10-16-2014, 01:04 PM | #1 |
Opinions on Transmission Fluid Changes
The fluid in my 84 K/10's trans is dark and recently I've noticed a weak shift from 1st to 2nd under light throttle. I've been hearing some conflicting opinions on whether or not changing the fluid is good or bad. I have heard fluid FLUSHES are to be avoided, but I'm talking about a new pan gasket, new filter, and letting as much of the fluid that wants to drain out to drain out. Then replacing what came out with fresh fluid. Should I go ahead and do the trans service or is it best to be left alone to not ruin any existing seals inside the trans?
My Wheels: 1984 Chevrolet K/10 Scottsdale 350cid *SOLD* 1989 Cadillac Fleetwood Brougham d'Elegance 307cid 2015 Chevrolet Silverado 1500 LT Texas Edition 5.3L 4x4 |
10-16-2014, 02:05 PM | #2 |
Re: Opinions on Transmission Fluid Changes
I have always gotten different opinions also.
I would do what your planning on changing. Its sounds like its in need of something anyways. Do it and start looking for a replacement t350? or tranny shop, just incase.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
10-16-2014, 03:39 PM | #3 |
Drain it, put in full synthetic ATF, and add a bottle of this stuff.
http://www.summitracing.com/parts/atp-at205
Rich Weyand 1978 K10 RCSB DD. |
10-16-2014, 07:22 PM | #4 |
The reason you hear conflicting opinions is what happens when you change the fluid you take away the friction particles from the fluid that it is using the keep the clutches from slipping.The clutches are wore out. If you change the fluid it removes what it is using to keep the clutches from slipping. Thats why you hear of people changing the fluid and the trans no longer will shift or work. I would not change the fluid until you decide to get another or time your rebuild. Its only a matter of time. New fluid will not fix your problem. It will most likely make it worse.
10-16-2014, 07:57 PM | #5 |
Robert Olson Transport
I tend to agree with Homemade87.. if you regularly change the fluids since you put in a new trans every 24-30K you would be ok but once you start experiencing weak shifts or the fluid is burnt, you will only hasten the death of the trans
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-16-2014, 08:47 PM | #6 |
If it's a TH350, Drop the pan (Save the Fluid), If the pan is full of Mud, Clean the pan out, Replace Filter. Strain old ATF with a rag & refill...Top off with fresh fluid. Save up for a rebuild. No sense in leaving a filter in that is most likely clogged.
Let us know if you have a 700R4, Several things can cause a soft 1-2, 90% of them can be fixed without pulling the trans. |
10-17-2014, 11:49 AM | #7 | |
10-17-2014, 03:51 PM | #8 |
I would plan on changing the fluid and filter. My guess is most failures that are blamed on fluid changes are due to the transmission finally failing due to neglect or just plain being wore out. On the other hand, not changing the fluid just continues the neglect problem.
Before doing anything, research the fixes clinebarger mentions as they may require dropping the pan anyway. |
10-17-2014, 04:24 PM | #9 | |
It'd be alot cooler if you did
10-17-2014, 04:27 PM | #10 | |
78K & 79C Jimmys
hadn't thought of the tranny but I've replaced burnt fluid and filter that i could get out before, but then no go.(got it rebuilt) BTW (paint filters) work on cooled deep fryer grease too lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-18-2014, 07:51 PM | #11 | |
Unlike TH350/TH400....700R4's run clean until they are ready to fail. If the pan is fairly clean, Check you TV cable adjustment (I have posted on this several times in the Engine & Drivetrain section). If TV adjustment is OK, Remove the 1-2 Accumulator Housing, Check for a Broken Accumulator Spring, & Holes in the Separator Plate, Yes, The Spring can wear a hole right through the plate. |
10-19-2014, 09:41 AM | #12 |
Fluid flushes are great if they are performed correctly and if you are using good product. Find a BG certified shop http://www.bgfindashop.com/locator/index.php
10-20-2014, 03:32 PM | #13 |
All right, I appreciate all the advice and opinions given here. I think I'm gonna go with what Clinebarger recommended and check for metal in the pan. I'll change the filter/pan gasket for fun and go from there. If it looks beat then I'll put the old fluid back in and just ride it out. What do you guys think, good plan?
