Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-25-2013, 10:03 PM   #1
i heart square bodys
i heart square bodys's Avatar
getting doors straight
i have some doors with some major warping and need to know how to get them looking straight , i have a board sander and lots of bondo, just not quite sure the proper technique to use it , it seems like i sand and i sand an alot of the body filler comes off (not all of it though of coarse) and its still wavy , someone help !
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 06-25-2013, 10:22 PM   #2
cableguy0
Re: getting doors straight
The kind of filler your using makes a huge difference. Do you have pictures of what your working with it will be a lot easier to help you.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-26-2013, 01:06 PM   #3
Cape Codder
Cape Codder's Avatar
Keep in mind when block sanding if you use to much pressure on the panel you push it in a little while sanding so when you stop it will come back out causing a high spot in the center. Light pressure cross hatch pattern and let the sandpaper do the work not your arm.
Cape Codder is offline   Reply With Quote
Old 06-26-2013, 10:05 PM   #4
MP&C
MP&C's Avatar
What caused the "major warping", where is it located on the door, do you have pictures?
Robert
MP&C is offline   Reply With Quote
Old 06-27-2013, 11:38 AM   #5
problazer
How bad are they warped? Back filling them with filler is not always the best idea. To much filler and you open a whole new can of issues.
problazer is offline   Reply With Quote
Old 07-27-2013, 08:14 AM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: getting doors straight
Might be better off getting full door skins at least you can treat the rust on the inside of the door
While it's apart plus you'll get arrow straight lines.just my opinion
Ben Smith
snipescastle2 is offline   Reply With Quote
bodywork, c10, doors, squarebody
