Old 12-01-2013, 08:45 AM   #1
tismy55
Rear Leaf Spring Shackles
Will 73-87 rear leaf spring shackle work on my 72 rear end leaf spring if they are the same width? Thanks for the help
tismy55 is offline   Reply With Quote
Old 12-04-2013, 02:22 PM   #2
tismy55
Re: Rear Leaf Spring Shackles
Can Anyone Help. Thanks
Old 12-04-2013, 02:41 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I believe the 73-87 leaf springs are wider.
Keith
Convert to disc brakes.
Old 12-04-2013, 02:42 PM   #4
lolife99
lolife99's Avatar
You can buy new "drop shackles" here:
http://www.performanceonline.com/che...springs-parts/
Keith
Old 12-04-2013, 04:09 PM   #5
tismy55
I have 2-1/2" leaf springs and I measures 73 they are the same width I just need to know it the 73 spring shackle will fit my 72 hanger
Old 12-04-2013, 04:09 PM   #6
Jdubs71
Jdubs71's Avatar
I dont belive the shackle changed much through 70's-80's. The spring width should be 2.5" so they should be fine
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 12-04-2013, 04:12 PM   #7
tismy55
Thanks for the help ,I appreciate it
Old 12-04-2013, 04:14 PM   #8
Jdubs71
Jdubs71's Avatar
This is what I bought. They're the same through 91 year models
http://www.sdtrucksprings.com/index....oducts_id=9423
My build thread
