Old 07-18-2014, 12:22 PM   #1
justgotatruck
Help With Brakes
Was driving and there was a sudden burst of air that came through the vents, then the brakes went really weak. I had to push them all the way down before i got pressure and then had to gently work them at that point to not skid the rear tires. Stayed like that for the rest of my drive home. Power steering works just fine, no issues
Any help on what to look for? only thing I've ever done with brakes is change them, so i'm lost as far as where to start. I checked the hose running from the PA and it looks to be in good shape
justgotatruck is offline   Reply With Quote
Old 07-18-2014, 01:15 PM   #2
Clyde65
Clyde65's Avatar
Re: Help With Brakes
1st things, make sure you have ample fluid in the reservoir, make sure you have vacumn at the booster. Bleed the brakes a little to verify you have fluid at all four corners.
It actually sounds like a master issue to me.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-18-2014, 07:38 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Sounds like a bad booster.. You usually hear some kind of vacuum leak.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-19-2014, 12:58 AM   #4
Captainfab
60-66 Nut
It sounds to me like the diaphram in the booster ruptured. Time for a new brake booster.
Old 07-31-2014, 05:58 PM   #5
justgotatruck
Sorry for the very late response.. wife's car was having problems so this went on the back burner.
So the booster is the issue. I was told by the previous owner he didn't think it was stock and these years didn't include them, but I found some conflicting information online.. did these come stock? if so does this look like a stock unit or after market.. And anything in particular i need to look for when replacing it? I know its a dual bowl MC so are there different kinds of boosters in regards to this?
Old 07-31-2014, 06:34 PM   #6
Dual MC were not available on these years. Looks like someone put a 67-70 booster & MC
1966, power brakes
