05-09-2013, 04:06 PM | #326 |
Re: LS swappers, post up your pics!!
05-09-2013, 07:53 PM | #327 |
heres mine 1971 c-10 with 4.8 and 460le
05-10-2013, 07:01 AM | #328 |
Always thought about a 71-72 longbed 2wd with a small lowering kit, and the same setup for a DD style truck. Nothing fancy, but still able to pull 20+ mpg and look cool doing it
05-13-2013, 09:24 AM | #329 |
Here is my 81 stepside with a 5.3L/4l60e from a 2000 silverado. I just ran the second tank through it and am getting 16.6 mpg mixed driving with 3.42's in the rearend.
05-13-2013, 09:25 AM | #330 |
05-13-2013, 10:06 AM | #331 |
05-13-2013, 10:15 AM | #332 | |
05-13-2013, 02:39 PM | #333 |
Second Chance Program
Your going to need to post a thread for your dash swap.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
05-13-2013, 06:47 PM | #334 |
05-13-2013, 09:58 PM | #335 |
GM ONLY BABY!!!
How are you figuring gas mileage? Just by refueling till full, or the computer somehow? Nice swap!! Dash looks sweet!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
05-14-2013, 08:50 AM | #336 | |
Thanks for all the compliments on the dash everyone. I did the swap after seeing it in Street trucks a while back and because I was tired of the factory dashes cracking. Here is a build thread I started: http://67-72chevytrucks.com/vboard/s...d.php?t=579031 Sorry, but I forget to take pictures until after I do something so there are very little pictures of me installing the dash. I may be able to take some more if anyone wants to see something in particular. |
05-19-2013, 07:30 PM | #337 |
Build thread is in my signature.
Here is the latest on my 72 C10 http://youtu.be/MIEkT-fKsOo Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual Last edited by 502ms; 05-19-2013 at 07:44 PM. |
05-19-2013, 07:32 PM | #338 |
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
06-09-2013, 05:43 PM | #339 |
83 chevy shortbed with 6 inch and a 03 6.0 swap with a 4l60e trans.
Dan G Lift it, fat chicks cant jump! 83 Chevy shortbed 4x4: 6.0 ls powered 97 Chevy 3/4 ton ex cab 454: work horse 00 Chevy camaro: daily driver 83 Chevy 3/4 ton: dads old rig |
06-10-2013, 09:03 AM | #340 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
06-21-2013, 07:31 PM | #341 |
06-22-2013, 01:37 AM | #342 |
07-21-2013, 09:27 AM | #343 |
Here's my 71' with a 2003 5.3/4L60. Still lots of little things left, but it's drive able...
-Sean 1971 C10 - 5.3 LM7 + 4L60E |
08-04-2013, 11:46 PM | #344 |
08-25-2013, 09:33 PM | #345 |
Finally got mine to run. There is still more to do. Here is video of it running. I cant believe how great it sounds (minus the knock), I also cant believe how much air the LSXRT and CAI suck in.
https://www.youtube.com/watch?v=qTmL...e_gdata_player
Check out my build: 1972 LQ4 Swap http://67-72chevytrucks.com/vboard/s...=1#post5427693 |
10-01-2013, 04:35 PM | #346 |
I am about to start me conversion with a 5.3/ 4l60 in my 67 C20 and I have looked and examined all the pics of this thread and have seen several trucks running the factory a/c compressor in factory location however I was told today that the factory compressor will not work properly on the old systems due to how they work and the expansion valve on the old systems. I was told that in hot areas like Texas when its 100+ that the cold air will surge in and out due to the pressure building up on the expansion valve. He said they work fine in areas where it doesn't get real hot and that they will also not work well unless the vehicle is moving and engine is turning higher RPM's. Can anyone shed some light on this.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
10-04-2013, 01:11 AM | #347 |
Active Member
A lot of people get rid of the original expansion valve and install a 1988-1998 evaporator coil and accumulator set up instead. It seems to work better that way. If you want originality, that is not an option. My truck has that set up, it works fine.
10-26-2013, 12:04 AM | #348 |
Cant wait to put mine in...got a 5.3 out of a 99 silverado...all i gotta do now is gather up all the parts for the swap and i still gotta to find a transmission
11-19-2013, 08:56 PM | #349 |
beautiful motor
ScoobyDoobyDoo |
11-19-2013, 09:05 PM | #350 |
A little further along.......
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
