Old 09-30-2014, 06:11 AM   #101
hardcore4life
hardcore4life's Avatar
Re: 1991 V3500 Project Heavy Hauler
So you're planning an 8.1 swap I take it?
68 C10 lwb, 406 sbc, 700R4
86 K30 srw, 454 bbc, TH400
11 Camaro RS, 217 V6, 6M
hardcore4life is offline   Reply With Quote
Old 09-30-2014, 10:10 AM   #102
MTCK
MTCK's Avatar
Yup, that's the plan. Not looking great for this winter as I haven't found any shop space and this truck is about 10' too long to fit in my garage.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-30-2014, 10:41 AM   #103
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Very cool Marcus! Somehow I missed this thread of yours. Looks like a very clean rig to play with. Love the Suburban interior and the swapped in tilt column in there too.….same color of Suburban seats I have in the K10. That rubber floor mat is a killer to work with huh? That is the same mat in my K10 and it is tough as nails to work with. You almost need a blow torch and chainsaw to cut and mold it. Looks like it turned out great. You will like that mat as it is practically impossible to hurt it.
Let me know when you want to start talking 8.1L stuff. You know I have the recipe at hand and it is fresh in my mind again as I am doing one in the Polar Bear Suburban this winter. Right now I’m still working on the engine internals and gathering install bits. This one is getting a Raylar cam just to see how much more a cam really wakes up an 8.1. Hope to install the engine around Decemberish.
Subscribed!
DirtyLarry is offline   Reply With Quote
Old 09-30-2014, 02:47 PM   #104
MTCK
MTCK's Avatar
Thanks Larry, yeah that mat is a PITA, but bulletproof. I'm still not 100% happy with how it is laying near the firewall, but the rest of it has settled down. That's exciting about the Raylar cam. They have some pretty cool vids of some wild 8.1's on their web site.
I've actually been referencing your good write up on CK5 quite a bit as I plan. Do you have a good source for purchasing new workhorse parts with "reasonable" shipping? I'm going to try using the in-tank sending units for the fuel system and the AC Delco EP241 pumps along with a direct replacement switch rated at 65 psi. Check out the data sheet link below. I think the previous version of this part from Pollak was not rated for as much pressure.
http://products.pollakaftermarket.co...S_41-revdd.pdf
It is supposed to plug right in where the stock 87-91 valve goes using the stock switch. The three tank setup is intriguing, though I would need a loan to put 80 gallons in at a time if I added a suburban tank in the rear. $135 was bad enough last week...
-Marcus
Project Plow Truck
Old 09-30-2014, 04:40 PM   #105
DirtyLarry
DirtyLarry's Avatar
Yeah, I hear you. I am not real happy with the way mine lays near the trans tunnel but it is as good as it will get being it is so stiff and thick.
Hehe, I know I am excited to try a RayLar cam! Should be interesting.
I might have a source for Workhorse parts. Let me know what specifically you would need. In all reality, if you’re not running A/C there really isn’t anything that Workhorse has that you can’t find through GM, Ebay or salvage yards. The highly sought after high mount A/C brackets through Workhorse are now extinct. All gone… the only ones to be found now would be from G-van engines at salvage yards or from PSI who now builds the 8.1L and 8.8L.
The pressure rating of the Pollak switch valve is not the issue. The issue comes in where the return port in the switch valve is too small (5/16) and the 8.1L’s with the return type fuel rail use a large return line much larger than 5/16. I think the return line on the 8.1L is around 10mm but in any event, the return ports on the switch valve are too small and restrict the fuel return which drives up head pressure. I tried to use the Pollak valve but the little ports caused the head pressure to run at 100 psi. Once I disconnected the return line from the switch valve the fuel pressure went down to normal. In the end, I gave up on the idea of using a switch valve. Instead I have an EP241 on a 1987 TBI sending unit in the right side tank which is just a storage tank. That pump transfers fuel to the LH tank byway of a switch on the dash.
Now, if you used a later model 8.1L with the returnless fuel rail you might be able to figure out a work around with that switch valve. I’ve never really researched the returnless fuel rails as I prefer the return type because they have an adjustable fuel regular built into the rail. The 8.1L I’m doing for the Suburban had the later type returnless fuel rail but I took it off and purchased a new return type fuel rail for it because I like having the adjustable regulator. 8.1L’s love higher than stock fuel pressure. They really respond well to 67-68 psi fuel pressure.
