Old 11-29-2014, 08:40 PM   #1
Ziegelsteinfaust
divorced transfer case
What are the advantages or disadvantages to them.
I was talking to a Ford guy who said he wasn't a fan of them, and wish they mated like Chevy for his high boy. Something about drive line slop being the issue.
Ziegelsteinfaust is offline   Reply With Quote
Old 11-29-2014, 09:23 PM   #2
kwmech
Re: divorced transfer case
A little more maintenance with the extra drive shaft and the mounting bushings. That's about it. The advantage is it is a lot easier to change the clutch when needed and a longer front shaft when a lift kit is added
Old 11-30-2014, 01:46 AM   #3
andrewmp6
A divorced case is good if you want a big lift like 16 inches or more,If he has drive line slop its wore out u joints or other problems basicly a lack of maintenance.All the napco gm trucks used a divorced case which was 50s in to the mid 60s.Ford ran both divorced and married in the 70s,The bronco and f150 was married the f250/f350 was half and half.
Old 11-30-2014, 01:50 AM   #4
60sIron
60sIron's Avatar
Depends on the year. The divorced mount t case I'm most familiar with is the T-221. When I rebuilt mine 15+ years ago shafts were unubtanable. You could cross reference bearings and seals but if you needed hard parts good luck. Not sure how many others were divorced mount. One other positive would be that it would be easier to obtain acceptable drive shaft angles on lifted trucks.
60sIron is offline   Reply With Quote
Old 11-30-2014, 07:11 AM   #5
andrewmp6
On the fords all the divorced ones are np205 i know of but its the wrong side drop for a gm truck.
Old 11-30-2014, 02:01 PM   #6
61K10
61K10's Avatar
Dodge divorced 205 for replacement of 221. a member here has done it.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 12-01-2014, 03:05 AM   #7
andrewmp6
I didn't know dodge used them but never kept up with dodge either.
Old 12-01-2014, 03:05 AM   #8
'63GENIII
'63GENIII's Avatar
Had a T221 in the '63 originally. Swapped it out to a Dodge divorced 205. I like being able to run nearly any transmission I want to. Drive line slop has never been a problem.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-01-2014, 09:53 AM   #9
andrewmp6
Yeah you can run any trans and using a 2wd one its cheaper then the same one 4x4.Replacement parts for the np205 are easy but for the t221 good luck on that.
Old 12-01-2014, 01:16 PM   #10
61K10
61K10's Avatar
63GENIII---so how is your combo working? Might just do this to mine down the road as it's pretty much not a freeway filer with the stock stuff.
1961 chevy K10
Old 12-01-2014, 10:38 PM   #11
'63GENIII
'63GENIII's Avatar
To date, my setup has been real good to me. I still have to work out the drive line angle a little bettr and connect the speedometer cable. The T221 worked great as well but I did notice a significant reduction in gear noise with the 205. I still have the 221 as I was going to get a bearing kit for it. Haven't gotten around to that one yet and probably never will with all the projects I have going.
Chris
'63 k15 long step
Old 12-16-2014, 10:23 PM   #12
1972RedNeck
1972RedNeck's Avatar
The early fords used a Dana 24 transfer case. I like the divorced cases too. It let me easily put a Clark 5 speed in my '66 Ford.
My problem with them is that when you run a lot of power through them when pulling big loads, it eats mounts. To remedy the problem I made a strut rod like a few of the newer highboys had to keep the transfer case from working forward and backward.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-17-2014, 07:21 AM   #13
eric67m
eric67m's Avatar
I thought one of the advantages was running the same drive line front and rear. I recently picked up a 86' np205 round pattern case. The outputs on the transfercase are different configurations. Is it possible to change one of my outputs so it is the same as the other. This seems like it would be a good advantage to running a divorced case.
eric67m is offline   Reply With Quote
Old 12-21-2014, 12:17 PM   #14
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
I installed a divorce cas in my truck. I did it so I could clock the case and was sick of the trans leaking into the t-case. I did everything and couldn't get the leaking to stop. I don't have any slop or vibrations. Its perfect!
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-17-2015, 11:14 AM   #15
01chevduramax
01chevduramax's Avatar
How did you come up with the angle or amount of clocking needed for your 205? I'll be running 10" of lift. Mounting of the 205 is the only part of the truck I have no clue how to properly setup.
'71 org/wht 3/4 ton 4x4
01chevduramax is offline   Reply With Quote
