#376 |
Re: Dug's 1959 Fleetside
gm stuff try gmupfitter and go through to see what you need from different models.
#377 |
I bought a SWB bed and tailgate from a '94 Chevy truck at the U-Pull-It place. Eight (I think) 18 mm bolts and it was off. The inside of the bed is flawless. Jim and I are brainstorming on how we can use the majority of the fresh bed including the bed front, bed floor, inside walls and latching tailgate and still make it look old. Ideas include replacing the '94 tailgate "Chevrolet" text with the text off of the '59 gate. All of the latching linkage appears to be above the area in which we would recess the '59 text panel. The '59 has a pretty large bondo filled dent in the top. May simply hang the '59 sides on the '94 bed. It will get a bit interesting around the '59 taillights since they are mounted on a flat surface and the back of the '94 (structure and tailgate) has a curve to it. The rest of the truck has a bunch of curves. Adding a few on the tail end of the truck will fit right in. Regardless, I will still need to section the bed walls. My first move will probably be to pop a line 3/8" on the outside of the pockets and remove the bed sides.
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#378 |
Dug,
How well do the '59 side panels line up with the '94? If things do line up well, it should be a fairly simple matter to reskin the '94 bed with the earlier sides. Now, trying to get the modern internals of the tailgate into the '59 would be a real feat ![]() |
#379 | |
#380 |
http://grantkustoms.com/catalog/fill...ler-p-280.html
sure you can find em cheaper with some searching this is the 1st thing that popped up
'59 chevy apache: camaro clip, LQ4 with 5.3l 799 heads, Vengeance Racing tune, LTs, CAI, 4l60e, 8.5" ten bolt w/ truetrac |
#381 | |
#382 |
Great score on the bed. I like your idea for using the tailgate. There is a build on here (old) that dealt with reworking the tailgate. Search for "Yukon Ratrod". I planned to steal his idea (that is very simular to what you are thinking on the taligate). Look at post 107/108 for how he grafted in the "Chevrolet".
I am getting inspired in Columbus (Goodguys) this weekend. I probably saw (and photographed) 50 to 60 AD and TF trucks today. Two years ago there might have been 10. I have seen a lot of great cars, and some great paint ideas. The 58-62 Corvettes have also got me drooling again to get off my rear!!!
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#383 | |
Columbus Goodguys sounds like fun.
#384 |
Okay, I feel like an idiot- have been searching for the "yukon ratrod" with no luck... could someone provide a link
#385 | |
http://67-72chevytrucks.com/vboard/s...=391290&page=5
#386 |
Cut the damaged passenger side off the new bed after coming up with a plan to hang the '59 sides off the '94. Sheet metal below nice and straight. After much measuring we were surprised to find out that the bed is more narrow in the rear than in the front by 1-1/2". In other words, the bed side top rails are not perpendicular to the front of the bed or the tailgate. The red line is perpendicular to the bed ends and represents the approximate location I will be butt welding the '59 to the '94 which means that the combined top rail will get wider as it goes towards the rear. May add a piece to the top rail so it looks rectangular from the top. Also, the inner bed sides narrow as well from front to back. After I remove the driver side, the next move will be to cut loose the top rails, tailgate support structure and bed front (but keeping them all together) so I can move the bed floor up to clear the T.B. suspension. Looks like one of the '94 bed cross members will need to be moved since it conflicts with the highest point on the T.B. suspension.
Note the Highlander in the background. Headlights had yellowed and faded badly. Polishing them no longer worked. Sanded with 1000 then 1200 Wet/Dry sandpaper then painted with Rustoleum clear coat for made for plastic headlights. Graingers sells them by the can. Bought a case of 6 from Home Depot for about $5/can. Also did the '08 Dodge in the background. Works incredibly well.
#387 |
Thanks for the link, Dug- looking forward to seeing how the "merging" works out!
#388 |
Thanks for bringing up the taillights - I had forgotten about them, and liked the idea. I started a thread in the General section of the 47-59 Board with pictures from Columbus. It was a really great show this year with a wide variety of cars/trucks. Looking forward to your updates.
Ricky
#389 |
Removed the '94 bed sides and set it on the frame.
