12-15-2014, 01:27 AM | #151 |
Re: Restoring Rusty - New Freeze Plug
So picked up and installed the new freeze plug. I inspected two others (one on opposite side, and one in front by the fuel pump) and they looked ok. I could not get to the two in the rear of the engine, or the two under the engine mounts, nor the last one by the steering pump.
I used a 1" socket to get it started. Looks good, so does it leak? OH HECK YES - First thing tomorrow I am off to AutoZone for a new one and their Freeze Plug Installation Kit. |
12-15-2014, 01:45 AM | #152 |
Re: Restoring Rusty - Starter Cable
even took off the starter cable to clean it ~ I'm a sick puppy
Can someone tell me why this positive terminal cable is BLACK instead of RED? |
12-15-2014, 01:48 AM | #153 |
Re: Restoring Rusty
12-16-2014, 02:52 AM | #154 |
Re: Restoring Rusty - Back to the Blower Unit
Finally got the blower unit reassembled, and put back on the truck, and I must say it looks the business!
I ended up using the 3M Strip-Calk product aka "dumb dumb" between it and the firewall as someone on this forum recommended, thanks again. |
12-16-2014, 02:56 AM | #155 |
Re: Restoring Rusty - Watchin' Paint Dry
Winter Projects Suck, even here in Cali, especially painting in the winter, so you have to get creative. Here we peak inside our paint booth and literally watch paint dry, as I had to get creative. This little yellow halogen jobbie is 500 Watts and puts off some good heat.
12-16-2014, 03:00 AM | #156 |
Re: Restoring Rusty - Finally Fluids Going In
man I thought I would never change that oil, always wanted to line my oil cans up like that, TV car show style and all, LOL
I know its cheap Oil but if there's anything my daddy taught me it's that it is better to replace cheap oil often than expensive oil NEVER, am I right fellas. Splurged $2 bucks on a new 1/2 inch drain plug as the washer on my old one was crusty. Last edited by Gregski; 12-16-2014 at 03:17 AM. |
12-16-2014, 03:04 AM | #157 |
Re: Restoring Rusty - Radiator Drain Plug
Look at that radiator drain plug, can you see those buggers stuck in it, that would explain why I had to remove the lower radiator hose to drain it.
Interesting design GM, flushing the cooling system hinges on one tiny 1/4 inch hole, why couldn't you just give us a wing nut type plug and call it good. No hon I did not see your Q-tips, why would I take em?! |
12-16-2014, 03:07 AM | #158 |
Re: Restoring Rusty - Engine Block Drain Plug
Took out this passenger side engine block drain plug for no reason, well I guess to drain the coolant out of the block to replace the poorly installed new freeze plug again.
I wish I had a picture of this little guy cleaned up, thought I did, oh well, used a wire whee, and it cleaned up real good. I opted no to remove it's twin from the driver side, didn't wanna push my luck. |
12-16-2014, 03:11 AM | #159 |
First time I dealt with a starter with shims, I guess that explains the two busted starter teeth I found in the bell housing under the fly wheel, must have been from the old starter.
12-16-2014, 03:15 AM | #160 |
Re: Restoring Rusty - Wire Hangers
got some new wiring mounting clips/hangers only to find out they are not the same kind, the old ones only have a bolt hole on one side and just bend over, not too happy with these, does anybody know where to get the OEM style hangers?
So cleaned up and re used the old ones. These run along my oil pan and hold the positive starter cable and others to the pan. |
12-16-2014, 05:28 PM | #161 |
Re: Restoring Rusty
You're making progress. A lot of it really.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
12-16-2014, 09:51 PM | #162 |
Re: Restoring Rusty
12-16-2014, 10:18 PM | #163 |
Re: Restoring Rusty
What product did you use to paint that blower unit? That is the perfect underhood finish, not too glossy, not too flat, just right.
12-16-2014, 10:20 PM | #164 |
Re: Restoring Rusty - Passenger Inner Fender Done
Finally some pics of the finished passenger side of the engine bay.
Blower assembly, painted - done Inner Fender, replaced/painted - done Battery Tray, replaced/painted - done Frame Rail, painted - done What do you think of the body color instead of black on the inner fender? I only painted the lid of the air cleaner housing because I am going to replace it with the Retro one from LMC Truck next month. |
12-16-2014, 10:29 PM | #165 |
Re: Restoring Rusty
I don't know if you have installed the oil pan yet but, the position of the pickup screen to pan needs to be 1/4"-3/8". I like to tack the screen to the pump as I have seen them fall off.
12-16-2014, 10:47 PM | #166 |
Re: Restoring Rusty
Awesome thread Greg,really entertaining and you do good work. Lots of good info for us rookies....keep it up.
12-16-2014, 11:34 PM | #167 |
Re: Restoring Rusty
Wow, had no idea about that requirement, figured Malory pump and Malory tube should have the proper bend to it, let's pray.
12-16-2014, 11:41 PM | #168 |
Re: Restoring Rusty
Thank you, I like it too. I've used KRYLON Rust Tough Enamel - Semi Flat Black on everything from the wheels, to the front bumper and now for bits under the hood. However it is getting too expensive at $7 bucks a rattle can. Thinking about switching to Rust-Oleum.
12-16-2014, 11:51 PM | #169 |
Re: Restoring Rusty
12-17-2014, 09:52 AM | #170 | |
Re: Restoring Rusty - You Got Mail
I just bought the Vortec head version of that manifold for my 355 that's under construction, and will be using a 80457SA or 80458SA carb. (The latter has center-hung float bowls and dual fuel inlets on the passenger side).
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 12-17-2014 at 10:11 AM. |
12-17-2014, 08:15 PM | #171 |
Man, that is music to my ears, so good to hear some validation, thank you. So what cam would you recommend, keep in mind I plan on buying aluminum heads to go with it. Looking for a street truck, nothing crazy, goal is 300 hp.
12-17-2014, 09:59 PM | #172 |
Re: Restoring Rusty
Comp Cams 12-235-2 will give you 290hp and 410lbft from a stock 350 with stock 76cc heads, as long as you put a dual plane manifold and long-tube headers on it.
If you're going with new heads like the Dart aluminum heads, it's pretty easy to get 400hp and 430lbft from a stock 350, using Comp Cams 12-238-2. Basically, 300hp is a pretty low goal for new heads. Or another way to say it, you can get 300hp without spending big bucks on heads. Download Camquest6 and play around with it. Just google camquest6.
Rich Weyand 1978 K10 RCSB DD. |
12-19-2014, 05:52 PM | #173 |
Re: Restoring Rusty
Wow Rich, great recommend, I'm liking this one I believe they call it the Xtreme 4x4 pronounced "Torque" LOL, Good Idle and 1,000-5,200 RPM range, what's not to like, but doing more homework still, thank you very much
12-19-2014, 06:18 PM | #174 |
Re: Restoring Rusty
I personally went with the 12-300-4, which is 285hp and 420lbft, because I wanted even more grunt in the bottom. Performance above 3000-3500 rpm isn't a prime consideration for me in a street machine.
Here is the dyno simulator run for the 12-235-2. The left side gives you all the parameters for the stock 350 you need to set. Then you can try all the cams you want.
12-20-2014, 05:15 PM | #175 |
Re: Restoring Rusty - Oiled The Hood Hinges
oiled the hood hinges with some White Lithium grease, and my god what a difference I can open and close the hood with two fingers ~ keep 'em lubricated boys!
