11-29-2013, 06:36 PM | #26 | |
Re: OCD Blazer
[quote=Tom Vogel;6393934]
It made s10 4 cly look pretty good for a daily driver and that was the gateway drug to boosted imports and lifted cummins |
12-02-2013, 08:02 PM | #27 |
Re: OCD Blazer
Heres a few pics of cutting the windshield frame,I bent some 5/16" rod to the contour of the top so I had a little more to weld to and grind on
12-02-2013, 10:02 PM | #28 |
Re: OCD Blazer
When I first started this project I was going to use 1/2' lines and solenoids left over from my sons s10 project[plus it was free] but a few years ago I saw the accuair setup and had to have it so I took out the old setup and replaced it with there E-level set up with touchpad and keyfob,I used 2 viar compressors and tank I already had
12-03-2013, 10:18 AM | #29 |
2WD Jimmy
Re: OCD Blazer
[QUOTE=I took out the old setup and replaced it with there E-level set up with touchpad and keyfob,I used 2 viar compressors and tank I already had[/QUOTE]
How tough was this to do? AccuAir Hawks the Airpod setup saying youll save 15 hours, Bot Im thinking of buying everything but the tank and making my own so I can hide everything underneath and in the rocker boxes. Airpod justs seems so bulky being in one big peice is all. |
12-03-2013, 11:21 AM | #30 | |
Re: OCD Blazer
One thing I will say is everything I've got from Accuair is of the best quality and most thought out products I've ever bought-(and no I'm not sponsored,just a regular guy in his garage at home) |
12-03-2013, 10:47 PM | #31 |
Re: OCD Blazer
Accuair install pics
12-03-2013, 10:55 PM | #32 |
Re: OCD Blazer
12-03-2013, 11:53 PM | #33 |
Re: OCD Blazer
12-04-2013, 01:16 AM | #34 |
A guy with a truck
Re: OCD Blazer
Super clean work. I like that position for the front sensors- used that spot myself, but went to the upper arm to clear the sway bar. Keep it up- this thing is great!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-04-2013, 01:43 AM | #35 |
Re: OCD Blazer
Nice work!
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
12-04-2013, 08:39 AM | #36 |
Re: OCD Blazer
12-11-2013, 09:58 PM | #37 |
Re: OCD Blazer
Ok heres were a little more OCD kicks in,it always bothered me that I could lay the frame on the ground but the rockers were still a 1-1/4" from touching
12-11-2013, 10:26 PM | #38 |
Re: OCD Blazer
Time for body drop?
12-11-2013, 10:46 PM | #39 |
Re: OCD Blazer
12-11-2013, 11:01 PM | #40 |
Re: OCD Blazer
I helped on one for a Nissan hardbody back in the day. UGH.
12-12-2013, 12:40 AM | #41 |
A guy with a truck
Re: OCD Blazer
Wowsers. Where's the back seat go?
12-12-2013, 08:59 AM | #42 |
Re: OCD Blazer
Its built in, see that hump between his fenderwells
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
12-12-2013, 09:24 AM | #43 |
Re: OCD Blazer
You have to remember I started building this truck over15years ago when pro street was cool so I narrowed the rear end to fit 31.5"x16.5"x15" and I had wheel vintiqes make me some 15"x12"rims with a 10" dish-
Hind sight is 20/20 and I don't like back seat drivers |
12-12-2013, 09:38 AM | #44 |
Re: OCD Blazer
I'm not questioning you. Its your truck, and your vision. But I thought you did it to hide all the suspension. I use to see that quite a bit at shows.
12-12-2013, 10:27 AM | #45 | |
Re: OCD Blazer
I didn't think you were questioning me,I'm joking on myself,over the years it's went so many different directions I'm not sure what I what the thing will end up being,that's just part of dealing with my OCD,ADHD personality I can get really focused on a project and know exactly what I want it to look like and work like a mad man on it then BAM push it in the corner and go just as hard on another project in a different direction then another and another til I come back to the blazer which might be 2 months or 2 years and by then there's a new vision for it so I will spend another month deconstructing it again. It use to bother me but now I've gotten older and understand it better,now it's kind of funny to me,if I could have finished it 15 years ago it would have been cutting edge,but now there's bagged blazers laying frame everywhere. I think this project is my therapy |
12-12-2013, 12:07 PM | #46 |
Re: OCD Blazer
following
12-19-2013, 08:29 PM | #47 |
Re: OCD Blazer
12-19-2013, 09:30 PM | #48 |
Re: OCD Blazer
That was some quick work
12-19-2013, 09:46 PM | #49 |
Re: OCD Blazer
Oh no,it's all bolted together,lined up and tacked but I still have to weld the whole outside perimeter
Still a long way to go But I can finally tuck nuts Last edited by Jimfred; 12-19-2013 at 09:52 PM. |
12-19-2013, 10:51 PM | #50 |
Re: OCD Blazer
Still a lot of work done in 7 days.
