Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-01-2013, 02:55 PM   #1
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
How to make a 1050 Dom list 8896 streetable
Short story is timing belt broke. Fixed it all up. Decided to changed the intake and carb combo from a pro dominator with dual 750 Holley to a super victor 4500 flange with a 1050 dominator. (The KID in me)
Rite out of the gate the idle circuit is rich and the low speed cruising around town is fat, lazy, and blubbery.
The 1050 is a 3 circuit. I should be able to tune all of that out. The question I have is we're do I start 1st?
The idle curcuit in the metering blocks (jet size)? Followed up with the low speed air bleeds (jet size up to slow things down)? Should I get into the intermediate air bleed for the rich conditions while cruising?
Thanks for any info that will help. I'm trying get this combo tuned up for a 4 day bracket race event in Eagle Idaho called the Halloween classic.
Motor info
408 SBC
11.6 comp
AFR 227 Jessel shaft mounts
Forged rotating ass. 6" rod
Cam lift .666 installed in at 105.8
Trans th 400 w/ t brake
4600 A-1 converter 4:56 gear.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 09-02-2013, 01:00 AM   #2
Super73
Super73's Avatar
Re: How to make a 1050 Dom list 8896 streetable
Wish I could be of help.. My dominator only moves air, not fuel.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-02-2013, 01:06 AM   #3
68 C-10 KID
Mean Green
Thanks Shaun. Maybe one day I will step my program up. Lol
Did the -7 make it to you?
AKA MEAN GREEN.
Old 09-02-2013, 11:23 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
OK, Ive got one Patrick set up for street for me, but it's a bastardized deal. I'm no expert but.. let me ask a few questions
Is the 8896 a soft (progressive) linkage? If not I think you will have nothing but headaches.
Is the primary set up with a power valve?
I'm looking for my holley listing and will be able to tell you what the factory jetting was. That's always a good starting point
edit FOUND IT
Both the 8896 and 8896-1 was jetted square with 88's front and rear.
I think the primary metering block is set up so you can use a power valve in the front. I'd sure try that will let you drop the primary down 8 jet sizes or so and maybe be a bit more streetable.
Hope that helps
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-02-2013, 12:45 PM   #5
Super73
Super73's Avatar
The -7's did get to me.. Not sure what I am going to use them for yet as the motor is spot on with the -8's. I will see how it likes the -9 and -10 this coming Friday
Thanks again!
Old 09-02-2013, 01:20 PM   #6
68 C-10 KID
Mean Green
Thanks Marv. I set the fuel pressure @ 6.5 set the float levels for a trickle. Installed 3.5" power valves & dropped the jetting down to 83's. I think your rite I need to even go farther to maybe a 79's.
I ordered AED blocks for it so I can adjust the idle circuit and some air bleeds. This all scares me. All of my tuning has been the basic stuff jets, PV, squirters, accelerator pumps.
AKA MEAN GREEN.
Old 09-02-2013, 09:10 PM   #7
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
if not answered yet I'd get a hold of prostreetC-10.
He's been known to build a Holley or two and might be able to lend his opinion to this.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-02-2013, 10:35 PM   #8
68 C-10 KID
Mean Green
Thank you. I'll PM him.
AKA MEAN GREEN.
Old 09-02-2013, 11:14 PM   #9
Marv D
Marv D's Avatar
Yeah someone send prostreet a link to this. He's a big block guy,,,,, but I guess he is of some use for something (LOL give him a hard time very chance I get) He definitely needs to chime in here.
Old 09-03-2013, 12:08 PM   #10
C20-67_N_MO
I sent him a PM about this topic.
Old 09-03-2013, 03:31 PM   #11
68 C-10 KID
Mean Green
Thank you very much. I was searching for him on post with no luck.
AKA MEAN GREEN.
Old 09-03-2013, 03:57 PM   #12
C20-67_N_MO
No worries.
I'd like to do this someday as well and want to see if it is feasible.
Old 09-07-2013, 08:41 PM   #13
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Sorry to just be getting to this. It's been a crazy week with the Holiday and trying to get the kids back in school and iron the routine down!
Let me start by saying that just about all of the fun I have had with carbs has been in the 4150/4160 platform. Very little Dominator work though I can possibly offer up some stuff to think about.
As you might guess, you are starting off on an uphill battle. There is a VERY good reason why you don't see Dominators on the street unless they are coming off the trailer and into the car show. I think you would have been much better off getting one of the 4150 style carbs that are just about in that same cfm rating. This is assuming that this is a truck that is at least driven on the street some of the time. The one thing that you will be fighting and really can't change is the horrible low speed velocity running through the venturis due, in part, to the huge 2" throttle bores and big venturis. It's a throttle response killer and will certainly cause it to run rich at idle. They really are an "idle to WOT" carb. Those carbs also have really big IFRs compared to the 4150 carbs. Just what is this Dominator list number? Is it new? Does it have the straight leg boosters or the annular? The much older ones are straight leg and the newer will have the annular. 3 circuits can help a little but there is just that much more to try and dial in. They are great for applications like tractor pullers where you really have to walk into the throttle to achieve WOT but still not designed for the street where you spend so much time at very part throttle. Your stall will certainly help a little. A power valve would be a must to read vacuum drops.
Tell us a little bit more about the carb as far as if new and list number. Also remember that you are at about 2,500 ft in elevation so there is a little less O2 in the air which will add to the fat state. At best it's probably going to buck and snort when trying to use on the street. Tuning on a 3 circuit carb is not for the faint of heart either. Yes it can be done just like anything else but you usually have to part with a bunch of Moolah and have Pro Systems, Braswell, AED...etc work the magic, taking in every last detail of your combo.
