Old 12-31-2013, 06:56 PM   #1
chakah
chakah's Avatar
Poor man's '63 aluminum grill
As most us know, aluminum grills are hard to find. We mostly see 64-66 if any. I have been on lookout for months for a '63 grill, no dice. Then some of you are fortunate to grow 'em on trees (Rene C/10 King).
While cleaning out the garage, I noticed too many spray cans. Why not put 'em to use.
Started with the basic tools for removal, die grinder, 4 in. grinder, wire wheels, and some spray cans. Now we all know there is no such thing as chrome paint, so I renamed it 60-66 C-10 Anodized Grill Paint.
This is before removing anything on my Panel.
You can't really tell on these pics but the white paint was really on there. Somebody went paint brush crazy on it.
Another angle. The screws on the trim rings were in really bad shape.
I'm sorry I skipped a pic, but I removed the complete grill with lights and all because the trim rings would not come out. Once it was out, I ground out the rivet fasteners to get to the trim ring screws. Besides it gives access to paint the headlight brackets.
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 12-31-2013, 07:15 PM   #2
chakah
chakah's Avatar
Re: Poor man's '63 aluminum grill
Now here are the headlight brackets. This gives me time to replace bad screws. I used a wire brush and a Scothbrite scuff pad since I don't have a bead blaster. I also get to primer paint. I used a flat black to match up the patina.
A light scuff with the pad and a light primer will do.
Since the grinders won't fit, I also scuffed the back of the grill.
I did half of the paint removal here.
This is where the die grinder helps. It'll get in through tight spots with the wire wheel bit.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 07:34 PM   #3
chakah
chakah's Avatar
Here is the grill with the paint removed. One thing I don't recommend is using paint remover. Wire wheels and paint remover do not mix, you'll get it all over.
Here I can take a grinder break and paint the body with a flat black.
Another angle. Two coats of this flat black from a dollar store does the job.
While the body dries, I continued on the brackets.
Like I mentioned earlier, a scuff pad helps. Rust dust gets all over.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 07:48 PM   #4
NEWFISHER
NEWFISHER's Avatar
So far , so good!
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 12-31-2013, 07:48 PM   #5
chakah
chakah's Avatar
Now I tape up the rest of the body for the white.
Here's the first coat. On this I used a white primer for paint. Simply because the dam can was in my way. I didn't want that glossy look either.
Looking better without the tape.
Hood closed looks even better.
Another angle. All that headlight wiring was already brittle, so I replaced it and rerouted for a cleaner look.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 07:54 PM   #6
spacedebris
looking good.
I love that way of deciding paint color. The can was in my way
spacedebris is offline   Reply With Quote
Old 12-31-2013, 07:57 PM   #7
chakah
chakah's Avatar
Now it's time to overspray the neighbors.
Can't forget the trim rings.
First light coat.
Those are done.
After the second coat. Here you can coat the back of all pieces.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 08:09 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That is looking really good.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-31-2013, 08:17 PM   #9
chakah
chakah's Avatar
I forgot to mention earlier but when I assembled the headlight brackets to the grill, I simply got some small screws with nuts to replace the rivets. These clips are for the trim rings. Now....why does Harbor Freights have to sell me a whole box? I just need 6.
And here it is assembled together.
Front view.
And the other side view.
Pretty damm close if you ask me,.....at least at 55 mph passing by.
And that's how save time and money looking for an aluminum grill.
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 08:18 PM   #10
60-66
60-66's Avatar
Man that does look good ! Really needed the detail behind the grille to, looks great !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 12-31-2013, 08:19 PM   #11
hopped up
hopped up's Avatar
That looks pretty damn good! I never have liked chrome paint but that came out great
hopped up is offline   Reply With Quote
Old 12-31-2013, 08:24 PM   #12
oem4me
NICE! It's ultra rare magnetic aluminum.
Old 12-31-2013, 08:35 PM   #13
Sillyoldman
#16876
Sillyoldman's Avatar
[QUOTE=chakah;6444127]I forgot to mention earlier but when I assembled the headlight brackets to the grill, I simply got some small screws with nuts to replace the rivets. These clips are for the trim rings. Now....why does Harbor Freights have to sell me a whole box? I just need 6.
Attachment 1193834
Because the other 94 will break (jk) Nice work on the grille.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-31-2013, 08:53 PM   #14
TJ's Chevy
TJ's Chevy's Avatar
That does look perrty darn good! Heck of alot cheaper then getting it chromed! Might give that a shot just for the fun of it!
Old 12-31-2013, 08:57 PM   #15
chakah
chakah's Avatar
thanks Jon, got the paper work done and now it's ready roll !
neither do I,....but don't ask why it was in my garage
there you go oem, that's what I'll stick to
...that's no lie, thanks
"El Jerry"
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
Old 12-31-2013, 09:00 PM   #16
Indian113
Indian113's Avatar
When I was growing UP, we called that paint "DUTCH CHROME" but I think it turned out pretty good and it's a improvement over what you started with.
Indian113 is offline   Reply With Quote
Old 12-31-2013, 09:04 PM   #17
Downlow2xfo
Downlow2xfo's Avatar
Yep might have to borrow this but all the credit will be yours my friend... Great job!!
May your life be like a roll of toilet paper... Long and useful or short and crappy!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=584520
Downlow2xfo is offline   Reply With Quote
Old 12-31-2013, 09:49 PM   #18
joedoh
joedoh's Avatar
that is astoundingly great!
Old 12-31-2013, 09:58 PM   #19
lesjeux
very nice job!
lesjeux is offline   Reply With Quote
Old 12-31-2013, 09:59 PM   #20
BadaSs_Cal
BadaSs_Cal's Avatar
Nice job. I dont think a guy on here hasn't at one time or another tried their hand at chrome paint... I just gotta ask..
how come they just dont sell the paint they colored the spray paint can lid!? Haha
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 12-31-2013, 10:17 PM   #21
chevyrestoguy
chevyrestoguy's Avatar
Wow, what a makeover! The coolest part is that it took very little money (but a lot of labor) and the results are outstanding. Nice job!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-31-2013, 10:48 PM   #22
pdxhall
pdxhall's Avatar
The grill turned out great. I've wondered about the chrome paint and how it would look but never tried it. Seems to be a winner.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 12-31-2013, 11:07 PM   #23
doobiebro
doobiebro's Avatar
Looks chingon brutha! The hard work paid off at the end!
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 12-31-2013, 11:18 PM   #24
markeb01
Senior Enthusiast
markeb01's Avatar
Nice improvement! The detailing behind really makes it work.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 12-31-2013, 11:23 PM   #25
C/10 King
C/10 King's Avatar
Holly sh#t, can I send you half a dozen 63' grills to redo?????
Just kidding, Looks fantastic!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
