05-10-2014, 10:08 PM | #1 |
No adjustment hole for rear brakes
I have a 1985 Chevy 4x2 long bed truck and there is no hole in the backing plate to adjust the brakes how do I adjust them ? I know about the backing up thing but they should have a hole there to manually adjust them shouldn't they ?
05-10-2014, 10:12 PM | #2 |
Re: No adjustment hole for rear brakes
you know, I just ran into this on my 67 camaro. The driver side had the access on the backing plate. The passenger had the access on the outside of the drum. Which I found by removing the wheel. This was new to me and made it interesting because that brake was froze up. I had to push the car to rotate the drum to 6 o'colock to get to the release.
Hope it helps. Matt |
05-10-2014, 10:18 PM | #3 |
I had the drum off a few weeks ago and there is no access hole in it either I am stumped .
05-10-2014, 11:46 PM | #4 |
Outside of the drum, huh?! And NO access on the '85 truck! Geeze, I've never heard of that in all my years!
My Camaro, and FRANKENTRUCK, both have the standard access on both sides, as do all my other vehicles. Learn something new everyday,... I'd guess Hiluxxulih will be doing a gross adjustment with the drums off and then utilizing the backup technique to complete the adjustment to the rears. How strange,... Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
05-11-2014, 09:56 AM | #5 |
I thought you was hallucinatin' till I looked at mine.
No holes on mine either! But a little quality time with a drill and files and a new plug will fix that. |
05-11-2014, 09:58 AM | #6 |
Have seen this before. Clean the backing plate real good at the bottom where the slot would be located. There should be 2 scored areas, use a chisel and hammer to knock out the slot needed.
05-12-2014, 08:12 AM | #7 | |
There are two because the backing plates are common and that way the same part can be used for both sides. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-12-2014, 05:28 PM | #8 |
05-12-2014, 06:42 PM | #9 |
What makes you think your truck is from Canada?
05-12-2014, 07:13 PM | #10 |
05-12-2014, 07:29 PM | #11 |
Could be, but maybe just certain optioned trucks where like that or just for a couple years.
My 84 is an Alabama truck built in Flint. |
05-12-2014, 07:47 PM | #12 |
driving is in my blood
Shouldn't be too confusing as its extremely common. Niether of my current trucks has the hole nor did my previous 79. The 79 was american built, both my currents are canadian built. You adjust with the drum off, then put it on and check, then re-do if needed. Or drill the hole lol.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-12-2014, 08:15 PM | #13 | |
05-12-2014, 08:48 PM | #14 |
GM Addicted
my truck doesn't have them either, even searched for knock outs when I just did brakes none found. I always adjust them before I put drum on so there tight then do the reverse procedure
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
05-12-2014, 09:50 PM | #15 |
I drilled my adjustment holes in my new drums...
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
05-12-2014, 11:15 PM | #16 |
Same thing on my 76 Julius when I did the brakes last summer. The really odd part was there were adjustment slots on the TOP side like the backing plates were used from another application and just flipped hpside down. I couldn't back off the adjusters to remove the badly worn shoes and had to break the pins and pull the whole assembly off with springs flying. Was something like 4 hours to do the whole job including the stuck wheel cylinder lines.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
05-13-2014, 11:27 AM | #17 |
Windy Corner of a Dirty Street
No adjuster access in the backing plate or drum face is not that uncommon in the industry. You need one of these shoe adjuster gauges where you flip it one way to gauge the drum then flip it around to adjust the shoe up to that dimension. This works great but if your drum has a wear lip on the edge you’ll never get them adjusted correctly. I use this tool even on vehicles with an adjuster screw access hole just to get the shoes adjusted up close to the drum then I do a few clicks of the start to run them a bit tighter. I find the tool usually gets you right on the money.
As mentioned above, most of the older 1/2 ton trucks without access in the backing plate have a knock out in the drum to punch out for adjusting however, if the truck has received a set of China's finest aftermarket brake drums in its life they probably do not have the knock out provision.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
05-13-2014, 01:33 PM | #18 |
its a real bummer when you discover that the wheel is frozen due to rust and you need to release the brake to even get the drum off. then you discover no adjustment hole to release it.
got er done and home but decided to not invest any money in the old front drums and ordered power disc kit. matt |
05-15-2014, 09:38 AM | #19 |
Has anyone checked their drums to make sure the "knock Out" is there?
Desert |
11-25-2016, 11:37 AM | #20 |
When I had a flat earlier this year I decided to check the drums on the rear of my '80 C-10. I looked on the back for an adjustment hole so I could back off the self adjuster, nothing.
I was beginning to think it was just my truck, until I read this thread, so now I know what to look for. Thankfully if there is a knock out in the drum itself it should still be there, looks to be the original drum. Thanks again for all the info, save me alot of cussing trying to get the damn things off.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
11-25-2016, 12:22 PM | #21 |
Are the two recessed rectangles I can see at the bottom of the backing plate not the knockouts? I've always seen oval ones, but it looks like there is something there????
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
11-25-2016, 07:45 PM | #22 |
My 78,C-10 had the adjustment holes in the drums.
When I got the new drums to put on it---No knockouts on them at all! Had to make my own holes. No knockouts in the backing plates either. I don't understand the reason for this.Some have them and some don't? Mike. |
11-26-2016, 12:47 PM | #23 |
I was wondering if it is Canadian built truck only thing not having adjustment holes .
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
11-27-2016, 08:49 AM | #24 |
I think it has something to do with the brakes being automatically adjusted as you drive, but that dont make any sense though as most rear drums do that anyways if I remember correctly
10-18-2018, 01:04 PM | #25 |
I have a '76 Chevy G-20 van, same deal. There is an indentation where the slot should be, but it doesn't look like a knock-out to me, looks like part one continuous piece of metal. These have never been touched. 33K original miles. Van sat in the guys back yard for 40 years with a bent axle.