- Overall plan is as follows: 1. Mount the '94 bed as shown in picture 1 with proper rake and cab-to-bed gaps. 2. Release the bed front and tailgate structure from the bed floor. 3. Section the sides keeping the the top of the bed front and top of the tailgate structure connected to the side top rails. 4. Lower the top rail, bed front and tailgate structure as a unit to a point where, when mounted, the '59 sides line up. 5. Move wheel openings. - Picture 2 is the measurement from the front TB mounting bracket to the bottom of the bed cross member. About 9" away. - Picture 3 is the rear one at about 2" above the frame rail. - Picture 4 is the middle bed cross member shown sitting directly on the frame rail where it belongs. The front of it is butted up against the complicated TB spring perch assembly which just so happens creates pretty acceptable cab-to-bed gaps. - If you look closely enough in picture 5, you can see that the high point of the spring perch assembly is about 3/4" below the bottom of the bed floor. Will move the bed down by notching the '94 cross member. May even rest the cross member on the spring perch assembly with a rubber pad between. The Chevy engineers went to allot of trouble to create this complicated spring perch assembly to get the exhaust over the rear end. Appears to me they over thought it. The clearances are way over the top. Looks like they could have made it flat and gotten nearly the same clearance.
#390 |
...oh, a surprise vintage VW slid out of one of the bed pockets when I disassembled the bed this last time. Will keep the factory wheels/tires and, since the patina is perfect, just clearcoat it.
#391 |
i've always thought the bed sides on tf trucks was too low and should have come up to the body line under the door glass like the height you have the bed in this pic.
it would take a lot of work especially on a fleetside bed but it would look good and custom not like i'm trying to add another year to your build, dug, just saying... ![]() ![]() ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#392 |
[QUOTE=_Ogre;6764734]i've always thought the bed sides on tf trucks was too low and should have come up to the body line under the door glass like the height you have the bed in this pic.
it would take a lot of work especially on a fleetside bed but it would look good and custom not like i'm trying to add another year to your build, dug, just saying... ![]() ![]() ![]() Orge, you may talk him into it! Dug mentioned he had the same idea - and had the same reaction - a lot of work. With a panel truck quarter it would be easier, but you would loose the spears. Thanks for posting the pictures side by side - now you have me thinking (dreaming!).
#393 |
Orge: Interesting that you bring bed height up. I agree with you. Ricky (Ricott) and I were having a conversation about that very thing. After I notch the center bed cross member to get it down as low as it will go, I will study it more closely. Ricky mentioned a truck he saw where the guy used panel truck sides. This allowed the guy to set the height where ever he wanted it. Those sides have no bullets. Note that the one I included shows that top body line in line with the bottom of the cab windows as you mentioned. Sure would have been smart of me to have removed the '94 sides a bit more carefully. Gotta learn how to use photo shop.....thx dug
#394 |
You're doing a real nice job on all the mods to get what you want.
Kim |
#395 |
Although worthy of serious consideration by a more seasoned fabricator, I decided not to make the bed taller to line up with the body line just under the cab glass.
Photo 1 - Jim came over and we hung the '59 on the '94 bed side using some SS hooks my Dad bent up many years ago to hang stuff up in his garage. Body line nearly lines up perfectly. Photo 2 - Approximately 3/4" gap between bed and cab. Remember, the center bed floor cross member is jammed up against the spring perch cluster. If I don't modify it, I can't move it any closer which is probably ok. Photo 3 - Aligned the bed front flange on the '59 side with the bed front '94 flange and determined it should go back to the stock location fairly easily. Photo 4 - With the bed aligned as stated in photo 3, the back curvature of the '94 tailgate assembly is 3/4" beyond the back of the '59 bed end. Should be able to work out a sheet metal transition to get there using some of the bed side material I have left. Photo 5 - If I don't notch the center bed floor cross member to fit over the frame and close the gap above the spring perch, I lose approximately 5-1/2" of bed depth which will give me a bed depth of approximately 13-1/2". If I decide to do the notch, the numbers will be 4-1/2" lost with 14-1/2" bed depth.
#396 |
Looking good Doug. I need to get over there and see your project in person. I finally got back to work on mine today. The more I take apart, the more rust and problems I find!
Jason ![]() My build thread: Double Jeopardy |
#397 |
Welcome home. We will get together. Man, you need to get the military to teach you how to weld and fabricate!
#398 |
i start my project like a month ago (56 stepside on 2007 trailblazer rolling chassis) without know if others have done the same project, after i start i search in the web and i found a bunch of similar project and i like to see how every body have different ways to figure it out put all together, the only problem that i have for now is the front wheel clearance when the wheels are full turned, i want the truck the most low possible but there is my limit the front wheels. and is not easy to find rims whit less offset than the originals so i think the only way is put very low tires on 17" rims.
for the floor i do this way because i use 4x4 trans Last edited by rustymarco; 12-18-2014 at 05:32 PM. |
#399 |
Last edited by rustymarco; 12-18-2014 at 06:13 PM. Reason: how delete comments ??????? this is very difficult to use |
#400 | |
