Old 09-08-2014, 08:04 PM   #1
KyleSeal
KyleSeal's Avatar
Brothers Trucks Door & Window Weatherstripping?
Brothers is having a rather large sale and I was curious if these weatherstripping Items are any good? I have a '70 C10 and want to keep the wing windows. I also would like to not have to slam the doors as it will be a daily driver.
http://www.brotherstrucks.com/prodin...CS0072&wlqty=1
http://www.brotherstrucks.com/prodin...WW0072&wlqty=2
http://www.brotherstrucks.com/prodin...FS6772&wlqty=2
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 09-08-2014, 08:32 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Brothers Trucks Door & Window Weatherstripping?
Seems a lot of guys like precision gaskets and you might want to check what brand those are ,JC Witney sells the precision gaskets and the prices are low .Most any new gasket will make your doors harder to close at first and you may have to adjust the door striker until they settle .
Old 09-08-2014, 11:07 PM   #3
Sean1985
Sean1985's Avatar
I used the brothers window channel kit. I thought it was good. I don't have a tremendous amount of knowledge in weatherstripping but I would buy it again.
Sean1985 is offline   Reply With Quote
Old 09-08-2014, 11:14 PM   #4
Nitis
Nitis's Avatar
Window kit was fine however I missed ordering the wing windows and not sure I want to open that can of works again right now
I'm satisfied with my door to cab seal kit however I would like to try the push on set from gmc Paul's. The glueing and taping was tedious. As for closing the doors you need to give them a little push if you just let them close they will only catch the first latch. Over time they are getting better.
Again only reason I would use another is to compare for myself
Nitis is offline   Reply With Quote
1970, brothers trucks, sale, seals, weatherstripping