When you ordered your AED blocks, did you talk to someone at AED? They are awesome and might have been able to get you much closer to having the blocks setup for your needs as apposed to just buying off the shelf, universal blocks.
prostreetC-10 is offline   Reply With Quote
Old 09-07-2013, 08:51 PM   #14
prostreetC-10
My Carbon Footprint
Sheesh.......I just realized that you had the list number in the thread title!!!
Is it new? Funny how Holley's disclaimer says "drag race only and for top end power".
How did it run with the twin 750's?
Old 09-08-2013, 12:45 PM   #15
stumpy
stumpy's Avatar
That's a whole lot of carb for the street let alone that engine. You shouldn't tune out the intermediate circuit. Why not start with a 750 Dom?
67 C10 LWB Fleet
02 Chevy K1500HD Crew Cab - Stock LQ4 & 4L80E, 3.73's, my DD
08 Impala SS - Wife's DD
96 Impala SS - stock engine with bolt-ons(Wifes race car),
96 Impala SS - 496 BBC race car 9.69 @ 143
stumpy is offline   Reply With Quote
Old 09-08-2013, 01:16 PM   #16
prostreetC-10
My Carbon Footprint
Ah YES.......the 750 Dominator. Even HOLLEY can't explain why that thing was ever created!!! LOL
Old 09-08-2013, 01:23 PM   #17
71Dragtruck
71Dragtruck's Avatar
For looks.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 09-08-2013, 01:39 PM   #18
prostreetC-10
My Carbon Footprint
That was the general reasoning and still not right for the street. They are and will always be like flushing a toilet. Great for the big end but so so around the pits.
Old 09-08-2013, 03:18 PM   #19
71Dragtruck
Been eying these up for my next carb.
http://www.prosystemsracing.com/svseries.html
Sponsored by:
Hard Candy Customs
Old 09-08-2013, 03:29 PM   #20
68 C-10 KID
Mean Green
The 1050 is slightly used. I traded a electric choke quick fuels for it. Ya every thing is race race. Not for street use. Lol. Hell with that I'm going to test that theory.
It ran like a dream. They were so much fun. Streetable, responsive ran clean on the low end. If I can't figure this 1050 out I will slam them back on. I leave for Boise for the Halloween classic in 6 weeks. So I have some tweak time.
When I talked to AED about the blocks and what I was looking to do all he recommend was the blocks. Never gave up any info on any tune ups that will get me close. Correct me if I'm wrong but I just might try and use the same idle and low speed tune up as a 850. In theory sure it will get me close enough for a base tune.
I'm just trying new things to broaden my experience as a racer and wannabe tunner.
AKA MEAN GREEN.
Old 09-08-2013, 03:29 PM   #21
prostreetC-10
My Carbon Footprint
I almost posted about the SV-1 so that's weird that you did. They have a pretty interested list of accomplishments with that carb and yet it still doesn't seem to be really catching on. I guess it had to be done. We already had the 2 barrel, 3 barrel and 4 barrel, not to mention the Predator variable venturi. Probably the epitome of WTO only. Seems like it would be a nightmare to try and run on the street. In all fairness to them, I know little about it and those guys are MANY steps above me in the art of fuel delivery. I know Marv likes them and for good reason.
Old 09-08-2013, 03:33 PM   #22
71Dragtruck
I'm running one of their nitrous 4150's now on my 489, next motor will be a 632 and would like to try on on it when I finally make the upgrade.
Sponsored by:
Hard Candy Customs
Old 09-08-2013, 07:56 PM   #23
68 C-10 KID
Mean Green
These SV-1's look like something I can get into.
AKA MEAN GREEN.
Old 09-08-2013, 08:19 PM   #24
prostreetC-10
My Carbon Footprint
For some reason I read into that this is a street/strip ride. First thing would be to set it back to box stock. Probably won't know IFR without using a drill bit or something else to stick in the hole and then measure with a caliper. Of course this won't matter if you immediately swap out the blocks for the AED ones. Those will probably come with 31-33 IFR's. Also need to check the air bleeds. The idle (farthest outside) should be 53's. The inters are 63 and HAB on the inside are 40's (stock).
I haven't done much with 3 circuits so I am not that familiar with the relation of the 3. Just at first glance, the 53's seem pretty small and the 40's seem pretty big. Most 4150's are in the 70-75 range for idle and the highs are 28-33. Once again that interm circuit might have a big effect on the other 2. Sure is easy to bump those 53's up though to lean out the idle charge but dropping down the IFR size to start with might be a better initial move. I'm thinking out loud so sorry if I'm all over the place.
What part of PDX are you? I grew up in Hillsboro and lived last in the Tigard/Lake Oswego area before moving to Bend.
Old 09-08-2013, 08:33 PM   #25
stumpy
stumpy's Avatar
I don't recall whether or not the 1050 comes with removable IAB's. If yours does, then try removing the middle IAB and see what that does. I had my 1050 Dom rebuilt by Nickerson Performance. It ran great on the track, but part throttle was very rough. At a dyno session the tuner wanted to make ridiculous main jet changes to clean up the low end AFR (it was pig rich). We call Nickerson and they suggested that I remove the intermediate IAB's (they make em all removable) and leave the mains alone. That one change made all the difference. It drives like a dream at part throttle and it improved my 60'. Before that I would not think of street driving it.
67 C10 LWB Fleet
