Closed Thread
Old 08-15-2013, 11:24 AM   #176
Roadkill58
Roadkill58's Avatar
Re: Roadkill's 58 Chevy Stepside
Gotta love a red truck with a louvered hood.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline
Old 08-15-2013, 11:27 AM   #177
Roadkill58
Roadkill58's Avatar
Not quite Ogre yellow, but it is yellow!
Rust Never Sleeps
Old 08-15-2013, 11:53 AM   #178
Roadkill58
Roadkill58's Avatar
Nice 4X4.
Rust Never Sleeps
Old 08-15-2013, 07:22 PM   #179
_Ogre
_Ogre's Avatar
yellow 4 eyed beauty
what's not to like?
shop air compressor timer
_Ogre is offline
Old 08-20-2013, 11:13 AM   #180
Roadkill58
Roadkill58's Avatar
Built a cheap rotisserie out of some engine stands.
I got the idea from Kabwe's build thread.
Need to add some spacers to the top bolts so the chassis sits level.
The yellow engine stand was heavy duty three years ago.
The black engine stand is now the heavy duty.
Don't want to see what heavy duty is three years from now.
Rust Never Sleeps
Old 08-20-2013, 11:23 AM   #181
dubie
dubie's Avatar
nice job on the rotisserie!!! And thanks for the pics from the show. That diesel dually is so bad ass looking!!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline
Old 08-20-2013, 11:31 AM   #182
Roadkill58
Roadkill58's Avatar
Thanks Dubie!
I really like that dually.
There is a 57 tow truck in the neighborhood I've been eyeing for a while.....
Rust Never Sleeps
Old 08-20-2013, 03:11 PM   #183
Kim57
Kim57's Avatar
Wish I had done that for my frame.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline
Old 08-20-2013, 05:28 PM   #184
Roadkill58
Roadkill58's Avatar
Kim
Kim I haven't used it yet and I'm already glad I have it.
I was swapping engine stands around today (had to swap out the heads for rotisserie) and decided to mock up a TPI engine.
Looks like it will fit. I will have to change the starter, or bell housing to make it work.
The mental deficients that pulled this motor did a hack job on the wiring harness
Rust Never Sleeps
Old 08-21-2013, 10:59 AM   #185
Kim57
Kim57's Avatar
Looks like it should fit just fine.
Kim
My build thread
Kim57 is offline
Old 08-21-2013, 01:12 PM   #186
Roadkill58
Roadkill58's Avatar
Kim
There is plenty of clearance all around. The bell housing won't work with the starter (bolts to bottom of block). I have the one that bolts to the bellhousing I can use.
Was going to remove the crossmember now so I won't have to do it later if I decide to go with an automatic trans.
Unfortunately I don't have a computer for this engine, but I do have a new Edelbrock manifold and carb for it.
This motor turns over but I don't know if it runs. Same goes for the blue one.
Rust Never Sleeps
Old 08-21-2013, 06:19 PM   #187
Kabwe
Certified Car Nut
Kabwe's Avatar
They sell them on ebay pretty cheap if you are interested in fuel injection. If not ignore what I said.lol
BTW Nice build.
Kabwe is offline
Old 08-22-2013, 08:35 PM   #188
Roadkill58
Roadkill58's Avatar
BTW Nice build.
Thanks Kabwe!
I should have known ebay would have them.
Rust Never Sleeps
Old 08-22-2013, 08:54 PM   #189
Roadkill58
Roadkill58's Avatar
Kabwe I was reading your build thread and noticed your IFS had lower A-arm support braces.
Did they come with your kit, or did you make them?
Mine didn't come any braces so I made some. I used some thick paper from
Costco dog bone boxes to make a pattern. The the thick paper separators from inside the box. By the way those bones contain doggy heroin. Our dog is addicted to them.
Used some 3/16" plate for the braces. I also made some gussets as well (not shown).
Should be good for a little piece of mind when hauling down the road.
Rust Never Sleeps
Old 08-23-2013, 08:55 PM   #190
Roadkill58
Roadkill58's Avatar
Made some progress on the truck today.
Tack weld lower A-arm support braces in place.
Moved crossmember to correct location. I used my assembly manual
for the correct measurements. If you don't have one of these get one!
Got the chassis on the rotisserie.
Time to get the rest of the dirt and grime off the chassis.
Rust Never Sleeps
Old 08-24-2013, 02:06 AM   #191
Kim57
Kim57's Avatar
Looking good. Love the rotisserie.
Kim
My build thread
Kim57 is offline
Old 08-24-2013, 02:16 AM   #192
Roadkill58
Roadkill58's Avatar
Kim
Thanks Kim.
I haven't tried rotating it yet.
I'm hoping it's a one man operation.
Rust Never Sleeps
Old 08-31-2013, 09:39 PM   #193
Roadkill58
Roadkill58's Avatar
Tried rotating the chassis on the homemade rotisserie. It wasn't easy to do.
I had to get out my biggest pry bar to get it done.
Modified the stands so the head would be level and rotate easier.
Made some adjustable height stands using stuff I have and more stuff from Blue Collar Supply.
Got some 1 1/4" bolts and nuts to make leveling the chassis easier.
With frame sitting level (and higher) I can weld on the chassis without bending over.
Having a rotisserie means no sparks or slag in places you don't want it.
Rust Never Sleeps
Old 09-15-2013, 05:34 AM   #194
Roadkill58
Roadkill58's Avatar
Still cleaning the chassis.
Installed the notch for the rack & pinion steering. Better to do it now even thou I'm not running bags.
Got the rotisserie sorted out now it rotates very eazy.
Ordered a harness and ECU for my TPI engine.
These pics are from the Goodguys in Pleasanton last month.
Rust Never Sleeps
Old 09-15-2013, 11:45 AM   #195
Kim57
Kim57's Avatar
That's a nice looking truck.
Kim
My build thread
Kim57 is offline
Old 09-15-2013, 02:38 PM   #196
Roadkill58
Roadkill58's Avatar
Kim
There are so many cool details on this truck.
The owner is a cool guy also. Answered a lot questions on the build.
Rust Never Sleeps
Old 09-15-2013, 07:59 PM   #197
ZR2RICK
ZR2RICK's Avatar
Great build, any more info on that killer GMC from the GoodGuys show?
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline
Old 09-15-2013, 09:10 PM   #198
Roadkill58
Roadkill58's Avatar
The truck should be in Custom Classic Trucks soon.
Rust Never Sleeps
Old 09-15-2013, 11:02 PM   #199
Roadkill58
Roadkill58's Avatar
The GMC has an LS1 engine.
Rust Never Sleeps
Old 09-17-2013, 10:35 PM   #200
blue57
blue57's Avatar
Thats a really clean truck. I had seen it out at the brothers trucks show. It does have an LS1...... just needs a set of motor covers.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline
Closed Thread
