Old 01-27-2015, 12:54 PM   #1
nate 71 k20
4 inch lift
Hey guys so I'm brand new to this forum I have a 71 k20 really mint truck daily driven and it rides...well like a 71 k20 so I traded some old parts for a set of rancho 4 inch front springs so I ordered all new lift shocks stearing arm lift block and 2 inch rear blocks cuz my truck has some bad rake but the problem is I found out there 85 k5 blazer front springs witch I read are about 2 inches shorter. My question is will they work with my stock shackles or am I f*cked?
nate 71 k20 is offline   Reply With Quote
Old 01-27-2015, 06:20 PM   #2
Mike C
Mike C's Avatar
Re: 4 inch lift
I think that the 85 springs are longer not shorter. And they need to be the correct length.
My opinion, buy a complete lift designed to fit your truck with front and rear springs. It's expensive. And it's worth it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-27-2015, 10:14 PM   #3
72MARIO
72MARIO's Avatar
Re: 4 inch lift
The 73 springs are longer. They require some work to fit but it has been done. There is a build thread on a big block blue suburban and he used 73 up springs
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-28-2015, 10:05 AM   #4
Re: 4 inch lift
You can use the '73-up springs if you move the rear mount back. By doing this you will gain another 2" of lift, due to the drop of the frame. It's either that or sell/buy or trade for 69-72
Old 01-28-2015, 08:50 PM   #5
nate 71 k20
Re: 4 inch lift
Thanks yeah I did a little more seething on it I think I'm going to move my front spring mount fowerd about an inch or do and every thing should line right up I'm doing it in an idiot fab shop with my budy who can prity much make any thing so will figure it out
Old 01-29-2015, 08:51 AM   #6
coopdog
coopdog's Avatar
Re: 4 inch lift
Cool truck man
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 01-29-2015, 10:58 AM   #7
nate 71 k20
Re: 4 inch lift
Thanks alot man
Old 02-02-2015, 11:13 AM   #8
nate 71 k20
Re: 4 inch lift
Well after is settled a bit it came out to be about a 3 inch lift and with all the add a leafs the last owner put in the back it sits prity level I had to move the front spring mounts about an inch and a half fowerd and it put my axle right in the center and my shackles are sitting better and it rides a bit better I used tuff contrys 6000 ez ride 4 inch shocks ass well 35s are coming soon.
