09-18-2014, 09:03 AM | #126 |
Re: S10 Swap how to
Thanks Bill for making this a sticky. I hope it will be a good tool for quick reference.
Side note. I just got an longbed pickup going on an extended cab in the shop today. As I build this one I'll be able to give ya'll dimensions for extended cab conversion as well.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
09-18-2014, 10:25 AM | #127 |
Re: S10 Swap how to
That's what mine is! I trimmed 2.375" off the front of the bed to match the extended cab wheelbase.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
09-22-2014, 04:01 PM | #128 | |
Re: S10 Swap how to
1950 Chevy 3100 Patina, S10 Swap #layinpatina 1923 T-Bucket 350 SBC,350 Turbo Trans |
09-22-2014, 05:59 PM | #129 |
Re: S10 Swap how to
I'm looking forward to this one. I'm hunting for a cheap extended cab for my 3600. They're snagged before I can get to them, and I don't want to pay extra for a pretty one. Can't wait to hear the verdict on this swap.
09-25-2014, 08:50 AM | #130 |
Re: S10 Swap how to
User Error; the two wires off the VSS should go directly to the ECM. There will be one wire from the ECM that gives signal to the speedo. I posted the pinout for S10 Dash plug earlier on this thread.
09-25-2014, 08:52 AM | #131 |
Re: S10 Swap how to
On the 3600 build. So far, the cab stand reference points and measurements are exactly the same as the long-bed frame. I am prepping the 5.3L/4L60E combo today, hopefully be the end of the week the bed will be mocked up.
09-26-2014, 05:37 PM | #132 | |
Re: S10 Swap how to
09-27-2014, 06:10 AM | #133 |
Re: S10 Swap how to
Sarge, I see lots of pickups done with the s-10. Ever done an AD panel truck/s-10 swap?
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
09-29-2014, 09:06 AM | #134 |
Re: S10 Swap how to
User error; Correct.
Old Crow; I have not done a panel truck yet, but I can't see the difficulty. They use the same bed and cross sills as a truck. Should be pretty much exactly the same.
10-02-2014, 11:10 AM | #135 |
Re: S10 Swap how to
I just bought both a 49 and 53 burb (one for parts) and I was thinking of swapping onto an s10 but I wondered if the low part of the frame would hang too low.
1959 Fleetside Big Window Long Box Standard Trim soon to be Deluxe 1953 GMC Carryall Suburban |
10-02-2014, 04:17 PM | #136 |
Re: S10 Swap how to
10-4 anyone have an actual pic of what the gauge plug looks like? I've got the unused portion of the harness all zip tied around the column up under the dash many many plugs... not doing the tear down myself... no clue which plug I'm looking for LoL... Fun stuff finishing someone elses project... it's got it own set of issues...
10-02-2014, 06:11 PM | #137 |
Re: S10 Swap how to
Maybe i'm a sucker for punishment or a control freak.... but i can never start where anyone left off. especially when it comes to wiring.
Not sure what year speedo you have... but here's a good start. http://67-72chevytrucks.com/vboard/s...d.php?t=313815 |
10-02-2014, 10:52 PM | #138 |
Re: S10 Swap how to
Beanyard; frame should sit just like it does on the truck swap. should look fine.
User Error; Sorry, no pics of the plug. It's a Blue rectangle plug with 18 pins. Should be the only one like it in the dash board area.
10-10-2014, 02:46 PM | #139 |
Re: S10 Swap how to
Sorry if I missed this answer, can the s10 front coils be used for the conversion using a V8?
10-10-2014, 04:28 PM | #140 |
Old Heap Driver
Re: S10 Swap how to
I had a V-8 S-10 with lowering springs, no issues at all.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '30 Model A Pickup, suicide front end, 350, 350, traditional style hot rod. |
10-11-2014, 12:31 AM | #141 |
Re: S10 Swap how to
Garyhenrich; Yes, I've never changed front coils. They work nicely. What I would recommend is new ball joints (Moog or equivalent), and replacing any worn suspension components while you swap in the drop spindles. Less headaches later that way!
10-11-2014, 10:05 AM | #142 |
Re: S10 Swap how to
Thanks, I will upgrade the worn parts when I install the drop spindles. Great thread. I took all this info, plus info from other threads on s10 conversions and put them all into a 40 page document that I am now following on my conversion. I have a 48 3800 that has a restored body that I'm dropping on a 84 s10. My 48 had a 54 235 installed and they moved the radiator ahead a couple of inches for fan clearance, Not sure if I'll need to change out the radiator to clear the steering box. Again, thanks for all the help, should be dropping the body on the frame in a couple weeks.
10-11-2014, 09:23 PM | #143 |
Re: S10 Swap how to
If it's a 1 ton, are you stretching that S10 frame, or are you converting it to a short bed?
10-11-2014, 11:13 PM | #144 |
Re: S10 Swap how to
Moving to a short bed. Bought another 48 3100, pulled the bed and running boards off of that and will set the new rig up as a short bed 48. My cab is fulling restored with a wooden flat bed but needs an updated chassis.
10-12-2014, 10:57 AM | #145 |
Re: S10 Swap how to
Gotcha... should be a pretty straight forward swap then.
Update on the 54 long bed swap. The long bed is about 2.5" too long for the wheelbase. The solution I came up with is to remove 1.25" from each of the bed splash guards (to tuck the bed closer to the back of the cab) and to re-locate the rear end rearwards 1.25". Other than that, the swap has all been exactly the same.
10-17-2014, 08:55 PM | #146 |
Re: S10 Swap how to
Skymangs... I Have A 1/2 Ton Longbed Im Looking To Swap Soon.
I Talked To The Guys At EZ Swap Chassis An They Told Me That For Longbed /LWB Trucks Using S10 Ext Cab Frames 87-92 All You Have To Do Is Flip The Rear Springs Around Front To Back.. This Will Give You The 125" Wheel Base Fitment ... Yes or No? You Seem To Have Mastered These Swaps.. |
10-20-2014, 09:39 PM | #147 |
Re: S10 Swap how to
Thank you so much for this write up. I have been searching the web for any info I could find and this is great. Me and a buddy of mine are trying to do a 1950 ( at least that is what he said it was) for another friend of ours. he wants it for his dad that has cancer and has less than 6 months to live. We are hoping to get this done in less than 60 days but niether of us have done anything like this. I have cut and pasted almost 50 pages from this thread to have at our finger tips.. Great write up, thanks again.
10-25-2014, 01:06 PM | #148 |
Re: S10 Swap how to
In brand new here. Just bought a second series 55 with a 58 fleetside bed. Any reason this swap won't work for me? Looks like my wheelbase is a little longer but I'm sure there's room to massage things a bit. There's a 118" wheelbase s-10 chassis on CL for $350. Thinking I'm gonna snatch it up. Any advice would be greatly appreciated.
10-25-2014, 05:02 PM | #149 |
Re: S10 Swap how to
I have gone through much of the write up and it is very detailed, I have the 53 chevy the S10 explorer rear end, and just purchased a cummins 4bt and will use a nv4500 for the the engine and trans choice. Will be putting a lot of your ideas into mine, thanks for the write up done well
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
10-27-2014, 08:56 PM | #150 |
Re: S10 Swap how to
Anybody out there used longer upper and lower a-arms instead of spacers on the front end? I would like to use tubular a-arms and not use the wheel spacers. Thanks
