11-19-2003, 03:56 AM | #1 |
do i have a bad brake booster?
i've noticed a few things with my 91 K1500 lately. the brakes seem to be grabbing evenly, and it doesnt pull either direction when they are applied. i am however experiencing a low pedal. today, i applied the brakes (while it was raining) and the pedal pulsated pretty violently as it went towards the floor. it stopped just fine, but made a hideous noise along with the pulsation. i've also noticed that if i step on the brake pedal before i start the engine i hear what appears to be some sort of a vac leak. if i dont step on the pedal before i start the engine its fine. anybody got any ideas what my problem may be? i'm all sorts of confuzzled here.
11-19-2003, 11:28 AM | #2 |
Watch out for your cornhole !
Pulsating pedal is usually warper front rotors.
Hideous noise? Where is it coming from? The deal with the pedal hissing before start up is normal.
11-19-2003, 01:45 PM | #3 | ||
Try spinnin 4 rear tars
Re: do i have a bad brake booster?
Under light braking, if you still feel pulsating or a wobble through your steering wheel, your rotors are warped and you need to get them 'turned'. Quote:
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
11-19-2003, 03:29 PM | #4 |
www.loweredd.com
wouldnt a bad booster be super hard to push though, indicating a leak? (it would be like manual brakes, or worse?)
11-19-2003, 08:52 PM | #5 |
i'm well aware of the ABS pulsation, and this was significantly more violent than that. the noise was more of a creaking noise than anything, and followed the pulsation of the pedal. it sounded as if it were coming from the pedal area, under the dash. i tried to recreate the circumstances in a parking lot, and it wouldnt do it again. my 82 did this to me one time too. just went away and didnt have any ill effects after that. on a note with the warped rotors, if that's what was causing this, i would feel it all the time. it only made the noise/vibration one time. everything else feels good except the low pedal.
11-20-2003, 02:08 AM | #6 |
Try driving on the same part of road again..... Maybe it was rippled in one area and when you hit the brakes, your tires kinda skipped across the road. Just a thought
11-20-2003, 03:49 AM | #7 |
i'll have to try that.
