1972 chev complete restore
Re: 1972 chev complete restore
Tear down
Posted via Mobile Device |
Gettin down to the end
Off to the sandblasters
Back from the powdercoaters
Start the rebuild we are now one month into the restore
![]() Looks like you are on your way... |
Hood back from powdercoaters
The cab ready to go
Boxsides
Nice work. I did this last year, just shy of five months from tear down to test drive.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Man I love how you guys in USA do these restores on your own and also in a short space of time......nice one guys..
Pegman, small request when posting pictures see if you can rotate them so we don't have to tilt our heads.. ![]()
------------------------------------------------------ ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560 |
#15 |
I am from Canada but I am new to this posting will try to rotate pictures...thanks!
#16 |
#17 |
Starting box assembly
#18 |
Nice work. Have you pick out a color yet?
#19 |
Yup gonna be dark blue
#20 |
Subscribed.
I'm curious if the hood was powder coated will it be painted later too? why not blast and spray epoxy primer or self etching primer or something like that?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#21 |
Yes the whole body was sandblasted then powder coated...just not the cab... Powder coating works much better on pieces like the hood because when it is coated the powder goes into all the corners because of the electrostatic process when you just spray it regularly it will not do that as well
#22 | |
#23 |
There are different types of powder coating material if you see my frame it is shiny and a different type of coating where as the body pieces are a dull finish and are able to be top coated as it acts like a primer as you can see with the hood picture it appears and looks like a brand new part. It is the only way you can get into all the corners unless you dip it into something. Thanks for checking my thread!
#24 |
nice!
1966 GMC ShortStep |
#25 |
Engine done and put back in
