#7301 |
![]() ![]() Join Date: Jul 2002
Re: What did you do to your truck today!
That looks good Josh!
#7302 |
Fun Stuff
![]() Join Date: Jan 2010
I guess you haven't been to Western Washington. They get pretty big around here.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
#7303 |
![]() Join Date: Apr 2013
Replaced the cab mounts on my '67 GMC all by my lonesome. The front bolts weren't tack welded fortunately - using a wrench inside a pipe for the head and a torque wrench on the nut I was able to torque 'em down to spec!
#7304 |
Went outside , started it up. talked to it for 5 mins.
I love my 58 chevy apache. is that wrong ? |
#7305 |
#7306 |
![]() Join Date: Dec 2012
I finished my under hood wiring cleanup project. It included running the wires properly through new firewall and radiator cable channels. Also any and all erroneous wire performing no function that was installed by the PO was removed. All wires exposed were wrapped in black wire tape. I also reattached the cowl after installing a more period correct antenna, trash guards and a new hood to cowl seal. On the engine I replaced the painted water neck with a nice polished aluminum version to tie into my aluminum covers and cleaner. During the wiring project I broke a front side marker lens so I replaced them all new on all four corners.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#7307 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Took the blazer camping at the coast this weekend...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#7308 |
go cyclones
Good weekend. Got the shifter lined up so P means park and D means go. Lubed the column so the shifter works again. Got the glovebox door back on. Installed return/return fuel line so it doesn't slosh out every time i go around a corner. Cleaned it up a bit. Ordered a overdrive shift indicator along with the anti-rattle bushing. Was able to drive it for a bit.
Posted via Mobile Device |
#7309 |
Went for a 1.5 hour drive with my wife in the mountains. First long drive after having the sm465 rebuilt, shifts great. It sure is nice not having to short shift into 4th gear at 20mph because 3rd gear sounded like a air raid siren!
#7310 |
RAT1968 '68 Cab/'71 Parts
i'm definitely sick. I have been a stupid wreck since I dropped RAT off with Painter Lee on Wed.
Really lame of me. But, I guess after rolling around under, over, and in her for four years, I gotta have some pain in letting her out of my sight. Let alone, the drag of being unable to drive her now that (most of) the bugs have been squashed. Lee's a great guy and excellent body/paint artist. I promised him I wouldn't bother him so he didn't have to deal with me hanging out interrupting him all the time. And, I won't...I just have to keep telling myself, "Remember your promise, promise, promise....". ![]() Today, I was shaking enough ( ![]() I got sick of that and figured that since I'd been asked a bunch of times about RAT's stance (I appreciate the questions), I'd make a little slide show with captions to point out what RAT is running next to the ground. Here it is: http://tinyurl.com/jvpea2b
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 06-30-2013 at 10:45 PM. |
#7311 |
Extended the wheel tub width and height.
![]() ![]() Posted via Mobile Device http://67-72chevytrucks.com/vboard/s...d.php?t=532127
Rincon |
#7312 |
PROJECT 7DEUCE
#7313 |
Removed grill and surround. Removed, cleaned and painted surround supports.
Cleaned and painted rad support. Bought new lights and grommets for the new to me 10' flat bed. Started to install new hdw on new grill and surround. 4 day weekend coming up and hope to get new grills and bumper installed, then blast and paint the flatbed.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
#7314 |
Rear Bilstiens installed. Much better. Removed, cleaned and painted tail light housings.
Figure out what you want--then figure out what you are willing to give up to get it. |
#7315 |
What was the part number on the Bilsteins?
1967 ![]() |
#7316 |
24-002486 is what's on the boxes.
#7317 |
67cheby
![]() Join Date: Sep 2008
did a little sheet metal work on the notch cover
#7318 |
ran 3/8 copper lines for the rear bags, and made a new bridge with chromally.
front bags will be next weekend ![]()
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#7319 |
Just ordered the fronts from O'Reilly part # Bil 24-192941.
#7320 |
Junior Member
![]() Join Date: Aug 2010
pulled the tranny back out
#7321 |
#7322 |
Converted the old points system to HEI on my dads 72 cheyenne and got my 70 back when I dropped his off.
Posted via Mobile Device Posted via Mobile Device
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
#7323 |
Be aware that Bilstein has HD #'s and those are the ones you'll be wanting .
The Sock Warehouse is so far , the best place to get them price wise , always in stock too . Plus , they're connected to an outfit that sells brake shoes super cheaply , no core charge , riveted typ if you want .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#7324 |
WOW! Looks like rincones and 67cheby did some positive work on their beds/wells. I went the other way, didn't want to replace the bed floor and wheel wells so I figured it would be much more fun to do a spray on bedliner instead. Don't want to fix the dents? Cover them up!
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
#7325 | |
