding my body panels, even using .023 wire on the lowest heat setting, doing a few spots at a time far apart, still warps like crazy!? Its frustrating me like unreal. I tell ya, if a real bodyman seen what i did to perfectly new bedsides, he'd have a few sighs..
Instead of me writing out all this, here is a link to the tech sheets
I use this product after i have my bodywork dialed in.
http://evercoat.com/imgs/pis/SLICKSANDPIS.pdf
I would also recommend using a epoxy primer on all your metalwork or bare metal spots before you apply any fillers.
As for fillers i like to use a skim coat of evercoat everglass over all my metalwork areas. Lets say you have a pinhole you missed welding up the everglass will resist moisture where bondo or filler will absorb the moisture.
After you layed down a skim coat of everglass and sanded it, you can use your choice of fillers. I perfer rage gold or extreme body filler(nice stuff to sand).
In no way am i telling you how to do your build but offering some advise that i have used for many times and had great results.
BLUIDVL is offline   Reply With Quote
Old 04-04-2013, 02:37 PM   #130
canadian sledneck
WOW that stuff seems to good to be true, I must try it out. Thanks for the info
canadian sledneck is offline   Reply With Quote
Old 04-04-2013, 06:00 PM   #131
BLUIDVL
BLUIDVL's Avatar
One major thing i have forgotten to say is if you end up using Slick Sand make sure the shop or paint store you buy it from puts it on the paint shaker for a min. of 10min.
If they tell you they shake it up before it goes on the shelf, INSIST they shake it again.
Another thing is to spray it through a gun with a 2.0 tip or larger.
Old 04-04-2013, 09:11 PM   #132
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Thanks, it is quite the learning process!
cool, thanks.
Originally Posted by BossHogg69 View Post
What part number was that playing brake cable kit?
the Wilwood prake brake cable or the or the inline tube pedal to intermediate cable?
I assume wilwood, they only have one park brake cable kit, its a universal fit, that only works with their disc/drum combo units.
...I would also recommend using a epoxy primer on all your metalwork or bare metal spots before you apply any fillers.
yea, I do use an etching primer on parts I sand right to bare metal. then start using primers after I do filler jobs, once I learned how to block things out properly i got better results. I welcome experience and advice! Thanks.
smoknbarrels is offline   Reply With Quote
Old 04-12-2013, 12:49 AM   #133
smoknbarrels
Registered Mail
well things are progressing... finally finished destroying my nice new bedsides, used a stud puller to bring it back a bit then filler'd her up! just need to do a few touch ups and fill a few bubble pockets, then scuff it up and start the paint process on them.
got sensors mounted up for the e-level up front, had to mount them a bit lower so it would clear the shocks which i relocated, so i just welded on a plate to the bracket I had already made for the shocks.
and here is the cab right in the middle of being wet sanded, what a long process, i really don't care for the orange peel look though, so I hit the clear with 800 then again with 2000. hopefully I can find materials I need to buffer it tomorrow, then I can put the cab on the frame for good!!!
Old 04-12-2013, 08:07 AM   #134
67cheby
67cheby
67cheby's Avatar
Looking good !
67cheby is offline   Reply With Quote
Old 04-13-2013, 10:13 AM   #135
Bomp
Bomp's Avatar
Good steady progress.
Bomp is offline   Reply With Quote
Old 04-13-2013, 02:32 PM   #136
smoknbarrels
Registered Mail
Originally Posted by 67cheby View Post
Looking good !
Thanks!!
thanks! hows the recovery going?
here are some shots after the wetsand of the clear coat. I am new to this so i didn't want to go too aggressive, resulting in a little wave here and there.. but wayy better then before! I was doing some reading on the internet (which was a bad thing this time) read some info and started the wetsand with 800, well that turned out to be much to aggressive for what I wanted, and now I have little micro scratches and I'm a bit too affraid to keep hitting it with 2000 to remove them and end up sanding off the clear is some areas.
I buffed it and polished, came out good, minus the micro scratches and the odd spot where the stupid 8" knuckle buster caught the drip rail for a split second and burnt the paint off right to the primer!
I dunno how I will buff the interior? I tried by hand, seems completely ineffective...
Size:  85.2 KB Name:  PICT0065.jpg
Size:  46.2 KB Name:  PICT0062.jpg
Old 04-13-2013, 04:33 PM   #137
YBNORML
YBNORML's Avatar
Looks great!! You'll be driving long before I will
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-13-2013, 08:13 PM   #138
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
that looks great! Did you mention the color and I missed? Just went thru but couldn't find where you mention it?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-13-2013, 09:02 PM   #139
BLUIDVL
BLUIDVL's Avatar
Looking good smoknbarrels.
