02-17-2015, 07:34 AM | #1 |
tire size
Hey guys!
i just bought a new set of wheels for my truck.. got a set of 15x7 slot mags (without the tires in the pic). id like to see what size tires y'all got on your truck. my current tires are two different brands of 31x10.5 R15 on chevy ralley wheels. im looking to get a new set of white letter tires like the coopers or bf goodrich for my slot mags. through a little bit of googling, ive found that 225 60 r15 may be what im looking for... not too tall. not too skinny. id love to see some pics of this size tire on 15x7 wheels on 55-59 trucks of course feel free to post pics and whatever size tires you got!
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
02-17-2015, 12:09 PM | #2 |
Re: tire size
As high as that truck sits I'd go with a taller tire than a 225 60.
This showing a 225-60x15 Radial TA at 25.6 inches tall. http://www.tirerack.com/tires/tires....=yes&tab=Specs On that site you can plug in tire sizes and with a couple of clicks you can see the specs of the tires you are interested in. It will let you know what you want when you go down to the local tire store. http://www.tirerack.com/tires/sizes/...sp?diameter=15
02-17-2015, 03:51 PM | #3 |
Re: tire size
My truck isn't as high anymore . I lowered the front by 2 1/2 inches and took the blocks out of the back.. The truck is sitting at about stock height for a 2wd. This pick is before taking the blocks out of the back. These tires are 31 x 10.5
02-17-2015, 05:59 PM | #4 |
Re: tire size
02-17-2015, 06:01 PM | #5 |
Re: tire size
From the back
02-17-2015, 07:23 PM | #6 |
Re: tire size
now with the new ride height, what size tires would look good on 15x7 slots? my current tires on the ralley wheels are pretty big 31x10.5 15
does that roughly translate to 265 70 r15? im not sure if i could even put these tire on 15x7 wheels? i want a tire thats maybe not quite as tall, but as wide as i can go on the 15x7. i like the tire to fill the wheel well
02-17-2015, 09:07 PM | #7 | |
Re: tire size
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
02-17-2015, 09:51 PM | #8 | |
Re: tire size
According to that site the 265 70 R15 translates to 29.6 inches tall x 10.4 inches wide. If you want to go a little shorter and wider the 255 65 R15 is 28.1 inches tall x 10 inches wide.
58 Fleetside 71 Cheyenne |
02-17-2015, 11:24 PM | #9 | |
Re: tire size
02-18-2015, 11:58 AM | #10 |
Re: tire size
I'd say 10 inches is too wide for a 7 inch rim. In one of the links I posted earlier it shows what size rim works best with different tire sizes.
I think I'd split the difference on tire diameter and go with something between 27 and 28 inches tall and a 70 or 75 width. That will still give you some tread width but work on the rims better and not be too short or too tall.
02-18-2015, 12:09 PM | #11 |
Re: tire size
I know it's kinda splitting hairs with the different tire sizes . If I saw tires mounted in 15x7 wheels, I'd figure out which one I like most. Not too tall , and also not too skinny
02-19-2015, 10:04 AM | #12 |
Re: tire size
I'm looking to get bfg radial t/a
Narrowed it down to these sizes 235 60 r15 235 70 r15 In this pic the seller told me the tires are 235 65 r15 and 235
02-19-2015, 12:25 PM | #13 |
Re: tire size
A 235 section is about perfect for a 7" rim, plus it is a common enough size that there will be lots of choices. If you are at about stock height however, I would consider a 235/75 - 15 which would fill the wheelwell height-wise better.
I use a 235/70 - 15 rears on a lowered truck. |
02-19-2015, 01:05 PM | #14 |
Re: tire size
I don't think bf Goodrich radial ta is available in 235 75. I only see 235 60 and 235 70 listed on the website
I like the cooper cobra tires too. Same thing , 235 70.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 Last edited by 57chevyman; 02-19-2015 at 01:10 PM. |
02-20-2015, 12:51 AM | #15 |
Re: tire size
Here's a 235/75Rx15 on a 15x7" wheel on a sock height 56 GMC
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
02-20-2015, 12:55 PM | #16 |
Re: tire size
In late but here is a spreadsheet I put together for 15" wheels to get width and diameter for different size and aspect within the range I was considering. I have the same for 13-20" wheels. pm me with an email if anyone would like the original excell spreadsheets to play with.
02-20-2015, 03:05 PM | #17 |
Re: tire size
on 15x7 wheels:
bf goodrich radial T/A and cooper cobra radial G/T size 235 60r15 235 70r15 245 60r15 thoughts on these sizes for my near stock height truck and BFG vs Cooper? the BFG 235 70r15 happens to be only $102.50 each at mavis right now after rebate.
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 Last edited by 57chevyman; 02-20-2015 at 03:10 PM. |