BTW…. The fuel pumps you would need to run an 8.1L are actually the EP381. The EP381 will fit on your existing sending units no different than the pumps that are on them now. You probably read where I had an EP241 but that was back when I was running the truck on a marine MEFI-4 ECM which runs on lower fuel pressure (~40 psi) like the old school TPI engine. I ran the EP241 for a short while after converting it to the MAF OBDII harness on a truck P59 ECM which requires around 62 psi but found the EP241 did not maintain fuel pressure at wide open throttle so I swapped in an EP381. Problem sovled. Confused even more now? BTW....the old EP241 pump that used to supply the engine actually lives in the RH tank now and is used just as a transfer pump.
Old 10-04-2014, 03:27 PM   #106
MTCK
MTCK's Avatar
Thanks for the info Larry. Good call on the different pumps - I would have ordered the wrong ones. I'm having a hard time figuring out why the valve you had was causing that much pressure. I wonder if you got a bad unit? Fuel return volume should only be a function of the fuel pump, pressure at the regulator, head loss through the lines and fuel used by the engine. The higher the pressure at your regulator, the lower the flow as the pump has to work harder. I suppose if you have a large diameter return line all the way to the valve then necked down that could cause some increase in pressure. 10mm ID is about 1.5 the cross sectional area of a 5/16" ID.
I'll do some more research and maybe even a little trial and error. I am interested in the wiring for a three tank system that was shown on that schematic. 80 gallons would definitely get me to the next station, and it would be nice to not mess with transfer pumps. I always forgot to turn mine off on my '77, as I had a system very similar to yours. $4/ gallon fuel all over the road!
Winter is here. I was waiting for a dump trailer to come available but it never did, so I hauled off most of the spoils from my grubbing project with the pickup. It was easy to load and a son of a gun to shovel out. I guessed the mix of roots and organics and dirt was much lighter than it really was. Still had about 3" of up travel to the bump stops with this load, but went over GVW by quite a bit. Whoops. Rides like a Cadillac with 3 tons in the back. Surprisingly the weight over the front axle was only about 500 lbs. more than when the truck was empty. That means I had almost 9k over the rear axle. The tires were cool but I won't do that again, even if it was just a couple miles across town.
I took the mini ex back this morning and the boost feature on the brake controller worked great. It was much more solid feeling while braking, even though the roads were slick. $$ well spent in my opinion.
-Marcus
Project Plow Truck
Old 10-04-2014, 07:16 PM   #107
y5mgisi
Second Chance Program
y5mgisi's Avatar
Good to see it get so much use!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-07-2014, 01:38 AM   #108
MTCK
MTCK's Avatar
It's been getting worked, that is for sure. Just got my SEM dye. Lead time is about a month, but I'm just happy I found a guy who knows how to ship paint to AK.
-Marcus
Project Plow Truck
Old 10-07-2014, 10:33 AM   #109
DirtyLarry
DirtyLarry's Avatar
WOW! 12,700! That’s heavy, unless you were on a Canadian scale . The funny thing is it isn’t even squatting that badly. Got to love K30s
Glad you finally got your paint. Not sure if you are planning to paint the center console or not but I haven’t had any luck with any of the SEM products on the center console (or Duplicolor for that matter). SEM works great everywhere else (door panels, dash, kick panels, sun visors, etc.) but whatever plastic the console is made out of nothing will stick to it. Everything just scratches off like a lottery ticket. I’ve tried a couple different SEM paints/dyes and well as prep products. The console looks horrible right now after a year of off-road travel so I was thinking of buying some vinyl that matches the seats to cover the console with. Not what I would prefer to do but maybe the only way to keep that damn console dark gray instead of its molded light gray. One thing about it, when it is time to repaint console it is easy to get the old paint off. Just spray it down with the power washer and all the SEM paint flies right off
Old 10-08-2014, 10:31 PM   #110
MTCK
MTCK's Avatar
I had a similar experience when I tried colorbond dye on my 77's console. It was pretty scratched up after two years. I'm hoping the SEM GM medium gray is close to the slate gray (89) suburban interior I have so I don't have to dye it. I'll need to do all the headliner trim pieces and front door panels - maybe the rear door panels and dash pad. We'll see. Maybe I should have named this truck 50 shades of gray...
