#1751 |
Re: What did you do to your truck today? Chapter II
6 hours of cleaning front suspension parts to get then ready for paint.... 45 years of crud build up is a mess!
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#1752 |
Have you tried electrolysis? It works great and requires little effort. graphite anodes are the cleanest. Electrolysis does take a long time though and some metals can't go in there. also springs
#1753 |
I just don't have the time to work on my truck due to work, so I dropped it off to a mechanic to have a new steering box, new hard brake lines, adjustable trac bar & rebuild the whole front end including new lower control arms
#1754 |
You talking to me? If so.. Huh? Never heard of that... Im a poor old elbow grease kind of guy who doesnt understand that kind of stuff.
#1755 | |
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#1756 |
I thought electrolysis was what your wife did to her mustash
Incapable of not thinking about my truck at least every other minute ![]() |
#1757 |
~ Rust Removal using Electrolysis ~
I am currently using this technique to "de-rust" a pair of Pontiac ram air exhaust manifolds. http://www.instructables.com/id/Elec...val-aka-Magic/ http://antique-engines.com/electrol.asp
#1758 |
Tim's truck got a New set of Wheels, same as my Boss 338s. They look great on his Yellow machine. My truck got an LED brake light tail-light set-up, I like it.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#1759 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1760 |
I installed the rear brake lines and hose.
I just took a knotted wheel on an angle grinder to the stock lines and they cleaned right up. The new brake hose was bought at Napa. ![]()
You remember when drinking too many beers was a bad idea? Me neither. |
#1761 |
New pinion bearings, limited slip and new gears
Chad ![]() '68 Camaro - 408 sbc, Muncie m20, 9' rear, hotchkis supsension (aka Betty) '72 C10 - pretty much all stock as far as i know, for right now anyways (aka Charlie) |
#1762 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Changed up a few things over the last week. Installed my newly rechromed front and rear bumpers and added P01 wheel covers and Euro styled side markers. Had to small up the pics as they were cell phone pics.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#1763 |
Andy, most of the typical truck parts suppliers stock them, I got mine from LMC I think it was like $60.00. They have the Red Only that does Tail-light, Turn indicators and Brake light in RED Only. And there's another model for the same price that also does White Back-up lights. The unit comes with Sticky Tape and a standard trailer wiring plug.
#1764 |
Almost finished with the metal work on one side of my C50 rear fender flares. Now build supports for the second running board and start on the other side.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
#1765 |
Awesome, your truck is a beast!
Scott |
#1766 |
Just brought and fitted this sweet looking canopy for the truck
"I ain't got no time for side tracks!" 69 R/T Charger 72 C10 Chevrolet 85 302 Jaguar 99 955 Daytona 10 1050 Speed Triple |
#1767 |
went and started to price parts, battery, tires and rims, then trying to get the brakes to come back up, first time in many years, opened the hood, to see what was going on there, opened the air cleaner, wow mice bedding, nothing in the carb, will get battery and put some gas in her, and try to see if she will fire over, motor turned over by hand with hardly any drag, so here is hoping it will run
#1768 |
I went to my local Junk Yard to look for 6 cylinder parts , found a few but still need a power steering pump with pulley for V - Belt , I know someone in So. Cal. has a 194 / 230 / 250 / 292 takeout engine lying there I'd like to buy it or some parts off it....
I'm getting antsy about getting my truck back to - gether . I have WORK TO DO . ![]()
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#1769 |
Very Nice. I am gonna steal that one.
#1770 |
Tinted my back window
#1771 |
Later on I went by NAPA and bought a cart load of engine gaskets and some torque converter bolts for the TH350 .
Am I supposed to use washers on these ? typ ? . I really need some 6 cylinder parts and Andy in Riverside doesn't answer 'phone calls nor E-mails , who in So. Cal. has a take out engine ? . I have a couple more pix to post but this junky old computer is so slow it'll choke and lock up instead of down loading them . Next week I guess .
#1772 |
Finished up the bazillion little spot welds (stich actually) across the back of the cab and front a pilliars where I R&R the roof and cab back.
Pics are from last week with it only tacked on but thought somebody might want to see em. Too tired to take any new ones today.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#1773 |
That thing is insane... Those rear fenders will be the bee's knees. Still say big lug nut spikes will be awesome too... would love to see this in person when done.
#1774 |
![]() Join Date: Sep 2011
Got the buddies back from the blaster. Off to the upholstery shop Monday.
1967 C10 SWB Owner - Rustbelt Restorations |
#1775 |
removed the old engine , transmission, crossmember and installed the manual crossmember, new engine and bellhousing.
