06-03-2013, 09:39 AM | #1 |
Air bag operation
I've got this Blazer (2wd) that already had air bag suspension installed. I'm old and air bags just ain't me. I took out the front ones. Went back to springs. I'm gonna keep the back ones so I can tow. I currently have the original set up - - 2 air compressors, air tank, etc. I'm wondering if I could/should remove all the above (poor installation and take up a lot of space) and just use a schrader valve to air up the rear bags. Anyone been there, done that?
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
06-03-2013, 11:43 AM | #2 | |
Kill Bill...et
Re: Air bag operation
06-03-2013, 10:58 PM | #3 |
Hollywood
You could possibly "recycle" the 2 pumps and tank.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help.
1968 cSSt shortbed 1971 custom deluxe shortbed frame off 1991 caddilac escalade ST shortbed 1992 chevy ext. cab Project: leftovers 2003 Silverado ext. cab shortbed (my dad's truck R.I.P.) 1969 trans am clone, pro tour 1985 Yamaha Vmax, custom 1993 Yamaha Vmax, showbike 1969 Sears Suburban SS12 lawn tractor Last edited by 70cst; 06-05-2013 at 03:16 AM. |
06-05-2013, 02:15 AM | #4 |
You could do that if it was me i would find a small tank and compressor which is easier to hide.
06-05-2013, 08:10 AM | #5 |
I have the rear bags only also, for towing. I have two schrader valves at the rear license plate.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-06-2013, 09:02 AM | #6 |
I'm assuming by your comments that 2 valves are better than one. I had in mind to tee the lines to one valve. Not a good idea? Thanx for tha comments.
06-06-2013, 09:27 AM | #7 |
T'd airlines allow shift of air pressure from side to side when there's leaning (in a corner) thus making the issue even worse. 2 valves (or separate airlines w/schraders) isolate each bag independently.
06-07-2013, 10:07 AM | #8 |
Thanx SCOTI. As usual, I wasn't thinkin ahead. Sounds like a plan.
