What is best NV4500 oil?
People tell me Castrol synthetic. I am having a hard time finding it around here. Must I special order this gold? I have these brands available local. Mobil 1 synthetic, Royal Purple synthetic and a couple others. Prices range from $9 up to $20 for the Mobil 1. I just busted my nuckles rebuilding this trans and don't want to make a wrong move on the oil. This is for my work truck and grain hauler.
Re: What is best NV4500 oil?
the GM or dodge fluid is what i run. i forget the name of the fluid but it is the same from either brand. its not cheap, but it is what the syncros want.
Chrysler # 4874459 GM #12346190 castrol syntorq is also the OK i believe. i usually run the dealership stuff. who ever has the better price. there are a few places on the net that you can order it as well. |
Castrol SynTorque 75W-90.
The GM dealer part number is PN 12346191. It is the exact same oil.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
6>8 Plugless........
![]() Join Date: Sep 2007
Dodge calls it synchromesh. We get it from our supplier in Minnesota and it's about half the price of every where else.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
OK guys, I did more checking last night and the general agreement is to use Castrol Syntorq (Watch that spelling closely) and Dealer oil. I had purchased some Royal Purple and some told me that was the worst thing I could put in the trans. Returned that last night. I have a connection with GM so I will find out today about oil from them. Thanks
Long thread on the dodge forums.. the oil is like gold ... unless you are crafty and cross it with a GM part number and buy it for 5 bucks a litre on sale in Canada anyway
gm (PN 12346191) this is one of the gm part numbers |
Heres the stuff for us North of the Border guys-
Right from the stealership...'Genuine Generous Motors' #10953477 $25 dollars a litre taxes in ... OUCH! mopar-4874459 subseded 4367579 or vice/versa costs even more! I used the factory fluid then if I have a synco go bad I can't easily blame the oil I used; but if i used anything else well...
100:1 low gear! |
is castrol synchrotorque available in canada cheaper?
I guess a 75-85 GL4 oils is what's recommended. Don't use GL5 oil, the additive package messes with the synchronizers and brass components.
http://www.allpar.com/mopar/transmissions/NV4500.html |
Windy Corner of a Dirty Street
NV4500’s are a finicky transmission to begin with I personally won’t take chances with any oil other than the OEM oil even if it does cost a few bucks more per quart. I agree with the part numbers Ryanroo posted.
I do like the idea of added capacity though. We'll see how the coolers and added capacity workout in time. ![]()
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
We've ran the coolers that are all aluminum and have had good luck with them. On 2nd gen dodges you can't run the LH side one though.
Well, I could not find any GM oil around here. I did find Amsoil synthetic. The label states that it is a direct replacement for GM part no.12346190. It has just a light oil color to it. I put four qts in for now. On my test drive it shifts very nice. It does have a slight werring noise when in motion. First time I ever looked at the inside of one of these. It has been a challenge. Thanks.
#13 | |
You are right with the fluid level. The capacity is one gallon. |
#14 | |
Both gm and dodge use the synchromesh name. |
#15 | |
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
