#651 |
Re: How about some pics of bagged 60-66
#652 |
Rollin' Old Skool
Came across this pic on Facebook one day:
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#653 |
Back from shop!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#654 |
Looks like Borris aka way2lo2
GOD BLESS AMERICA! |
#655 |
Rollin' Old Skool
That's what someone else on Facebook had said in the comments where I saw the pic.
#656 |
Out and about.
#657 |
Pictures.
#658 |
here are a few recent shots of my truck.
pancaked front crossmember 2" cupped lower a arms 2"drop spindles lowered front bumper 1 1/4" and moved it back 3/4" lowered the core support body mount 1/2" and front cab mount 1/4" front 15x6 supremes with 6.10 cokers back 15.8 with l78 cokers ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 Last edited by coulter; 04-06-2014 at 03:12 AM. |
#659 |
The lowered front bumper looks cool.it reveals the bottom painted lip on the grill surround.nice mod.
#660 | |
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 ![]() |
#661 |
My 63...Just installed the front bags. Not as low as I wanted but still satisfied.
#662 | |
![]() '03 3500 Duramax dually '96 1500 ext. cab Chevy '66 swb C-10 '63 Panel '60 VW vert '56 VW vert |
#663 |
Rollin' Old Skool
#664 |
Mine!
Tony from Norcal |
#665 |
#666 |
Tony, truck looks cool !
#667 |
Thanks guys!!! ^^^^^
Tony from Norcal |
#668 |
i love these trucks bagged
#669 |
62 c10 short
#670 |
Has anyone that is Bagged, figured out a way to jack up the truck if a flat tire or total bag failure happens? I found a thread with this question and NO answers.
Thanks everyone. |
#671 |
I have been able to compensate for a blown line or bag by adding additional pressure to the bag opposite the issue. This is generally enough to get it off the road and attend to the problem. If assembled correctly so the lines don't get cut or melted and the bags don't get pinched or rub a hole through you should be golden for years. I also recommend you give your system a general inspection as part of your maintenance routine. This will help you avoid any possible future issues.
#672 |
Yep. Air up, Jack on flat frame in front of tire to drop tire. Or I also have 4x4 that spans the rear frame. Have not tried with new rear shocks yet they might let rear drop enough.
#673 | ||
Here is the thread I was talking about. Jacking Options for Frame-Laying Trucks http://67-72chevytrucks.com/vboard/s...d.php?t=622653 |
#674 |
Getting close to being done
#675 |
^^^ahhh, that is sooo cool,....I just made a mess in my shorts
