Old 08-04-2013, 01:49 PM   #101
naphtali5725
naphtali5725's Avatar
Re: 87' 4x4
nice build thread... good job, truck looks great!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 08-04-2013, 09:53 PM   #102
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Thanks Naphtali!
Thanks for that part number MTCK. I'm going to start looking for one. Do you keep a spare tire under the bed? I was wondering if that still fits.
Greenlee is offline   Reply With Quote
Old 08-04-2013, 09:56 PM   #103
77ChevySharkBite
77ChevySharkBite's Avatar
Re: 87' 4x4
Hey buddy!! Truck looks sharp!!
I wanna see some pictures of the refreshed interior
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 08-04-2013, 10:13 PM   #104
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Thanks! I will get some pictures. I redid the headliner this weekend with some fabric from Hancock's. I'm not sure how long it will last. It had a crumbling fiber glass headliner board and it was hard to get the fabric to stick. If it comes loose I will break down and get one from LMC.
Old 08-04-2013, 10:47 PM   #105
MTCK
MTCK's Avatar
Re: 87' 4x4
I'm not sure if a spare tire would fit or not. My exhaust already prevents me from using the factory spot (and the mount is long gone, and the tires are too big). I bet you could still get a 29 or 30 inch tire under there depending on which type of mechanism it has. I'll take some measurements next time I am under the truck.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-05-2013, 09:53 PM   #106
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Here is where I'm going with the interior. The door panels and trim were maroon. I repainted them with SEM Firethorn Red. The wood trim came from a Anaheim Suburban between the door panel and carpet insert at the bottom. I cut it shorter, re-stained it and put it at the top of the door panel.
I got the compass/temp mirror from another member here on the forum. It's still 95 degrees and it was almost night. I need to get air conditioning in this thing! It's too hot to drive it anywhere. I plan to go with Vintage Air when funds allow.
Old 08-25-2013, 11:10 AM   #107
Jwood70
Re: 87' 4x4
this sure is a good looking truck.
2014 single cabF150- Daily. 35s, camper shell and lifted.
1979 Custom Deluxe- project
Jwood70 is offline   Reply With Quote
Old 08-25-2013, 11:20 AM   #108
rs74
rs74's Avatar
Re: 87' 4x4
How did you go about doing this. What all did you do to hook it up. I am wanting to put one in my 85.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 08-25-2013, 01:22 PM   #109
tex_waco_usmc
Project Heaven in my 67!!!
Re: 87' 4x4
Originally Posted by rs74 View Post
how did you go about doing this. What all did you do to hook it up. I am wanting to put one in my 85.
x2
tex_waco_usmc is offline   Reply With Quote
Old 08-25-2013, 08:56 PM   #110
Greenlee
Greenlee's Avatar
Re: 87' 4x4
The mirror was pretty easy. There is a power wire, ground, two wires that go to a remote temperature probe, and finally a wire that goes to the reverse back up lights that turns off auto dimming when you put it in reverse. I don't have the reverse light wire hooked up yet and works fine without it. I mounted the temperature probe to the bottom of the core support behind the bumper. There are instructions here on the forum that I used for the wiring.
Old 08-25-2013, 09:35 PM   #111
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Took the truck to the beach yesterday. Had a great time and it ran good.
On the way home, things took a turn for the worst! Lost 3rd and 4th gear on the 700r4. The fluid smells burnt so I'm pretty sure it's fried. Wasn't even sure if we would make it home. Drove about 25 miles at night in second gear with the hazards on. It was a real bummer.
The transmission has less than a thousand miles since rebuild. However, the truck sat so long in pieces the receipt I have for the rebuild is 8 years old.
Here are some pics from when we were still having fun!
Old 08-25-2013, 11:13 PM   #112
Jwood70
Re: 87' 4x4
That sucks about the trans, but I really like your truck. Hope you can get this issue worked out soon
Old 08-26-2013, 09:08 AM   #113
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 87' 4x4
looks like it was fun at the beach,trucks looks great,hope the tranny dosn't cost too much
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 09-22-2013, 12:51 AM   #114
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Well my 700r4 was definitely fried. Started calling for prices to get it rebuilt and was getting quotes in the neighborhood of $1,800.
A friend of mine had a TH400 mated to a NP208 that came out of K30 military truck that I could have for free. We had no idea if it was good or not. The fluid looked good so I decided what the hell, I might as well try it before spending a bunch of money. Well we dropped it in today and it works and shifts great!
For those who may be wondering: the drive shafts worked with the TH400, diesel torque converter works fine, cooling lines mated up fine, and the gas flex plate bolted up to the diesel converter. These are issues I had questions about before we started.
Also, I got some use out of my front tow hooks.
Old 09-22-2013, 09:32 AM   #115
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: 87' 4x4
What a great build. Love a red step side 4x4!!!!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 09-22-2013, 12:10 PM   #116
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Thanks!
Old 09-22-2013, 03:56 PM   #117
mud.man.rj
mud.man.rj's Avatar
Re: 87' 4x4
Don't see very many stepper 4x4's especially a diesel. Nice truck for sure.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 09-22-2013, 08:05 PM   #118
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Thanks Mudman. It's actually got a TBI 350. I meant the TH400 came from a diesel K30 so I wasn't sure how it would work with the gas motor. I did a lot of reading on the forum and Google and there were some differing opinions on this.
Old 09-22-2013, 08:43 PM   #119
cst 72 blazer
cst 72 blazer's Avatar
Re: 87' 4x4
sweet ride man I like that red with the wood grain looks sharp!and the 89-91 suv front clip sets it off!very nice
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 09-22-2013, 09:30 PM   #120
mud.man.rj
mud.man.rj's Avatar
Re: 87' 4x4
Well Glenlee, either way diesel or not, a nice looking ride for sure. Cruise all day in that.
5.0 4spd std.
7" lift w 35's.
Old 10-02-2013, 08:03 PM   #121
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Not too much new to add, but I did put in a factory clock and a three speed shift indicator since I no longer have overdrive. Also, I copied what others on here have done and put LED's in place of the dash light bulbs. That makes a huge difference! I could barely see the gauges at night before. Here is a pic:
Old 10-04-2013, 01:05 AM   #122
MTCK
MTCK's Avatar
Re: 87' 4x4
Dash lights look great! Doesn't that make a heck of a difference? That's a bummer about your transmission, but great you got up and running again with little $$$ spent. I like the mirror, may have to snag that idea on a future project...
-Marcus
Project Plow Truck
Old 12-16-2013, 11:08 PM   #123
Greenlee
Greenlee's Avatar
Re: 87' 4x4
Santa came by here a little early with a new bezel and dash insert. I also ordered a Vintage Air kit today.
Old 12-16-2013, 11:16 PM   #124
Greenlee
Greenlee's Avatar
Re: 87' 4x4
I have a little tip I wanted to share for loose A/C vents. I put an O-ring on each side and they are nice and smooth now.
Hopefully, I will have some more updates soon!
Old 12-17-2013, 01:25 AM   #125
MTCK
MTCK's Avatar
Re: 87' 4x4
Niiiiiice! I'll be curious to hear how you like the vintage air system. I've been looking at their stuff for potential A/C in my crew cab.
-Marcus
Project Plow Truck
