#51 |
Re: 68 c10 6.5 turbo diesel
Here are the update pictures. Back of cab and front of bed painted under bed undercoated. Hard line fuel lines AN fittings 1/2" suction 3/8" return bulkhead through floor. Parking brake cables and guides all new.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
#52 |
Pics of the fuel lines
#53 |
More pics of fuel lines. I have not finished 1/2" line to fuel pump yet will post pics of that set up when done.
#54 |
Got most of the fuel lines done fuel filter housing and lift pump mounted. Got gauge cluster painted and put in a volt gauge got ride of amp gauge. The alt is a 140 amp that would burn the factory shunt wire. I made new wiring harness for the engine and installed a high amp dist block. I made a new front wiring harness also I am still waiting for a fuel sending unit from a 72.
#55 |
More pics it is raining here a lot so some got wet.
#56 |
I have a radical idea!
You are doing a real nice job on that truck!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#57 |
Thanks I appreciate the compliment.
#58 |
Update pics painted inside of fenders. Painted core support and installed cowl panel. I have finished all the corner supports and lower splash panel have all that painted today. I will post pics of that tomarrow I will also be painting the hood.
#59 |
Update I got inside painted top of dash painted right door sill/pillar painted. I got grill and hood painted and installed. New cowl seal and cowl installed all body tightened down and aligned. Fuel lines almost done just need 90 deg AN coupler. I resealed drip rail got all rust out of it also. I need to fix sill on left side and paint it.
#60 |
More pics
#61 |
Some more
#62 |
More update got door seals and tail light lenses. Got AN 90 deg couplers for fuel line fuel line is done. Main bearings are in the mail.
#63 |
started on the motor
#64 |
All inside is painted everything doors, sills, pillars, everything done. Got latches, window regulators, striker plates painted.
#65 |
Love it! I like your pics, keep'em coming. I'm a diesel technician. I like the 6.5's but the one in my 97 4x4 crew dually is sickly. I would like to swap a mechanical pump in but after I factor in the cost of that and everything else, I think I'm going to swap in a 12v instead. I do like your idea of a mechanical 6.5 in your 68. It's different and you will like the fuel mileage.
#66 |
Also what made you want to keep the fuel tank in the cab? Most use a blazer tank under the rear of the bed.
#67 |
To keep it original. Plus I like filling up the tank from sitting inside lol. It easy to swap mech pump on 6.5. The other way is hard. All you need is a 90s pump a 93 is the best if it a 4911. Get pump and lines and that's it hook up one wire and done make sure throttle bracket is on pump.
#68 |
Also thanks for the kind words that is what I'm going for original but different.
#69 |
Motor coming together.
#70 |
More pics all brackets and parts are painted.
#71 |
Engine pics look nice. Coming right along!
#72 |
#73 |
![]() Join Date: Mar 2011
I don't know how I missed this thread, your doing great work keep it up
63 k20 with cummins 4bt, owned sence 1982 |
#74 |
Thanks I don't have much of an update just been painting all the small stuff. When the wind stops I will be putting the back window in.
#75 |
Looking forward to more updates. Great build!!
1986 Chevy Wrangler 4x4 305/700r4 6" lift 37x14.50x15 |
