Old 12-05-2012, 09:38 PM   #101
jonny..2008
Re: '69 c20 rescue kind ..... of.
then when space was open i relocate member and test fit new tank.
ran out fo light for tonight and steam too.
nut a good day for a change.
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline   Reply With Quote
Old 12-11-2012, 12:42 PM   #102
jonny..2008
man i hope those bushings get here today...............
Old 12-11-2012, 01:11 PM   #103
sgaylord
Project collector
sgaylord's Avatar
Nice progress. It's a nasty job. Good luck!
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 12-13-2012, 12:20 PM   #104
jonny..2008
Steve
the work pleases me. i just wish i had more time and less pressure getting it done. borrowed cars suck. borrowing a car for over a month even more suck.
the end is nigh. bushings here today or friday. all pieces for fuel tank on hand. ready to get to work.
Old 12-14-2012, 12:40 PM   #105
jonny..2008
the bushings are finally on the brown truck out for delivery.
finally.
Old 12-17-2012, 05:38 PM   #106
jonny..2008
track bar bushings installed ...... finally.
Old 12-18-2012, 12:04 PM   #107
jonny..2008
monday was a good/bad day here.
i was able to get in to a shop of a real good friend that i was out of touch with.
so i chose to do the tank.
when we work to exhaustion, we make mistakes and rush.
there are some corrections and finishing to do, but the tank is in and filler neck connected.
still have to get an alum fuel door. make a bracket for the top of the neck and a cover for the bed side of the neck.
also still need to connect the filler end of the vent.
then i can connect the tank to pump and see if it was all done right.
Old 12-18-2012, 12:05 PM   #108
jonny..2008
Old 12-18-2012, 12:08 PM   #109
jonny..2008
also cut four and a half feet out of the exhaust. it dumps in front of the rear wheel now.
Old 12-18-2012, 04:08 PM   #110
jonny..2008
Well I just got the truck back from alignment. I think it drives great. But if the other licensed driver doesn't think so, it's going to have to go.
Old 12-24-2012, 09:52 PM   #111
bollybib
bollybib's Avatar
so is it going or staying ???
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 12-24-2012, 11:52 PM   #112
jonny..2008
its still here for now im trying to get her to love it.
Old 12-28-2012, 08:20 PM   #113
jonny..2008
The truck is serving its purpose. Moving house three blocks away. Truck doing good after last Round of updates.
Old 01-06-2013, 05:46 PM   #114
jonny..2008
Load number 70 ish.
Old 01-24-2013, 01:02 PM   #115
jonny..2008
i do have some updates.
mostly i have been moving and just driving the truck to work everyday.
the tank project is moving slowly but one more session should do it.
maybe this weekend.
Old 02-20-2013, 01:07 AM   #116
jonny..2008
im missing the trick to put the vid HERE.
so we get a link instead of me putting the rear drum bakes on with regular old tools. nothing special. also replaced two u joints.
eaton ho 52 with 8 lug drums.
http://youtu.be/raGxEDB-lPc
new master blew a rear wheel cyl. after 800 miles. so truck got new brake shoes and wheel cylinders, a spring kit and new bearing seals.
Old 05-18-2013, 12:00 PM   #117
jonny..2008
truck has been running great.
no real issues to report from the previous work posted here.
solved an issue that had me stuck regarding the starting issue.
p.o. cheaped out on the battery. there was one shot to get the truck started, if it didnt, it was a ten min wait, or jump start.
battery was too small for v8 starter. $80 fixed it.
I have a new 1406 sitting on the self, nothing wrong with the 1406 on the truck but this new one is shiny. also have intake manifold water leak so ill replace the gaskets, clean up manifold, and install new carb.
also ordered a new aluminum radiator ($180 from monster radiator in oregon FREE ship too!). the one in the truck has a few small leaks on the tank sides and im afraid when i seal the manifold it will make enough new pressure to pop the rad the rest of the way. its pretty mild weather here and the temp on the gauge never gets higher than 190' but im mostly concerned with the pressure increase from fixing the other leak.
also looking to replace the power steering pump this round. pics to follow, when work begins. i just wanted to touch base now that i am back in improvement mode.
Old 05-18-2013, 12:02 PM   #118
jonny..2008
Old 07-02-2013, 11:53 AM   #119
jonny..2008
had a weeping radiator and a leaking manifold at the rear (water).
couldnt fix one without making the other worse so.....
also changed the p.s. pump and pully and lines.
cleaned up manifold in the process.
small bonus was i found a mallory billet dist hiding back there!
if everything runs nice this week we will pop the new carb on this weekend.
NOTE: PICS ARE IN REVERSE ORDER. I DONT WANT YOU ALL THINKING I MADE IT WORSE!
Old 07-15-2013, 01:21 AM   #120
jonny..2008
Did upper column bearing.
what a huge difference.
it felt like the new pump was going out.
first vid (18 sec is before with intermediate shaft off.
http://youtu.be/wnIfpohlFRU
second vid is after steering wheel off.
http://youtu.be/zgcOth6qeBA
fixed upper bearing.
http://youtu.be/A5pGUbyRyFI
Old 09-12-2013, 12:21 PM   #121
jonny..2008
Truck is for sale.
1969, 8lug, c20, shade tree, spindle conversion
