01-26-2014, 01:51 PM | #101 |
Old member
Re: What did you do to your truck today? Chapter II
Yesterday I drove the truck to our local chapter of chevy trucks meet in Greenville SC along with some others! First drive since the 6.0 LSx motor install!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-26-2014, 02:07 PM | #102 | |
This product actually is what most Restoration companies use to paint OEM style restoration projects... |
01-26-2014, 02:19 PM | #103 |
I spent my weekend stripping the paint off of my hood and the front fenders. I used aircraft paint stripper then sanded it down. Very time consuming.
01-26-2014, 02:39 PM | #104 |
RAT1968 '68 Cab/'71 Parts
Oh...My neck!
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-26-2014, 03:42 PM | #105 | ||
"Now all I need is a shop to go with my shop vac!" Last edited by texjake; 01-26-2014 at 03:53 PM. |
01-26-2014, 11:35 PM | #106 |
Installed my new engine harness, and got the old boy fired up..kinda. Took a lot of fiddling with the timing, but finally got it sputtering with the accelator smashed to the floor. Looked down the carb, pumped the throttle, and just a little bit of gas is dribbling out. I just rebuilt the carb too. It was shooting a nice jet out right after I got it back on the engine. Now, just dribbling. Guess I have to pull the carb apart again.
But it ran, yippee!!!
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
01-27-2014, 02:12 AM | #107 |
Awesome thanx again @elliot949 @TeX Jake much appreciated. I'm in so. Cal. And its been really nice weather lately. i.e. 70°-80°. I even have a space heather that can supply the heat over night.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
01-27-2014, 02:31 AM | #108 |
Puts some paint down before we install the new motor!!!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
01-27-2014, 07:06 PM | #109 |
Took her on a ride around town, went to the folks house and to get pizzas for dinner before the icepocalyps hits here in houston and the city falls apart!!!
01-27-2014, 07:25 PM | #110 |
Hooked up the trailer and drove out to Adam's and bought my new cab ! .
Now I have to wait until Thursday or Friday to take it to the body shop and see what he wants to replace it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
01-27-2014, 08:07 PM | #111 |
That looks really good, I have been struggling on how to strip all the old paint off my truck it needs to go to metal. All in all did the stripper work well for you and what did you use in the sanding process thanks Jerry
01-27-2014, 09:57 PM | #112 |
Re : Chemical Stripping
Just be EXTREMELY CAREFUL of chemical burns ! I first used " Aircraft Remover " in the 1960's and got some on my hands and arms , boy howdy was that a bad burn and hurt like the dickens because no water or anything else to remove it from my skin .
01-28-2014, 12:49 AM | #113 |
The aircraft stripper I used worked pretty good. I roughed up the paint with 40 grit just to open up the paint to let the stripper soak in. I had about three coats of old paint on. So it took a coat of stripper for each coat of old paint. Once I scrapped off as much as I could I used 80 grit to remove the rest. Like the previous post said, be careful with it. It will eat through light latex gloves, your clothes et,. were goggles, use in well ventilated area and/or use a respirator.
01-28-2014, 08:54 AM | #114 | |
01-28-2014, 09:33 AM | #115 |
I looked into getting it blasted. There's a company not too faraway that does it. I was quotes about $125 to $150 a panel. So it would add up pretty quick.
01-28-2014, 09:36 AM | #116 |
Typically if you do it all at one time they will cut the deal... I was quoted 125 for fenders and grill and 150 for the hood but they did all 4 pieces for 300...
01-28-2014, 10:04 AM | #117 |
dazed and confused
you are going to have to change your fender emblems now. Looks good
members met: redbaron69, billsbowtie,nc67 |
01-28-2014, 10:24 AM | #118 |
Does anybody know of a LSX 6 litre emblem that we could use?
01-28-2014, 11:18 AM | #119 |
I don't think they make a LSX 6.0 liter fender badge. There are LSX badges out there but not coupled with the 6.0 liter.
"Now all I need is a shop to go with my shop vac!" |
01-28-2014, 12:43 PM | #120 |
I dont think there is a media blaster around the spring tx area where I live or I would, plus the whole truck has to be strippd and I think by using a little elbow grease I should be able to do it myself. Although sure would be easier to have it blasted, as well as cleaner!
01-28-2014, 12:43 PM | #121 | |
01-28-2014, 01:53 PM | #122 |
New u-joints and carrier bearing. Should have bought a puller($30)...local brake shop pulled it off and stripped out my threads...now I know why they didn't charge me. $65 later at Scottys Driveshaft fixed the problem...they are the best.
Whooped my butt for awhile...as always the search button was most helpful.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
01-28-2014, 02:43 PM | #123 |
Got my wheels back from powder-coating, they look a lot cleaner now !
71 C-20 07 Magnum RT AWD |
01-28-2014, 04:37 PM | #124 |
I test fitted my new seat and figured our how far up I needed to mount my floor shift:
Then removed it and began the fat mat installation: Then laid the new carpet in to test fit:
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-28-2014, 10:49 PM | #125 |
Be aware that media blasting creates heat and can warp panels WAY beyond salvage ~ I've seen this happen many times , even though the company said " yeah , yeah ~ we've been doing this for 20 years and never ruined a panel yet " .
Once your original panels are ruined , you're going to wish you'd chem stripped instead .