10-20-2014, 04:28 PM | #14 | |
'77 P10 (GMs late 60s thru the 70s truck spare parts bin model ) |
10-20-2014, 11:10 PM | #15 |
Everyone on here gave great opinions and insight to what my problem could be and how to deal with it. Clinebarger's info happened to encompass the best of both anti-fluid change and pro-fluid change specific to what trans I have so I liked what he said. I'm all too familiar with TV cable maladjustment having dealt with that on my Fleetwood Brougham's 307+200R4 combo.....
12-12-2015, 05:14 PM | #16 |
But Found Her 25yrs Later!
I have a Summit Th350 with very little miles I bought from another. I dropped the pan to install a Lokar Dipstick. The fluid is nice fresh and clean. The only problem is I don't know what kind of fluid to put back in it.
It still has fluid in the Torque Converter, so I guess my concern is if it matters that whatever is in it needs to be the same or not?
12-12-2015, 06:48 PM | #17 | |
12-12-2015, 08:41 PM | #18 |
I see there is different Types such as Type F.
What Type should I use?
12-12-2015, 09:18 PM | #19 |
Moderator
For the TH700R4 TH400 TH350 4L60 4L80 3L60 or 3L80 in good condition fill with Dexron VI.
There is no such thing as Dexron III certified anymore. In 2006 GM stopped buying and licensing it so there's no guarantee it's Dexron III anymore because the fox is watching the henhouse. Here's GM Tech Service Bulletin 04-07-30-037D on the "new" Dexron VI transmission fluid. Our trucks fall into the "2008 and Prior GM Passenger Cars and Light Duty Trucks" category... It's worth reading the recommendation to not use Dexron VI in Power Steering, Manual Transmissions, and Transfer cases that originally called for Dexron III. It obviously doesn't apply to the SM465 or the NP203 & NP205 transfer cases that had other fluid recommendations. The GM recommended juice is noticeably less expensive than the Exxon Mobil product I would trust. "The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRONŽ-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Power Steering Systems should now use P/N 9985010 labeled Power Steering Fluid."
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-12-2015 at 09:33 PM. |
12-12-2015, 09:35 PM | #20 | |
Something that says it's suitable to use in a transmission that called for Dexron III originally will be perfectly fine and acceptable, even Wal-Mart Supertech. Heck, even a lot of the big name trans guys have no qualms with Supertech. There is no need to spend the big bucks on Dexron VI unless you are running a late model trans, in my book. You can get a gallon of Dexron III compatible Supertech for $15 or so. I've been running it in my GM autos for years without a single problem. |
12-12-2015, 09:45 PM | #21 |
My transmission guy said the fluid type doesn't really matter, the main difference he said was some fluids grip differently. He always ran Ford fluid in his GMs to make them shift harder. The GM fluid allows some slippage for smoother shifts.
That being said I just run Dexron whatever from AutoZone. |
12-13-2015, 09:37 AM | #22 | |
Moderator
http://www.walmart.com/browse/auto-t...d:Super%20Tech The WalMart Supertech Dexron VI is licensed just like everything labeled Dexron VI. It's the same $4.27/qt as the Multi-Vehicle Dexron Mercon. Super expensive stuff there.
And please let us know if and how your repairs were successful. |
12-13-2015, 11:12 AM | #23 | |
Posted via Mobile Device |
12-13-2015, 11:59 AM | #24 |
Moderator
A lot more GM rigs on the road that came with Dexron VI now. Demand is up so supply is up and price is down. The inverse is true of Dexron III.
Dexron III compatible price isn't likely to stay even with Dexron VI for much longer.
12-31-2015, 12:40 AM | #25 |
I have always changed/flushed auto trans oil in my own shop. I pull the pan, change filter and reinstall. Pour in a gallon of new ATF, and remove the lower trans line from radiator. I than slide a short piece of rubber hose on line , and put into drain pail. Start the truck, and let fluid pump from line into pail until clean , red fluid appears. Reinstall line on rad, and refill trans to correct level. Maybe not quite as effective as a professional flush, but works and saves you a few bucks.
