Old 06-01-2013, 03:45 PM   #1
dirt_migirt
Front brakes locked up
I just put new calipers and pads on my truck blead the brakes and went to move it and the front brakes are locked up and won't let the wheels spin so I cracked the bleeder and they released I re blead the brakes and it keeps doing it. It is a 77 c10 with manual brakes the guy before put a 80 an up master cylender on it cod that be the problem???
dirt_migirt is offline   Reply With Quote
Old 06-01-2013, 04:05 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Front brakes locked up
Front hoses might be NFG.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 06-01-2013, 09:15 PM   #3
DetroitIron
DetroitIron's Avatar
Yep!
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 06-01-2013, 09:21 PM   #4
mgchevyparts
mgchevyparts's Avatar
Probably not hose(s) if both sides do it. Something is keeping pressure to the calipers. Did you make any changes/adjustments to the master?
mgchevyparts is offline   Reply With Quote
Old 06-01-2013, 10:41 PM   #5
Rufton
+1 everybody and mgchevy; unlikely both hoses would collapse into a check valve at same time.
Could be faulty residual pressure valve(s) or sticking MC piston if not the mentioned hose.
Rufton is offline   Reply With Quote
Old 06-01-2013, 10:58 PM   #6
meatwagon83
meatwagon83's Avatar
check the prop valve, its rare but i have seen two bad brake hoses before
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 06-02-2013, 06:18 AM   #7
wraprail
wraprail's Avatar
Brake hoses? Doubtful
@dirt.....What is the pedal like? Hard? Spongy? Does it travel much?
What about when you bleed them?
Did you bleed the rears too?
If not you should do them in order.
We have to assume the calipers have been rebuilt properly and are in good condition.
Make sure you have the correct pads and caliper hardware.
You should put some white grease on the O rings where the calipers slide and on the spindle where the caliper contacts.
Just some tips. I can't see it being hung up like that due to lack of lube.
I would agree with meat that possibly the metering valve inside the combo valve is stuck. There is a button that you pull to aid in bleeding. Try messing with that button or maybe smacking the valve with a hammer a few times.
There is no residual pressure valve on the front brakes. (there should not be)
Brake hoses don't magically cause brakes to lock up. OK maybe it is possible but I still think it is highly unlikely.
That's about all I can think of.
Last edited by wraprail; 06-02-2013 at 10:18 AM. Reason: Removed foot from mouth..
wraprail is offline   Reply With Quote
Old 06-02-2013, 07:24 AM   #8
ont_guy_38
ont_guy_38's Avatar
It's actually very common for the brake hoses to cause the calipers to stick, They swell on the inside and won't let the fluid back through. Not thinking though, prob not both at once.
1985 C10
2004 Avalanche
Old 06-02-2013, 07:40 AM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
how hard was it to get the calipers on the rotor?
maybe you have 1" calipers on 1.25" thick rotors
measure the thickness of your rotors then post the part number of the calipers you bought.
(this is just a wild guess lol)
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-02-2013, 09:34 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
when you bled the rears did you remove the drum and clean?
or just bleed from the outside?
i'd check and ajust the rears
seized up ajusters ....no rear brakes coming on?
does your ebrake work?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-02-2013, 09:42 AM   #11
Rufton
Originally Posted by wraprail View Post
Brake hoses? Thats a good one. lol
How the hell could faulty brake hoses cause the calipers to stick?
They can't.
Brake hoses don't magically cause brakes to lock up. That's Ridiculous
Tis possible for old hose to act like check valve; ID may be restricted and interior may develop debris and barbs from disintegrating hose.
We don't have to assume calipers were built proper.
I didn't say residual pressure valve was supposed to be installed; My point is to check if defective residual pressure valve is installed.
Not so Ridiculous.
Old 06-02-2013, 09:59 AM   #12
cmyc5575
I had an issue not so much with hoses collapsing but the fitting that goes threw the frame from the metal break line to the hose, was rusted and was preventing fluid from going threw it. But most lily not your problems since it sounds like they locked up at the same time.
cmyc5575 is offline   Reply With Quote
Old 06-02-2013, 10:19 AM   #13
wraprail
wraprail's Avatar
Not so Ridiculous.
I stand corrected...
Old 06-02-2013, 06:58 PM   #14
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Check the free play on the master cylinder pushrod. Not enough will make the brakes lock up. Pump them until they lock up, then loosen the two mounting bolts on the master, if the brakes release, you do not have enough free play. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 06-02-2013, 07:21 PM   #15
88Jimmy4x4
88Jimmy4x4's Avatar
how did the brakes work before you touched them?
1991 GMC Jimmy 4x4
Old 06-02-2013, 07:47 PM   #16
dirt_migirt
they didn't work at all when I bought it all I have done is replace the calipers and his is where I am now
Old 06-03-2013, 12:07 AM   #17
Pork Chop
I had an 85 that sat for years and the clips that hold the brake lines to the frame were rusted enough to close off the brake lines. Don't know if that would cause them to lock up
Pork Chop is offline   Reply With Quote
Old 06-03-2013, 12:36 AM   #18
Smallz72project
Smallz72project's Avatar
If this were to come into my shop this is what I would do. So we know that when its locked up and you open the bleeder valve at the caliper that it will release. Need to find the component that is holding pressure. Move up and crack loose the line into the hose, does/doesnt it release, from there to the proportioning valve then to the master and any other components inline. If you open something and it releases continue up, when you find something open and not allowing it to release the bad component is the last component before where you just opened the system. If you get to the mastercylinder and nothing changes...we have to assume that you got bad calipers.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 08-12-2018, 05:48 PM   #19
nascarmikeb
On my 87 sierra classic, the driver side is stuck. I switched the caliper and a new brake hose. I have the correct pads and rotor. The truck sat undriven for 3 years. None of the other brakes are locked up. I will try the above method in hopes of finding the component that is not allowing brake pressure to release. The fluid in the master cylinder is murky brown. Im not sure what that is about. Also what is the "correct procedure to bleed all 4 brakes. I have drums in the rear and discs up front.
Mike
nascarmikeb is offline   Reply With Quote
Old 08-15-2018, 11:55 PM   #20
74CustomK20
74CustomK20's Avatar
My 98 (newer but same issue) had this. My master cylinder went bad n wouldn't release. Went through 2 hoses n 2 calipers before I found out.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
