Old 12-20-2013, 03:07 PM   #1
ChevyGearHeads
Starter wiring
Ok, I come to you all for wisdom, once more. I bought an American Autowire engine wiring harness and there is two wires hanging down for the starter, a purple one and a yellow one. I have heard and read a lot of speculation of which goes where. I was wondering if anyone knows which goes where? Anything appreciated ! Thanks
'68 Chevy Truck with HEI, automatic
Paul
'68 C10 327/TH350
LWB
ChevyGearHeads is offline   Reply With Quote
Old 12-20-2013, 03:42 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Starter wiring
The yellow should be the bypass if you're running points ignition. With a HEI, it is not used.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-20-2013, 04:46 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Starter wiring
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-20-2013, 04:53 PM   #4
67 chevelle
67 chevelle's Avatar
Re: Starter wiring
purple is the standard color wire that goes to your neutral safety switch and from there another purple wire goes to the starter selinoid
if you are running a point type ignition , as bigdave160 said the yellow attaches to the positive side of the coil for full 12 volt suply only while cranking , the other white wire that attaches to the positive side of the coil is a resistor wire that usually measures at 9 volts in the key on position
67 chevelle is offline   Reply With Quote
Old 12-20-2013, 06:08 PM   #5
1972SUPERSB
1972SUPERSB's Avatar
Re: Starter wiring
I just installed this same exact wiring harness. I have a HEI and just used the purple on the starter. You won't need the yellow of you have an HEI. I was asking myself why did they provide the yellow wire when it is a wire harness just for an HEI truck?
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 12-20-2013, 06:33 PM   #6
hayhauler71
hayhauler71's Avatar
Re: Starter wiring
purple to the S term yellow to the R term[ if you are running points ignition ]
Fuzzy
hayhauler71 is offline   Reply With Quote
starter, wiring harness
