Can anyone tell me all the differences from 1977 to 1978, and 1979? I need wiring and chassis differences. I know essentially they're the same from 1973-1980 but i need those 3 years exactly as i have my 1977 c30 and 1978 k20 and 1979 k10 titled and all but need help!
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 Last edited by 79Betty; 01-12-2014 at 06:25 PM. Reason: I'm an Idiot. |
Re: Difference in Years?
As far as wiring is concerned, the three biggest differences I can think of are:
(1) For trucks with gauge clusters, 1977 was the last year to use a mechanical oil gauge. 1978-up oil gauges are electric. As a result, the instrument cluster pin-out changed quite a bit for gauge clusters between 77 & 78. (2) 1978 was the year they changed to the fusebox that takes the plastic ATO/ATC type fuses instead of glass fuses. There were also a number of wire colors that changed for 78. I believe these might have been mid-year changes so there might be some early 78's with the glass fuses & older wire color coding. They also added a ground buss connector near the parking brake in 78. (3) 1978 was the first year for the permanent magnet type wiper motor. The wiring is a bit different because there is a separate connector for the parking switch. The 73-77 wiper motors had the parking switch wired internally in the motor. Chassis wise, I believe 78 was the first year to have added some extra strut bracing from the engine mounts to the transmission & transfer case on the 4x4 trucks. The seat belts were changed in 78 as well. The 78-up seatbelts have the retractors for both the lap & shoulder belts built into one assembly that's bolted to the floor beside the seat. While 77 had separate retractors and the one for the shoulder belts mounts to the door latch pillar portion of the cab (and interferes with mounting the factory type cab corner speakers). The cab floor is shaped slightly different where the seatbelts mount and the rear halves of the sill plates are different in that area too. |
Ray that is some good info that helps. Trying to also distinguish of brake parts will interchange as i have a 77 c 30 wiring harness, cab n doghouse, 78 k20 chassis and 79 k10 axles n suspension so it's hectic as hell trying to order the right parts.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
#4 | |
That is right in the time period where the front axle changed from Dana44 over to the Corporate 10 bolt. It wasn't a clean "instant" change, it took quite some time before they all got 10 bolts.....must have been a supply issue?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
That would also mean a difference in brakes... Be a good note.
78K & 79C Jimmys
compareing my 78 and 79s
my 78 has early glass fuses,both 79s blade NSS wire colours are different high/low beam wire colours different 78 no charcoal,79 yes 78 two line fuel,79 three(1/4 return) 78 Idiot oil,moved holes when changed to gauges not sure about inner /outer hood release...78 no, 79s yes and the "Fat lip" hood edge? some think 79
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#7 | |||||
I believe the 2 vs. 3 fuel line difference has more to do with the original engine/drivetrain configuration than the year. Both my dad's 77 and my 77 have the 3-line setup with the 1/4" return. Quote:
Also, the headlight bezels, lower grille molding, and change from exposed fuel cap to filler doors. There are a bunch of cosmetic changes on the interiors too. Like a different style of instrument panel bezel for 75-77 vs. 78-80. And the higher trim level trucks had woodgrain accent panels on the dash & doors with about 3 different woodgrain styles used over the 73-77 year range. Then they changed to brushed aluminum in 78. And that reminds me ... the location of the VIN tag moved from the door jamb to the dash in 79 so a cut-out "window" was added to the dash pad. Last edited by ray_mcavoy; 01-13-2014 at 06:22 PM. |
78K & 79C Jimmys
I wondered if the 3 line pump helped with fuel boiling?
Well 1978 and older has standard threads on brakes and 79 and up has metric >
AFAIK the 77 was the lat year Chevy offered a engine that ran on regular gas. Mine is a LS9
H/D emission. No smog pump and single fuel line, (No vapor line)Larry ![]() P.S. No cat. converter. |
#12 | |
My 77 K15 has the LS9 H/D emission like yours, no smog pump, factory dual exhaust with no cat converter, and no vapor canister. But it does have the 3-line fuel pump, in/out/return with 2 lines (feed/return) along the frame. Dad's 77 K15 has the same setup but with the LF4 400 engine. I think the light vs. heavy duty emission cut-off point was still at the 6001 lbs point for 1978. Except in California where it was 8,501 lbs. Then in 79 it was upped to the 8,501 lbs. So the regular gas (no cat converter) engines were still available for a while after 77. But they became increasingly limited to heavier trucks as the years went by. And the laws changed requiring converters on more and more vehicles. |
Maybe someone ca help again. Anyone know what are the right fuses for a 79 wiring harness? I found mine but i have no fuses. I have to wire in pretty much everything except the headlight switch... Should be fun!
Reviving a thread... Trying to figure out what it is between a 1974 and 1977 now... I know the core support... Know 76 n down had door panel difference... I need wiring diagrams dangit... If i can get it titled as early as possible the better... But i don't want to have to order brake parts for 8 different years lol
#15 |
78K & 79C Jimmys
my 79 4X2 non AC,writting kinda worn tho
#16 |
My 78 was leaded gas truck. It is a C2500 HD.
I know the "VOICES" aren't real but they have some great ideas. 1978 GMC Sierra Classic C25 1983 Datsun 280ZX Turbo 1997 Chevy Cheyenne K2500 1999 Polaris Sport 400 |
#17 |
My79 was unleaded cat truck, 78 k20 and 77 c30 both leaded and not cat's. Need to get it titled as 74 only problem is it has a 79 k10 front axle (metric brakes) and 77 wiring... Just hope i can find out what the real differences are!!
#18 |
#19 |
Was "told" to get a state issued VIN because of the cab swap. If not i have a 74 cab now i can swap, but that sounds so much easier. Need to get to the BMV but i hate them so much... So very very much...
#20 |
In Texas, when you get the VIN reassigned they go by the frame. Whatever the frame VIN is will be the truck you will have. Look at my avatar. 78 frame, 85 body, 90 grille & core support w/ carburated 95 engine. Went through all the inspections, paperwork and hoops. Still titled as a 78 with a DOT sticker in the door jam showing the original VIN.
Tags |
difference, years variation |
