3 in lowering block for coil springs rear
looking for a nice 3 in block for coil spring rears
like those aluminium 2 in versions , already have 2 by 3 box block but im putting it back togeather for the last time and want sumthing nicer looking does anyone make them? Posted via Mobile Device
///Relaxed Atmosphere |
Happy to be here
![]() Join Date: Mar 2000
Re: 3 in lowering block for coil springs rear
I don't know if any one makes a 3" block. You need to consider that might create scrubline issues in the event of tire failure. If your running a 15" rim it is not advised to go more than a 2" block.
not worried about scrub line on a bagged and body dropped
truck and ive already have 3 in blocks and have 15 steelies without any issues and i have 22s too just looking for a nicer set of blocks as stated before , can anyone make a nice set ? Posted via Mobile Device
Take your 2" bock to a CNC shop & ask them to duplicate in a 3" version. Might need to adjust the top angle to keep the pinion angle good though. I used to be a CNC machinist & that wouldn't be hard to do at all.
2001 ![]() |
good idea , ive already put a email into taylor at mmw to see , ive set the angle with a 3 in block installed so i just need a block , i can make a nicer block out of steel but i kinda wanted a billet one lol
#6 | |
My truck had 3" blocks in the rear when I bought it. Had 15" wheels too. Got a flat one time, and just barely didn't drag the bottom of the u-bolts along the road. I got rid of all that and did proper drop spring. Still have the blocks though if anyone wants em.
![]() Join Date: Jan 2011
He should be OK with the 22" rims but that much block may look kinda funny from behind, just my opinion.
if u drive a bagged truck high enough to see the blocks u dont
need the bags , and really are 3 in blocks so much worse than 2 in ones ? i only have the 15s as extra rollers Posted via Mobile Device
my bad
#11 | |
Happy to be here
If you want assistance and information we are glad to offer it. You can check the attitude at the door.
#12 | |
![]() Join Date: May 2010
Hell yeah!!!
Try summit racing, bought some 3 and 4" from there before.
Stock is good but custom is the sh*t! |
summit doesnt sell them for coil spring/trailing arm trucks only leaf spring trucks but thanks for the suggestion
#15 |
$30 shipped for the pair of 3" blocks I just pulled out. They're not pretty but they're strong.
