#26 |
![]() Join Date: Oct 2012
Re: 69 gmc dually soon to be 12valve
#27 |
[URL=http://s1371.photobucket.com/user/cjbresee/media/Mobile%20Uploads/CB9127A4-1F5F-4562-89D7-996F5AC56A02_zpsux8d7wlp.jpg.html]
![]() Before the new inner cowl....pic dosent do it justice....there was rot all across the front. If I hadn't put all the time in the rockers and cab corners....I would have looked for another cab. |
#28 |
6>8 Plugless........
![]() Join Date: Sep 2007
Great rust repair, that sure was a sweet rig in the day! It'll be even better with the newer drive train and new found power train.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#29 |
#30 |
#31 |
#32 |
#33 |
#34 |
It's hard to work on your shop when it's filled with projects. I have that issue too.
#35 |
Yeah....it was a challenge moving the truck over here...then back over there... lol! Didn't need the ladder with the truck in the shop! I used garage door panels to insulate. Wanted to do that for years. I'm loving having the outdoor wood stove heating the garage now :-)
#36 |
Ok....I've been stumbling around with these eaton axels. I thought they were ho52s...being out of a one ton I'm thinking they might be the 72s. thoughts?
#37 |
Truck had the 350 with only 40,000 miles with the np435 trans, divorced transfer case, pto winch with the eaton axels. Would this be the power package that NAPCO offered?
#38 |
The rear axle would have been the stock rear axle. Does your SPID list the R05 option? Being a 3500 it would hae been an H072. Checking the axle code on the carrier will help confirm that.
Up front NAPCO built axles based on the H052 centersection. Additionally they supplied the Dana t-case, lift block/stops, front spring mounts and hangers/brace, engine crossmember mod. parts ect. The PTO and the winch are of course options added to the basic "conversion" 4x4 parts. As a package conversion the stock engine, trans and rear axle were used without modification. Even the park brake cables used the 4x2 guides and frame dimples.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-14-2015 at 01:18 AM. |
#39 |
Love the build so far!
#40 |
#41 |
Frame off to the sandblaster
#42 |
[URL=http://s1371.photobucket.com/user/cjbresee/media/Mobile%20Uploads/8CA2C58F-BB57-4AA7-A6EC-B5D44B0F75A6_zpsl6o0poxb.jpg.html]
#43 |
Random question....has anybody in dealt with vintage air for these trucks? Opinions would be appreciated.
#44 |
Looks nice. It looks like you made a wise choice and got a cross member from AW. I haven't used a vintage air for these trucks. But, I know a few local guys who have and they love them.
#45 |
Yeah, I think I could of fabricated the crossmember to the first gen mounts. I looked up autoworld and called them. They are awesome to deal with. Great people....it's my first go around with a conversion. I want to get it right. Just wondered about the vintage air....it would clean up the firewall a bit and give me more room. Pricey tho lol!
#46 |
The only downside to any aftermarket heat/air is that they use inside cab air. Therw is no fresh air option which make defrosting windows using the heat function very challenging.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#47 |
Do they have a website? How much was that crossmember?
#48 |
Here you go.
http://www.cumminsdieselrepowers.com/Crossmembers.html Their original website if you want to look around it is: www.autoworldmt.com
#49 | ||
#50 |
They must have axed their old one.
