Re: D52 Caliper Rear Disc Brake Brackets
Sorry Captainfab; I was just rereading this rear disc bracket info and I came across my 2 cents worth and I had said a 77 chevy truck diff. while I have a 64 chevy truck 12 bolt.It was rebuilt but I have to do a axle swap to a 5 lug so my tires will fit back on( it came with 6 lugs) so I have to order those first and by the postings I should be able to upgrade mt 12 bolt soon !!! What exactly do I need/LOL/I guess everything !!! Thanks
#2 | |
60-66 Nut
Since you have a '64 truck 12 bolt, you will also have to change the side spider gears along with the axles. Once you have the axles out, remove the backing plates. All of my rear disc conversion brackets except the Impala SS brackets, can be R&R'd without removing the axles.
