#226 |
Re: Post Pics of your Static Drops!!
So beautiful.
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
#227 |
#228 |
The bed is boxed in - solid tail piece (no tailgate). The panels are aluminum that I had machined to match the fins on an M/T Valve Cover. Panels are recessed into the tail piece. I'll see If I have a better pic and will post.
#229 |
Few more pics.
#230 |
#231 |
#232 |
I'm posting again, at least I think I already posted, because I've learned more about what is actually under it since the trade...
Drop spindles -2.5" cheap single piston...I think 75 mm, stops alright tho. Drop springs? Still unsure but the front cross member is only about 3.5-4 inches from the ground. 9" ford rear end with leaf springs under Axel tubes Air shocks with the upper mount relocated(not enough imo) There's prolly 2"-3.5" depending on psi in air shock between Axle tube and frame. Also the same distance between to of rear end housing and floor. If the shocks are empty or low it'll bottom out but it does good when there's a lil psi added. She does lean to the back passenger side a lil, I'm assuming it's just worn leaf springs..?.. Anyway, I want to get seat belts, then some good sway bars for sure.
Live and let live ![]() Last edited by familyfast64; 10-15-2013 at 05:03 PM. |
#233 |
7/8
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#234 |
#235 |
1.5 cut coils in the front, cut .5 in the back with 2" blocks 1966 c20 custom camper daily driver.
#236 |
#237 |
Finally got that low and level look that I was seeking.
#238 |
And again...but now with smaller diameter tires.
#239 |
Still working it...
#240 |
![]() ![]() Join Date: Apr 2012
Really starting to like the lowered longbed look, Very nice truck there Endlessearth , love your style !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#241 |
#242 |
#243 |
64 with spindles and 1" springs in front 5" springs in back.Tires are 235/75/15 on van rallies and truck rallies in the first picture.
#244 |
My 62. when I bought it it had the torsion bars cranked all of the way out and heated springs in the rear. 2nd pic is matching set of tires still same height, 3rd picture is with 2 1/2 inch Western Suspension Drop Spindles, 10 rounds back in the Torsion bars, Same heated springs rear with 18x8 with 235/50/18 on the front and 18x 9 1/2 255/55/18 on the rear.
#245 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
#246 |
rusty1962, man you got it right in that 3rd pic. The stance looks good and as mentioned, those wheels make a difference.
#247 |
Thanks, Lot of work already done you can't see but Still Long way to Go!!!
#248 |
I like that last truck with the moon discs on it. I guess I am partial to those.
#249 |
![]() Join Date: May 2012
Just finished mine in July. Some where around 6" in the front, 6' to 8" in the rear. 540ci big block.
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 Last edited by contagious102; 12-20-2014 at 09:58 AM. |
#250 |
Bad ass!
