Old 11-01-2014, 02:08 PM   #26
OrrieG
OrrieG's Avatar
Re: My new roller frame
Time to drop the body on to check wheelbase, ride height, etc. Still $500 worth of parts there....
Old 11-01-2014, 02:18 PM   #27
lowrodderchev
lowrodderchev's Avatar
agreed!!!
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 11-01-2014, 03:26 PM   #28
Jbm1956
Yea I agree with that. But I want to get this truck on he road lol. So hopefully its right
Jbm1956 is offline   Reply With Quote
Old 11-01-2014, 08:29 PM   #29
Kim57
Kim57's Avatar
The only real way to find out if it right is to mount your cab front fenders and bed on it.
If it's not the right wheel base they may have the rear out of position or the front clip out of position and you wont know until it's together.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-03-2014, 10:52 AM   #30
buggy5872
buggy5872's Avatar
No im not sure on the year. I heard you add an 1 inch or so when you put the camaro clip in not minus an inch. Lowrodderchev is at 116 inches and his is perfect in the wheel well.
Maybe it was forward not back....its been about 5 years since I did one....I will measure the wheel base on mine and let you know.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 11-03-2014, 03:51 PM   #31
dubie
dubie's Avatar
yeah it's 1" - 1.5" forward the clip has to move when you lower it. Even when you lower with a dropped axle, and lowered leafs, the center pin is moved 1" ahead of stock. It looks like it was installed correctly, just a bit to short.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-06-2014, 12:00 AM   #32
izonme13
izonme13's Avatar
My clip was put in with the original wheelbase. So I had to move the cab back 1.5" and now it is perfect. Thankfully I'm changing to a 4 link rear suspension so I can extend the rear of the frame when I C-notch it and make the bed fit properly. So with that being said, don't worry it can be fixed. My wheelbase is 115 1/2".
izonme13 is offline   Reply With Quote
Old 11-06-2014, 11:14 AM   #33
cooperhw
cooperhw's Avatar
If you use the shortened frame couldn't you just trim a couple inches off the front of the bed sides and put it back together?
I am new to this era truck but just throwing out ideas. Me myself, is something on mine is too short I lengthen it, if it's too long I shorten it. It's just sheet metal or even frames are just metal. I am not an excellent welder so I apply a good tack and then call in my professional welder. He could weld a snot rocket to an ice cube "I sh*t u not".
cooperhw is offline   Reply With Quote
Old 11-06-2014, 11:30 AM   #34
Jbm1956
Yea im not too sure on how to fix it. Im hoping it will be fine. I just need to sit the cab and fenders on a cfoss my fingers. Cuz welding stuff is out of my league
Old 11-06-2014, 04:55 PM   #35
lowrodderchev
Yes won't know till its together