Some advice on wet & polish....
Start with 800 grit to cut your down your orangepeel like you did.
Then hit it with 1000 grit
Then 1500 grit
Then 2000 grit & if you havent gone insane by then
Hit it with 2500 grit. You really dont have to go to this extreme using 2500 grit but makes it nicer to polish out.
One thing i noticed on your cab you wet sanded is the you sanded right to the edge.
That is not recomended, reason being it is so easy to burn through on a edge polishing.
This will open a whole new can of worms for you & not in a good way....
I like to stay a min of a 1/2" from all edges on a wet/polish. I also tape around all my edges to be safe.
Another little tip is to add a drop of dish soap in you bucket & spray bottle when your wet sanding. Makes sanding a little easier.
Also do not wet sand with out a block, never just use your hand. You will end up seeing grooves created by your hand.
Hope this helps.
How many coats of clear did you lay down?
What brand are you using of clear?
What size tip & air pressure are you using?
Old 04-13-2013, 09:13 PM   #140
Hardesty454
Hardesty454's Avatar
Looks great! Trial by error is the best way to learn. I'll follow along for this build.
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 04-13-2013, 09:21 PM   #141
PHAT TONY
PHAT TONY's Avatar
Probably,.......he may never let you drive it at all!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 04-13-2013, 09:23 PM   #142
PHAT TONY
PHAT TONY's Avatar
I don't know how many coats of clear you put on, if it's less than 4 or 5 go easy....
1972 K10 4X4-Sold
Old 04-13-2013, 10:23 PM   #143
YBNORML
YBNORML's Avatar
Nice!
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 04-14-2013, 10:01 AM   #144
smoknbarrels
Registered Mail
Its funny, i have most of the winter to work on it, but like last year i dont get much done during the winter, but push hard the last few weeks of spring, starting to not look like its gonna be rolling this summer..
The colour is Galaxy Blue from Alsa, not an easy paint for a beginner.
Then 1500 grit
Hope this helps.
You have some really good points! What I did was sand with 800, then 1200, then 2000, but i guess i didnt sand enough with the 2000 (must have been getting tired) and i got some micro scratches left behind from the other papers. I sprayed 3 coats of clear, so i am a little nervous of sanding too much. I didn't know you can spray up to 5 coats! Sounds like a lot of product!
I used a 1.5 tip for my base ( think i'm going to 1.3 next time) and used 1.3 for my clear. Clear is a proform product or plus1 or something like that. Running my pressure a little over 20psi at the gun.
Wish i would have though of taping off drip rail and a few other spots, as i did do a bit of damage, i guess i will just have to use some nail polish and do a few touch ups.
I definitely am learning! Thanks.
Yea, 3 coats exterior, and 2 interior. I am thinking i should not have wetsanded the interior at all, its impossible to buff that area on the dash, i need to buy some sort of small head for a drill or something.
Old 04-16-2013, 12:35 AM   #145
smoknbarrels
Registered Mail
Another forum member was nice enough to give us an idea of what the build should end up like.
Old 04-16-2013, 11:06 AM   #146
sduckworth13
sduckworth13's Avatar
That is a super nice color, your doing great job. It'll all be worth the effort when your done.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-16-2013, 11:57 AM   #147
Bomp
Bomp's Avatar
Your buildin a show winner there.
foot recovery is going good thanks for asking.
Old 04-17-2013, 01:16 AM   #148
smoknbarrels
Registered Mail
yea, I actually really like it the more i look at it, thanks.
Your buildin a show winner there...
I don't think it gonna be a show winner, but I am trying to the best of my skills.... and patience! thanks!
gonna stay up late tonight, or into the early hours and get my paint and clear done on the doors, and perhaps hang them the next day or two! I am just waiting for my primer to dry so I can hit it with some 320.
Old 04-17-2013, 04:14 PM   #149
smoknbarrels
Registered Mail
well I didn't spray the colour last night, takes a while sanding the primer down.
but here it is!! finally have the doors done today, so I will be looking forward to hanging them in the next day or two, wanna make sure I don't get finger prints in the clear coat when handling them.
thought it would be fun to spray my brake reservoir, so I disassembled it and shot the casting.
Old 04-17-2013, 04:18 PM   #150
VA72C10
VA72C10
VA72C10's Avatar
looking good!