-Marcus
Project Plow Truck
Old 10-13-2014, 03:09 AM   #111
MTCK
MTCK's Avatar
For fear of being redundant... The weather warmed up and dump trailer came available so I hauled off the last of my grubbing. Hauled a little more than 35k lbs, 386 miles of driving in total, about half of that with 7k trailer in tow. Another 50 or so miles with 18k of trailer and skid steer in tow.
Motor has developed a pretty noticeable knock and I used about a quart of oil over the ~400 miles. Everything else worked flawlessly. Had to use 4wd just about every time to get out of my driveway, but was good after that. I get a loud rubbing noise under hard acceleration in 1st gear. I think it might be the fan hitting the shroud, and may try placing my gopro under the hood and seeing if I can make it happen. I would not be surprised if the motor mounts are shot - the t-case shifter sure moves a lot.
-Marcus
Project Plow Truck
Old 10-13-2014, 03:44 AM   #112
y5mgisi
y5mgisi's Avatar
I once had a truck that would rub the harmonic balancer on the crossmember. Could be that.
Old 10-13-2014, 11:26 AM   #113
MTCK
MTCK's Avatar
That's a good idea I'll check there too. Thanks.
-Marcus
Project Plow Truck
Old 10-13-2014, 03:46 PM   #114
y5mgisi
y5mgisi's Avatar
Mine would do it every time on a hard left turn.
Old 10-14-2014, 02:36 AM   #115
MTCK
MTCK's Avatar
Looks like the 50 shades of gray theme continues. Sprayed on of my junkyard sun visors to try out the classic coat and check the color. It is quite a bit lighter than my slate gray interior.
The floor mat, dash and center consol all match well. I need to play with one of those computer rendering deals to look at the color options. I like both of these grays, just need to see how it all goes together with the headliner fabric, door inserts and two materials on the seats.
That was three coats 10 min apart. Coverage looks good. Not sure I needed to do the third coat.
-Marcus
Project Plow Truck
Old 10-14-2014, 08:38 AM   #116
Greenlee
Greenlee's Avatar
I think that will probably look fine when you get it in the truck. Mine has stock unpainted red visors, seat and seatbelts, and SEM Firethorn red dash, door panels and trim. The shades of red are different, but you don't notice it in the truck. Even new vehicles usually have some different shades of color by design.
Greenlee is offline   Reply With Quote
Old 02-07-2015, 12:30 AM   #117
MTCK
MTCK's Avatar
Haven't done much work on the truck lately. I had one of my old rusty rims with a slow leak around the valve stem so I dismounted it, hit it with the wire wheel and painted it. Decided I had better do the rest so they match. I got tired of dragging the compressor outside to air up every time I needed to move the truck to plow. -35F headed for -50F tonight.
-Marcus
Project Plow Truck
Old 02-08-2015, 06:37 AM   #118
hardcore4life
That temperature sounds horrendous. ��
Old 02-08-2015, 11:01 AM   #119
Hankster
Hankster's Avatar
Fresh wheel paint looks good
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 02-08-2015, 05:31 PM   #120
MTCK
MTCK's Avatar
Thanks Hankster. Yeah it is a little brisk and tough on the hardware. My last tank I'm my Tacoma was 10.3 mpg. Yay auto start.
-Marcus
Project Plow Truck
Old 02-08-2015, 10:29 PM   #121
farmall
farmall's Avatar
Why in the world do you live up there?
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 02-09-2015, 04:06 AM   #122
MTCK
MTCK's Avatar
It's not so bad. The cold temps keep the population down - otherwise we would be overrun!
-Marcus
Project Plow Truck
Old 02-09-2015, 07:53 AM   #123
farmall
farmall's Avatar
More than half of Oregon is Gov land from desert to Cascades to rain forest to the coast. I have 32000 acres right out my back door all year long. This pic is in January, just a thought.
Old 02-09-2015, 01:42 PM   #124
MTCK
MTCK's Avatar
That's gorgeous! I've spent a lot of time in Oregon and it would definitely be on my short list if I couldn't live here. My wife attended grad school in the western part of the state and I did two years of undergrad in Idaho and frequented the eastern half, but haven't spent much time in central Oregon.
I do like to recruit from our local university here, as this is not for everyone. That way potential employees have at least survived a winter!
Cool H1, is that yours?
-Marcus
Project Plow Truck
Old 02-10-2015, 11:13 PM   #125
farmall
farmall's Avatar
Yea, thats my 2 door.
I could not handle the prolonged cold and darkness. It would make my female reproductive parts hurt if you know what I mean
